Hi there,
today I installed my ordered rotary encoder (Alps STEC12E08 24 impulses with 24 detents, which is already used by many) in the DS1054z (Mode to DS1104z).
First had to find out that the Rigol button / encoder board was changed.
All rotary encoders are now surface mounted. This means that there are no more holes.
Ok, modified the new Alps so that it was on the back plan, unsoldered the original and installed the Alps exactly positioned.
So far everything is ok, but the detents do not match the impulses.
Especially in longer menu lists, you notice that one menu point is often skipped per rest.
Could it be that in the last update the behavior on the encoder was changed so that this Alps is no longer read correctly?
