Author Topic: Rigol DS4012 100 MHz hackable to 500 MHz?  (Read 10566 times)
Offline bozidarmsTopic starter
  • Country: at
« on: March 02, 2016, 01:07:16 pm »
Hi to all,
i am new in group and have question before baying:
(i cant find nothing about DS4012)
can somebody, please, finally tell is it possible to convert Rigol DS4012 into 500MHz scope?
Thanks and best regards,
Bozidar
  • Country: at
Re: Rigol DS4012 100 MHz hackable to 500 MHz?
« Reply #1 on: March 03, 2016, 07:00:16 pm »
Does, relay, nobody wont to help with answer?
I know that this theme was here before, but simply a cant find nothing about DS4012. :-//
Offline hendorog
« Reply #2 on: March 03, 2016, 07:21:12 pm »
I guess noone else here has done it. There are probably not many 2 channel DS4000's out there.
You could be the first one to try  :-+
Offline Muxr
« Reply #3 on: March 03, 2016, 07:23:43 pm »
Here is an epic thread that details how the hack was derived for 1k and 2k models. https://www.eevblog.com/forum/testgear/sniffing-the-rigol's-internal-i2c-bus/
Not many people have the 4k Rigol, but it may be similar to unlock it. So feel free to read the thread and potentially come up with a hack yourself.
Online H.O
« Reply #4 on: March 03, 2016, 07:28:57 pm »
Several users here (me included) with Rigol 4000 series scope but I can't remember a single one reporting they own a 2 channel model. As has been said in the other thread there's really no reason for the hack not to work on the 2 channel models but again, either no one owns one or the one(s) who do haven't tried to hack it.
Offline hendorog
« Reply #5 on: March 03, 2016, 07:37:39 pm »
^^^ Yep exactly, wot he said ^^^
  • Country: at
« Reply #6 on: March 03, 2016, 08:35:41 pm »
Thanks for now.
I have a chance to get one for reasonable price (i think so),
and if all goes right i will try to hack that one.
Regards
« Last Edit: March 03, 2016, 08:55:11 pm by bozidarms »
Offline Gunb
« Reply #7 on: March 06, 2016, 05:37:25 pm »
What?
I've reported a few times to own the 2-channel version for years. And I hacked it to 500MHz successfully, at first I used the firmware later on the serial.
Rgds
Online H.O
« Reply #8 on: March 06, 2016, 07:49:44 pm »
Sorry about that, I do recall you've got a 4000 model but not that it was the 2 channel version. But that's great, the OP has received the answer he was looking for. Thank you!
  • Country: at
« Reply #9 on: March 09, 2016, 07:46:17 pm »
Thanks you all,
specially to Gunb with nice news.
I didn't receive Rigol yet, but   is on the way.
I would allow me to contact Gunb when is applicable.
Best regards,
Bozidar
  • Country: at
« Reply #10 on: March 18, 2016, 08:10:15 pm »
Hi to group,
finally received Rigol DS4012, and  hard to believe but it is true -
unlocked all options, 500MHz BW too :clap:
just amazing...
Tnx to all.
Best regards,
Bozidar
« Last Edit: March 18, 2016, 08:18:28 pm by bozidarms »
  • Country: at
« Reply #11 on: March 19, 2016, 12:48:28 pm »
I know, is perhaps too much,
but i can't hide my enthusiasm.
I swear don't do that anymore.
It seems that the upper limit is over 1,1GHz - hats off Rigol, AWESOME!
regars,
Bozidar
« Last Edit: March 19, 2016, 05:20:10 pm by bozidarms »
Offline lifeclock
« Reply #12 on: June 01, 2016, 12:13:24 pm »
regars,
Bozidar
Do you have a link to the instructions you followed? I would also like to do this.
Offline TurboTom
« Reply #13 on: June 01, 2016, 01:46:53 pm »
I found out the same with my MSO4014. Trigger works up to somewhere between 1.1 and 1.2GHz, yet the displayed signal (voltage) is attenuated by approx. 24dB (or 1/16th of the actual input signal). 3dB bandwidth is round about 600MHz. Anyway, that's an amazing performance for a 100MHz scope...  8)
Offline hendorog
« Reply #14 on: June 01, 2016, 09:53:16 pm »
Haha it's a pretty cool feeling, I posted the same thing when I got mine.    :-/O
For me the triggering still works up to 1.6GHz, although once the freq gets up there you need to use averaging to see a trace.
