Products => Test Equipment => Topic started by: kenche on December 12, 2018, 02:39:23 am
If you follow the instructions on the link closely it will create the correct code. Instead of creating a file on a USB drive, I entered the code using the EDIT function on the scope. https://www.bambach.biz/projects/elektro/upgrade-rigol-ds2072a-to-ds2302a/ (https://www.bambach.biz/projects/elektro/upgrade-rigol-ds2072a-to-ds2302a/)
It was the only way I could get it to work also. Did you get the 300mhz code to work? I got 200, but not 300.
