Author Topic: Rigol HDO1000 and HDO4000 12bit oscilloscopes launched in China  (Read 316698 times)
Offline Veteran68
Re: Rigol HDO1000 and HDO4000 12bit oscilloscopes launched in China
« Reply #1225 on: April 07, 2024, 10:41:30 pm »
I have received the below news from Rigol, see the attached screen capture.
The following link for USA :
https://www.rigolna.com/promos/?utm_campaign=DHO1000%20PROMO%20EMAIL%20-%20032724&utm_medium=email&utm_source=AHA
That's the same $899 the DHO1074 has been selling for since February. Looks like the promotion will extend through July. It's $100 off, but nowhere near the deal that BF was ($400 off).
The following users thanked this post: egonotto, thm_w
Offline vokars
« Reply #1226 on: May 26, 2024, 11:20:54 am »
I am working with the Rigol DHO 1072 for 2 weeks now and it is finally the scope I was looking for many years now. I need it for audio stuff that means low noise, low SFDR, high vertical resolution but not so much bandwidth.
Pros Presale
  • Very well specified
  • Because many features from the DHO4000 series: very well shielded (information thanks to EEVBLOG teardown) and 1.5 ppm clock precision
  • 10 MHz reference input / output
  • Averaging and High Res mode in acquisition not just math
  • screen resolution 1280×800
  • Good visual representation of analog waveforms
  • fast and reliable datatransfer for scripting (python / pyvisa)
  • Window docking
  • pricing ok
Pros from Testing for 2 Weeks now (latest firmware release xxx.12)
  • Very good general user experience:
    • Really sensitve well shielded instrument with low noise and good SFDR. I finally can see all this mud that my function generator is creating.
    • Ergonomic workflow including FFT(!).
    • Many small but useful features that make this a great scope e.g. Option windows can be left open during measurement because they can be set to transparent background.
  • Low SFDR / noise
  • 16 Bit High Res mode @25 MHz bandwidth (with full 2 GSa/s sample rate) !!!
    • 14 Bit High Res with 50 MHz bandwidth.
    • With the usual bandwith reduction of factor 4 per bit this would be 3.125 MHz not 25 MHz in 16 Bit mode. So it looks like the High Res Filter for 16 Bit doesn't reduce the corner frequency directly but the 14 Bit filter is applied for a second time so that the filter attenuation is larger instead (not sure)?
  • Actual good visual representation of analog waveforms as expected.
  • 1 MSa FFT works fine. As always the FFT has to be set up approriatly by the user to get the optimal results.
  • Remote interface works fine using python scripting / pyvisa. There is one issue: see cons.
Cons from Testing
  • Encoders
    • in this blog it was reported that encoders sometimes can lose a step. It was speculated if this is a mechanical, software, asic, ... issue: It's mechanical. I have it at the horizontal encoder. But with light side pressure the problem is gone. So it's no showstopper for me but nevertheless Rigol should use other encoders in future versions.
  • When measurement is stopped and memory setting is changed then after next measurement the user interface should show the new samplerate. Works with autotrigger but not with single trigger. The refresh is finally triggered when e.g. the horizontal time base is changed. Not a showstopper because just a GUI problem and a workaround exists. When using the remote interface the correct value is provided. But Rigol should fix it with a firmware release.
  • XY
    • As shown here for the DHO900 33:35 the grid in xy mode is not quadratic. XY is a visual tool so sin/cos with equal amp should be a circle. Nevertheless the scale values are correct but Rigol should change that with a firmware update.
  • When getting large waveforms from the scope with scripting/python/pyvisa I need an additional delay of about 200 msec to get the correct waveform. *WAI, *OPC?, *OPC + polling event registers, ... don't provide the required handshaking. Rigol should fix that in a future firmware release.
  • FFT cannot use math channels as source. That issue was discussed in this BLOG. It cannot. I understand that this is a performance issue but a slow FFT when using a math channel is better than none at all. Rigol should change that with a firmware release.
Siglent Comparison (SDS1000 HD) (Only Presales no Testing)
  • Showstopper for me was that Averaging and High Res ("ERES") is just available as math channels. For audio stuff High Res is the most important mode. And a learned from experience that Rigol has 16 Bit@bandwidth of 25 MHz with smarter filter than just moving average / decimation.
    • I heard that for SDS2000 HD series this is planned to be changed with a firmware release but I didn't want to bet on a firmware release for the SDS1000 HD series. When this would be included in a future firmware release it would actually be a game changer.
