Author Topic: Rigol DS1054Z unlock  (Read 6275 times)
Offline paddyred
« on: April 25, 2016, 08:09:59 pm »
Hi guys,
I apreciate this topic has been done to death but I was hoping for a more recent update. Does Riglol still work on the latest version of the v04.01 firmware? Also if it isn't a good code what happens? apparently it locks you out?
Offline ytterligare
Re: Rigol DS1054Z unlock
« Reply #1 on: April 25, 2016, 09:01:55 pm »
Hi Paddyred, as I said, mine arrived last week, with firmware 4.03.SP2, and riglol did his duty, no sweat. ;)
Hope it helps.
Offline paddyred
« Reply #2 on: April 25, 2016, 09:27:44 pm »
Thanks for that! Hopefully mine has the SP2. Is there a newer version? I have just ordered mine from direct from rigol
Offline paddyred
« Reply #3 on: April 25, 2016, 09:58:54 pm »
Also, what code did you use? Was it DSFR as I keep seeing DSER as the working one. Have you used your 500uV vertical too? Apparently it doesn't work on the 1054z but if it didn't work why put the software there in the first place!
Offline Marcos
« Reply #4 on: April 25, 2016, 10:10:27 pm »
Pray not to have the latest firmware release. Read forum about it.
The good code is DSER.
Offline Athanasis
  • Country: cy
« Reply #5 on: June 09, 2016, 11:30:06 am »
Is there any newer release than 4.03.SP2 ?
Also which is the best unlock method to date? Any light there?
Offline nanofrog
« Reply #6 on: June 09, 2016, 12:59:10 pm »
No, not yet.
Hasn't changed; go to the Riglol 1.03d website, enter your unit's S/N, and the code DSER in the Options field (leave Privatekey blank), then hit the Generate button. A small window pops up with your unlock code.
At this point, RTFM on how you enter this code and do so. Then reboot IIRC, and you're done.  :)
Don't sweat over this, it's very easy to do.  :-+
Offline Dawid
« Reply #7 on: July 28, 2016, 08:35:04 pm »
Hey,
I just bought DS1054Z and my firmware is: 00.04.04, board: 0.1.4
I assume it is the latest (am I right?)
Hacked succesfully.
