Like so many others here, I went for one of the Instek GDM-8251A meters that was for sale on eBay. At the price they wanted, it was really hard to pass up.
It seems to function well except for one thing: the current input is dead. Shows almost, but not quite, zero amps.
Further testing shows that the issue is with the 1A and 10A ranges. When it switches between those and 100mA and 10mA ranges, you can hear a relay click. There's a fuse on the low-current common input jack, and that works just fine. I don't know if there's a similar thing for the high-current circuit. If there is, it doesn't appear to be easily replaceable.
I may be facing a dead relay. I suppose it's possible that the 10A current shunt resistor is dead, or perhaps one of the amplifiers. I don't know anything about how this is architected.
Anyone else have similar issues with theirs? I know that I was supposed to take it apart before I turned it on, but I couldn't resist.
Anyway, could make for an interesting repair attempt...