  • Spec not as good as the Rigol DHO 1000 datasheet. E.g. I didn't find the clock precision. My fault?
  • SDS1000 HD has lower screen resolution than Rigol DHO 1000 series. Hm ... it's a 12 bit scope ...
  • SDS1000 has better math (formula editor, ...) but Rigol math is ok for me because the math channels can be chained (exception FFT :( ). More complicated stuff has to be done with scripting anyway.
Rigol DHO800 comparison (Only Presales no testing)
  • Thanks to the EEVBLOG teardown I have learned that the DHO 800 internal shielding is not what I expect from a sensitive measurement istrument. DHO1000 quite the opposite. Looks rock solid and instrument performance shows that.
  • DHO 800 screen too small for a touchscreen with docking windows.
The following users thanked this post: egonotto, thm_w, the Chris
Offline egonotto
« Reply #1227 on: June 04, 2024, 01:14:48 am »
Hello,
Batronix states “availability unknown (Verfügbarkeit unbekannt)” for the Rigol DHO1074.
Best regards
egonotto
The following users thanked this post: vokars
Offline hololens
« Reply #1228 on: June 20, 2024, 04:24:22 am »
There is an update available:
[Model Supported] All the DHO4000 series oscilloscopes
[Latest Revision Date] 2024/03/27
[Updated Contents]
00.02.13 2024/03/27
      - Fixed the problem of deleting files when copying the same files.
      - Requirements for optimizing the total time for oscilloscope delivery, configuration, and reading.
      - Fixed the problem of crash when LAN is not connected and click Apply.
      - Fixed the problem that after passing the test screenshot, it cannot be stopped.
      - After fixing the default, *IDN? cannot read the project version number.
      - The problem of not closing the project version number lxi/identification.
      - Fixed the issue of statistics not being reset when moving the measurement cursor.
      - Fixed the problem that the measurement value of the moving cursor area is not updated after STOP.
      - Fixed the problem of occasional no waveform when booting.
      - Fixed the issue of the waveform disappearing in small gears after a pause.
      - Implementation of USB external keyboard requirements.
      - Fixed the problem of obtaining Math waveform error.
      - Fixed vertical scaling mask error by testing.
      - Fixed SPI timeout triggering problem, also for four-channel mode.
      - Modify the problem that ultraLab cannot connect to the server after shutting down and restarting.
      - When the Zoom function is turned on, the cursor adjustment area is not limited to the Zoom window.
      - Modify the offset range below 50 ohm and 500uV/div to solve the flip problem.
      - Fixed the problem of failure to modify the settings of measurement source B.
      - Fixed the problem of window transparency and failure to load the last value.
      - Fixed the problem of error in saving screen waveform to csv and SCPI command to obtain waveform in Math filter operation.
      - Fixed the problem of crosstalk caused by adjusting vertical offset.
      - One-click to open the measurement items required by the user and realize the functional requirements of the trigger source tracking channel.
     - Error displayed when modifying the measurement cursor for multi-source measurement.
     - Fix the problem of IIC SCL threshold and SDA threshold random reset&trigger level line random jumping caused by probe ratio at 10X gear.
The following users thanked this post: egonotto, thm_w, vokars, the Chris, Lochstreifen
Offline sorenkir
« Reply #1229 on: June 20, 2024, 03:20:14 pm »
Installed on my DHO1074 without any issue. All options still active. I just had to do the fan speed hack again.
Michel.
The following users thanked this post: egonotto, the Chris, Lochstreifen
Offline TurboTom
« Reply #1230 on: June 21, 2024, 12:55:14 pm »
As @sorenkir reported, installation of the firmware works okay, though not as described in the instructions (Menu -> Storage -> Upgrade -> File Path -> select "Removable USB Disk -> select firmware file (check circle) -> OK -> Upgrade). The "Upgrade" function directly in the main menu (still) doesn't seem to work.
Fan speed mod gets reset as mentioned, moreover the broken "Flattop" FFT window file gets re-installed, so to correct this, the window file needs to be replaced again as described here.
Probe scaling factor appears to be corrected in the decoders, so that's a  :-+
Unfortunately, video trigger still appears to be broken (at least PAL and NTSC, I didn't have a source available for the higher standards).
