Author Topic: ECOM Ex-DM 1000 - A rebranded Fluke 87-III Ex  (Read 6142 times)
Offline armandasTopic starter
  • Country: jp
    • My projects
« on: February 05, 2014, 08:16:32 pm »
Now here is something you don't see every day - a completely rebadged Fluke handgeld DMM. I scored this on an ebay auction that no one else was interested in :)
Judging from the appearance, it is a rebranded Fluke 87-III Ex, although I was not able to find any references to an intrinsically safe version of the Series 3. This could be the first Fluke generation that had an Ex version. It looks like ECOM have been doing Ex modifications for Fluke for a long time (see here), but no longer rebadge the DMMs.
  • Country: jp
    • My projects
Re: ECOM Ex-DM 1000 - A rebranded Fluke 87-III Ex
« Reply #1 on: February 05, 2014, 08:17:33 pm »
A couple of pictures from inside. Anyone knows what's that thing stuck to the front?
« Reply #2 on: February 05, 2014, 08:22:29 pm »
Probably a thermal shield to prevent bits of exploding fuse from burning a hole through the front panel.
Offline Wytnucls
« Reply #3 on: February 05, 2014, 08:27:58 pm »
I don't think it's a shield. It has wiring going to it.
More like a sensor of some sort.
Or perhaps the buzzer, as it looks like the whole PCB has been potted.
« Last Edit: February 05, 2014, 08:32:09 pm by Wytnucls »
« Reply #4 on: February 05, 2014, 08:33:50 pm »
Likely then it is the MOV's for the EEx rating then under a blast shield so the arc as they fail will still not ignite vapour.  Wiring looks in the right area for extra clamps.
Offline Wytnucls
« Reply #5 on: February 05, 2014, 08:43:59 pm »
MOV or a Gas Discharge Tube are good candidates.
  • Country: jp
    • My projects
« Reply #6 on: February 05, 2014, 08:52:19 pm »
Ok, that kind of makes sense.
Offline Napalm2002
« Reply #7 on: February 06, 2014, 12:59:05 am »
How much did u score it for?
Offline EEVblog
« Reply #8 on: February 06, 2014, 01:02:34 am »
Interesting!
Certainly an approved custom job.
  • Country: jp
    • My projects
« Reply #9 on: February 06, 2014, 08:15:45 am »
£80
Interesting!
Yes, even the manual is completely rebranded.
Offline peter.mitchell
« Reply #10 on: February 06, 2014, 10:26:49 am »
£80
Bahhhhhginnn!
I think it is the MOVs, if you look at the board compared to a "normal 87 iii", there appears to be a "jumper" in a sheath under the compound, though it kinda looks like a MOV with the same coating fusible resistors get...
