I posted about my failed Rigol before - it failed to boot with a black screen and all lights stayed on. This happened last summer as soon as the weather got warm here. Last time I sent it in for repair - took two weeks, but it got back working. Today (weather's warm again) the same thing happened.
Not wanting to send it back for repairs every summer, I opened the thing up and measured some voltages coming from the switch mode supply, and they were all much lower than they should be (4.2V, 9.2V, -3.1 V...) ...poor regulation? Couldn't find any obvious problems on the switch mode supply, and since I don't have a second scope, it's hard to check. Has anyone had similar problems (Black screen, lights come on and stay on, no booting)? And have you been able to fix it without sending the thing in for repairs...?
This is getting really frustrating,...I need my test equipment to work and my circuits to fail(!) not the other way round
Based on the supply diagram from "A Helene" in another post, I measured the psu output voltages while connected to the main board. Here are the results....
As you can see, all the voltages are too low. Any ideas what could cause this? Any help is greatly appreciated.
