Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Products
Test Equipment
Rigol ds2102e CAN decode
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Rigol ds2102e CAN decode (Read 1151 times)
rockfishon
Newbie
Country:
on:
February 08, 2019, 05:20:33 pm »
Is it possible to CAN decode the "A-B" math signal on a Rigol DS2102E? I just purchased a new DS2102e and am trying to use it to decode potential issues on my Chevy CAN bus. It seems that the decode can only be applied to CH1 or CH2 unless I am missing something.
Logged
TurboTom
Super Contributor
Country:
Re: Rigol ds2102e CAN decode
Reply #1 on:
February 09, 2019, 12:46:57 am »
At least on an MSO2**2A-S it's not possible to select math as an input to a decoder. I'm afraid the only way to analyze a differential signal on one of these Rigol scopes with their protocol decoders would be to use a "proper" differential probe.
Logged
JDubU
Frequent Contributor
Country:
Reply #2 on:
February 09, 2019, 01:26:12 am »
What about adding a CAN transceiver eval board to do the differential to single ended conversion?
For example:
https://www.amazon.com/gp/product/B00KM6XMXO/ref=crt_ewc_title_huc_1?ie=UTF8&psc=1&smid=A50C560NZEBBE
Logged
Romain
Regular Contributor
Country:
HW & SW consultant
Reply #3 on:
February 09, 2019, 01:32:58 am »
If you're just after decoding the bus, then simply decoding A should be enough to retrieve the packets.
However, you could use a CAN transceiver, or a simple op-amp if you're after the differential signal.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Products
Test Equipment
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