That proves that the trigger is working as if it wasn't the averaging would show a flat line.
- This was tested with a -10dBm signal from my Signalhound and an ~ 0dBm signal from a PLL eval board. Scope input set to 1Mohm, not 50ohm for the higher freq.
Edit: Also I found 2mV/div was more sensitive than 1mv/div at these frequencies - and of course the trace isn't useable, it's just fun to play with.
« Last Edit: June 01, 2016, 09:59:11 pm by hendorog »
Offline vedro
  • Country: si
« Reply #15 on: September 26, 2016, 03:37:49 pm »
Hello,
I am new to this forum and from what i`ve seen so far I regret not joining earlier. Allot of great threads on electronics (especially on my favorites, FPGA`s  :) )
we are planing to purchase a Rigol DS4012. I like the possibility for a 500 MHz hack. Could you guys please shed some light on how to do the hack.
Best regards,
vedro
Offline pascal_sweden
  • Country: no
« Reply #16 on: September 26, 2016, 04:58:55 pm »
Why not buy the model with 4 channels? :)
Offline ebclr
« Reply #17 on: September 26, 2016, 06:18:03 pm »
PRICE for 4 channels is much higher
Online H.O
« Reply #18 on: September 26, 2016, 07:19:56 pm »
Well, it IS more expensive but really not that much.
At this time Batronix sells the DS4012 for €1795 and the DS4014 for €1995, the difference there is probably less than what the two extra probes you get is Worth alone, not to mention the two extra channels. Then again, if you know you don't need it then "wasting" €200 is of course stupid.
Whichever model you buy you now get all the options (excluding bandwidth) for free.
They also have the "Economy model", with 2GSa/s and 14Mpts memory, it would be interesting to see a teardown of such a device, if they're TOO the same 4GSa/s, 500MHz, 140Mpts hardware being sold at an even lower pricepoint.
Offline TurboTom
« Reply #19 on: September 26, 2016, 09:16:17 pm »
But if you buy it here you´ll get it for considerably less: http://www.rigol.eu/clearance/#a_DS4012
2 years warranty included  ;D
...appears like someone bought it already probably it was temporarily hidden in someone´s shopping basket...
« Last Edit: September 28, 2016, 05:16:15 am by TurboTom »
Offline vedro
  • Country: si
« Reply #20 on: September 27, 2016, 08:19:44 am »
Hello,
I have searched this forum and found a possible "solution" for the update.
Link: https://www.eevblog.com/forum/testgear/sniffing-the-rigol's-internal-i2c-bus/msg523679/#msg523679
This is reported to work. I am not sure which version of firmware are nowadays models shipped with. You guys, who bought the oscilloscope recently and performed the update, what FW version was installed?
Best regards,
vedro
  • Country: at
« Reply #21 on: September 27, 2016, 01:43:09 pm »
that is right solution / i have done so :-+.
Since then i haven't upgraded / everything work perfect.
Regards
  • Country: no
« Reply #22 on: September 28, 2016, 06:21:37 pm »
Are you really sure about the 2 years warranty? On the top of the Rigol product deals list it says explicitly "90 days warranty". I am under the impression that the "2 years warranty" description, as you can find in the product itself, is a copy-paste artefact from the new product list :)
Offline TurboTom
« Reply #23 on: September 28, 2016, 08:32:29 pm »
I´m 99% certain that the specified warranty in the product description has to be correct since there are several items with no warranty explicitely mentioned, some with one, two or even three years specified. In the "standard" product description, there´s no warranty period mentioned. I placed an order on one instrument with apparently a two year warranty period. It´s already delivered but I´m remote from home at work during the week so as yet I cannot confirm anything. I´ll report once I´m back home and opened the box and checked the documents.
Cheers,
Thomas
Offline TurboTom
« Reply #24 on: September 30, 2016, 02:35:19 pm »
Okay, just went through the shipment and papers: There's nowhere a note to be found regarding a reduced warranty period. So I guess european legislation is valid here that grants the consumer a limited 2-year warranty (which of course I already voided anyway  ;) )...
P.S.: FYI, here you can read more about my purchase: https://www.eevblog.com/forum/testgear/rigol-mso2000-series-hacking/msg1038258/#msg1038258
Edit: Added post scriptum
« Last Edit: September 30, 2016, 03:11:32 pm by TurboTom »
