Author Topic: Rigol DS4000 100 MHz hackable to 500 MHz?  (Read 18433 times)
Offline alank2
Re: Rigol DS4000 100 MHz hackable to 500 MHz?
« Reply #50 on: August 25, 2017, 12:07:37 pm »
Moreover, in comparison to other oscilloscope manufacturer's offers, the Rigol DS4000 series doesn't appear as attractive anymore as it may have three or four years ago.
I don't know.  Who else offers a 4 channel scope with the DS4000 performance/dual ADC's at a price anywhere close to it even now?  You can run 2 channels at 4 GSa/s or all 4 channels at 2 GSa/s.
Offline Steff_electronics
not able to perform the upgrade
« Reply #51 on: February 17, 2018, 08:26:10 am »
even if it is an old topic I would like to ask why I could have problems doing the upgarde?
I have a DS4014 with decoder upgrade already done, but I am not abe to do the BW upgrade.
It is using SW version 00.00.04 and HW version 1.2
Thanks for any help
Offline extronic
    • Extronic
Re: not able to perform the upgrade
« Reply #52 on: April 27, 2018, 02:52:15 pm »
Thanks for any help
What exactly problem do you have?
I'm about to buy MSO4014 and need to be sure if I can upgrade it or not :)
EXTRONIC STORE - https://extronic.pl/
Offline jjoonathan
« Reply #53 on: April 27, 2018, 03:35:37 pm »
The latest version of the SW (and the version I have been using for the last ~year with 500MHz option) is 2.3.0.3. This is significantly newer than 0.0.4, maybe they added the option between the two versions?
Offline mrbk
« Reply #54 on: April 27, 2018, 04:05:16 pm »
Hi!
I upgraded my brand new mso4014 just two weeks ago.
Using latest firmware.
And it works beautifully.
So unless they changed something in the last days you're probably fine.
/B
Offline TurboTom
« Reply #55 on: April 27, 2018, 04:06:10 pm »
The latest S/W version for the DS4000 series is 2.3.1.1, apparently published in October, 2017.
Offline alank2
« Reply #56 on: April 27, 2018, 05:31:21 pm »
Does anyone have the latest list of fixes for that latest firmware?
Offline jjoonathan
« Reply #57 on: April 27, 2018, 06:57:34 pm »
I don't see 2.3.1.1 on int.rigol.com and the form on int.rigolna.com gives me a zip of 2.3.0.3 when I put in my serial number. Where did you spot it?
Offline ErikTheNorwegian
  • Country: no
  • Asberger, aspi, HIGH function, nerd...
« Reply #58 on: August 21, 2020, 07:04:56 pm »
if someone got time and info..i could need some help,
got a MSO4024, how can i uppgrade/hack  this to 500Mhz?
/E
/Erik
Goooood karma is flowing..
  • Country: no
« Reply #59 on: August 22, 2020, 06:24:52 pm »
I moved my question to :
https://www.eevblog.com/forum/testgear/rigol-ds4000-option-and-bandwidth-hack-251434/msg3200358/#msg3200358
The thing I did not know, was that the system info screen will still say it's a MSO4024 after it's been hacked... 😆
« Last Edit: August 23, 2020, 02:55:34 pm by ErikTheNorwegian »
/Erik
