1) The bigger the supported frequency range, the better! Note that many useful measurements incide on harmonics. If you are measuring a DUT at 700MHz, you may be interested to take a look at the 3rd or 4th harmonics - 2.1GHz and 2.8GHz. A spectrum analyzer that only reaches 1.5GHz may be limited - ultimately it really depends on your desired applications. Of course, if you are just into HF/VHF/UHF radios, then 1.5GHz might be more than enough.
2) Why go Rigol? You can purchase the Siglent SSA3021XPlus and then hack it into a SVA1032 - a full feaured SA/VNA up to 3.2GHz, at around 1.500 Euro (+VAT).
Regards,
Vitor
