Author Topic: UT61E backlight wire routing  (Read 1155 times)
Offline seanspotatobusiness
« on: September 17, 2018, 01:50:48 pm »
I'm putting a backlight into my UT61E DMM, controlled by a cheap TTP223 touch sensor module. I would like to know if my intended location for the module and wiring could affect the accuracy of the meter. I wanted to put the module on the front (there seems to be enough room) to avoid threading my wires from front to back but maybe there's a good reason most mods seem be placed at the back?
I did find this image on another forum. Is that the only area sensitive to interference?
Thanks!
Offline Nisei
Re: UT61E backlight wire routing
« Reply #1 on: September 17, 2018, 03:27:01 pm »
Check my tutorial here:
https://www.eevblog.com/forum/testgear/uni-t-ut61e-backlight-mod-with-touch-sensor-(tutorial)/
The pics are showing exactly where I placed the wiring and module and it's working fine that way.
« Reply #2 on: September 17, 2018, 03:29:25 pm »
Unfortunately the finest wire I have is still too thick to feed through those via holes from the back of the board to the front so I'm hoping for an alternative route.
Offline Nisei
« Reply #3 on: September 17, 2018, 03:51:38 pm »
Why not spend less than $5 and have enough wire for the rest of your life?
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F302864621867
