Author Topic: RIGOL DS2000 mod - silent fan  (Read 18722 times)
Offline Carrington
Re: RIGOL DS2000 mod - silent fan
« Reply #25 on: November 21, 2013, 03:24:43 pm »
« Last Edit: November 21, 2013, 03:27:23 pm by Carrington »
My English can be pretty bad, so suggestions are welcome. ;)
Space Weather.
Lightning & Thunderstorms in Real Time.
Offline ilciberneticoTopic starter
« Reply #26 on: November 21, 2013, 05:40:56 pm »
I confirm that the original fan of my DS2072 is marked GLOFN GFA06015H12H with 0.16A of absorption...
Offline Clint
« Reply #27 on: November 21, 2013, 06:16:06 pm »
And it can be either of those two, but not much difference.
looks like 3dB difference to me ??????
g33K5 L1k3 80085
Offline Carrington
« Reply #28 on: November 21, 2013, 06:30:06 pm »
Yes 3dBA. So what? We want to change it for other.  :-//
The NF-A6x25 airflow is 29.2m3/h vs (28.2 or 30) and the acoustical noise is 19.3dBA vs (33.5 or 36.5).
« Last Edit: November 21, 2013, 08:11:32 pm by Carrington »
Space Weather.
Offline Carrington
« Reply #29 on: November 22, 2013, 10:33:52 pm »
There is another reason by which I haven't changed it yet:
If the temperature control have feedback then, no problem, since both are able to achieve the same airflow at 12V (assuming that 12V is the maximum).
But if no, both fans should have a similar airflow response, or higher for the new compared to the original.
Thinking about more carefully, yes, exists feedback.
« Last Edit: November 22, 2013, 11:04:07 pm by Carrington »
Space Weather.
Offline Circlotron
« Reply #30 on: January 10, 2014, 04:30:54 am »
Those sharp metal edges that the air has to flow through can make a fair bit of noise too. I have cut them off on computer power supplies for a reasonable improvement. Seeing it is inside the scope case you could do this without it being visible from the outside.
Offline Veketti
« Reply #31 on: March 08, 2023, 09:07:11 pm »
Sorry to revive old topic. As my DS2072A is out of warranty I wanted to try to make it more quiet. First of all, I cut the metal grill obsturcting the fan. There is still the plastic grill to protect it. That reduced the noise bit, but still it was loud. Installed Noctua NF-A6x25 and now it is quiet. However temperature rose from 27.5°C to 31.4°C. Noctua's advertized 0.12A current was not even close to reality. It draw only 0.075A. Original fan was 0.16A and draw 0.166A. Even though the exhaust temperature aint that high, I think I'll put back the original fan as it runs four degrees hotter. Component temperature differences might be even more than that..
Online Fungus
« Reply #32 on: March 08, 2023, 09:10:07 pm »
Those things are rated to run in 50 degree Celsius ambient temperatures.
I don't think 4 degrees rise will make much difference.
Even if you're not convinced by that I wouldn't give up on making it quiet. Maybe get a different fan.
« Last Edit: March 08, 2023, 09:11:42 pm by Fungus »
Offline Veketti
« Reply #33 on: March 19, 2023, 05:47:02 pm »
Bit update. Ordered bunch of fan's, but 60mm size unfortunately only one. Orion OD6025-12HB with following specs: 25CFM / 42m3/h 0.22in H2O / 54.8Pa 30 dbA. So should be 6.5dbA more quiet than the original GLOFN. But it's now 55dbA at around 50 cm in front of the scope. Not really quiet, I'd say it's loud, but darn that thing moves air. Exhaust temperature 30°C.
Online LinuxGuy123
« Reply #34 on: March 07, 2024, 09:57:25 pm »
Do you have an update on this ?   I have a 2072 and I'm tired of how loud its fan is.
