Author Topic: If my scope is 20 MHz, any reason to get a probe rated to 100 MHz?  (Read 2114 times)
Offline gooseEL34Topic starter
Thanks
Offline Keysight DanielBogdanoff
  • ALL THE SCOPES!
    • Keysight Scopes YouTube channel
Re: If my scope is 20 MHz, any reason to get a probe rated to 100 MHz?
« Reply #1 on: May 19, 2016, 10:15:47 pm »
The probe you get will effect your overall bandwidth.  100 MHz is probably more than you need with a 20 MHz scope.
We actually had a blog post a few weeks back that talks about calculating the system bandwidth: https://keysightoscilloscopeblog.com/2016/03/30/what-is-oscilloscope-system-bandwidth-and-how-do-i-find-it/
Offline tautech
« Reply #2 on: May 19, 2016, 10:41:47 pm »
Thanks
Just get a pair of these:
http://www.ebay.com/itm/Two-P6100-DC-100MHZ-Oscilloscope-Scope-Clip-Probe-100MHz-For-Tektronix-HP-DY-/262248944156?hash=item3d0f41521c:g:2scAAOSwezVWup1c
You can't go wrong unless your scopes input capacitance is some crazy value outside the probes range of adjustment.  :scared:
Avid Rabid Hobbyist
Offline saturation
  • Doveryai, no proveryai
    • NIST
« Reply #3 on: May 21, 2016, 12:33:50 pm »
Quality control on those no name probes can vary so best to get the higher MHz rated one.  Also, a 60MHz and 100 MHz probe from no-name are essentially the same price, and for use at 20MHz both work very well as the Keysight document explain. If you are diligent on eBay you could find even higher rated probes for less money if you buy more than one.  I bought a box of 4+ some years ago for ~ $20 as day-to-day banger probes; the construction could be iffy, but most of those in the box are still alive; I think we posted tests on eevblog forum some years ago.
https://www.eevblog.com/forum/reviews/cheapest-100mhz-oscilloscope-probes-hands-on-review/msg100171/#msg100171
Best Wishes,
 Saturation
