Sooo, that's my first post here, and it's already about something horrifying.
![Undecided :-\](https://www.eevblog.com/forum/Smileys/default/undecided.gif.pagespeed.ce.cCZ6w-jWpR.gif)
I have a Rigol DS2072, which I "upgraded" to a DS2202+56M. I did that soon after I got the scope and have been using it for about two month now.
Last time I used it, I enabled math mode and channel 1, everything was working fine. So far so good.
Now when I switch on the scope, it boots, and I can see that the settings from the last time I used it are still in effect, but the scope is stopped and completely frozen (-> doesn't react on any input).
I have tried flashing the firmware, wich works, but the scope is still frozen, and even the same settings are still displayed. I tried several firmware versions, but the result is always the same.
Is there any way to hard-reset the scope?
I'm not sure if this issue is caused by the 200MHz hack, or by anything I have done (eg. a bug in the math mode?)
Thanks in advance for any help!