I'm not certain if someone from Rigol checks this forum for bugs of their products or ideas for improvements -- I rather get the impression that this isn't the case. But I'ld consider it a great idea for Rigol to "give us" the 50 Ohms inputs since Siglent's "Counterpart" (I know some members will argue that comparison...  :-//) SDS1000X HD comes with them, and some may remember that the DSA800 series of spectrum analyzers all of a sudden got the 10Hz RBW with a firmware update after the SSA3000X appeared on the scene... And come on, repair the FFT windows functions, and what about a temperature-controlled fan? All the required hardware is there already.
Time lacked for more in-depth testing of the new frmware, but as yet it doesn't appear to be a game changer...unfortunately. At least, Rigol is still supporting the series.
« Last Edit: June 21, 2024, 05:35:50 pm by TurboTom »
The following users thanked this post: sorenkir, egonotto, the Chris
Offline Tom620
« Reply #1231 on: June 23, 2024, 01:07:17 pm »
Also upgraded without any problem. Extra options are still there. Had to re-apply the fan-mod.
Offline Frunse
« Reply #1232 on: June 24, 2024, 09:48:22 am »
Hello, nice to read this,
I am also interested in Audio Elektronics and used the Rigol DS1054Z (Hacked) so far.
For Decoding i have an 34Channel Logic Analyzer https://www.pctestinstruments.com/deutsch/
And the Software is much better to use than on Scops so no MSO Needed.
I was comparing DHO1074 against the SDS1104XHD and ordered me, @ the End, the DHO1074 because of the better Price Performance Ratio on Analogue Representation.
@Saelig
DHO1074                 900$
SDSSDS1104XHD   1399$
DHO1074 Has HDMI Out and better Screen resolution, also the 10MHz Clock Syncronisation capability (SDS1104XHD dont has it @all) becomes Handy with the Sigllent SDG2000X for Syncronisation
(My Eyes will not become better on my Age so i like big Screens ;) )
The only thing i would miss is the BodePlot ability but not for the Cost off Performance.
The Sinalgenerator for SDS1104XHD cost extra Money (165€) so not realy comperable.
The Logic Analyzer kost also additional 342€ for 16 Channel!
The Intronix has 34 Channel and cost 490$ .
Timing-Modus, Sampling-Rate: 1KHz to 500MHz (interne LogicPort Clock)
State-Modus, Sampling-Rate: 0 to 200MHz (Clock-Signal from DUT)
Sample-Puffer: 34 x 2048 Samples (Datakompression: 2^33 to 1 (Sample-Rate up to 200MHz))
Interpreter: see Attachment!
Now i need to wait to get the Sope delivered.
Robert
« Last Edit: June 25, 2024, 10:42:49 am by Frunse »
Offline TurboTom
« Reply #1233 on: June 24, 2024, 12:30:50 pm »
I really like the smooth waveform display on these scopes, especially when playing with memory depth and multiple, overlaying scans, combined with the really good resolution of the display. It's a shame that Siglent apparently didn't do better with their pixel-doubling on the SDS1000XHD. At lest, that's something that Rigol got pretty much right with their entry-level high resolution scopes...  :D
Definitely a decent choice for audio electronics!
Offline skander36
« Reply #1234 on: June 24, 2024, 02:30:09 pm »
This rubbish called "pixel doubling" by some peoples is a smoothing technique used by all manufacturers(including Rigol on DHO1K) to display a moving wave (pic1). In stop mode where wave is unmoved it is not visible. Not all people zoom on screenshots to search for double/triple /quadruple pixels :)
The thing that add an unpleasant effect on Siglent scopes (in particular on SDS1KHD) is the stair effect, remembering about 8 bit scopes (pic2).
For audio electronics I will choose Siglent first, because of it's Bode plot capabilities. It can use two channels to analyze and generate Bode plots simultaneous on both channels on a stereo system (pic3).
That combined with it's easy zoom function to help observing low signals make him the preferred choice for audio.
I have both scopes and I like them both ...
The following users thanked this post: egonotto, TurboTom
Offline hpw
« Reply #1235 on: June 24, 2024, 02:47:54 pm »
HDO4000 looks for Audio nice ... BUT  :palm:
- 2 years old DSO
- FW maintenance cycles a about 6 month
- Only 1M FFT
- Only Flat Top as for 16 bit this is a low performing FFT Window, as may OK for 8..12 Bits
- No dt/d math function as LeCroy & Siglent... and ??
- unknown, white background as using print screen background, as like to print later on. Or to use transparency 0% ??
- 250M to as max 500M memory
- unknown Jitter figures on reference & in case of used external 10MHz reference
Good:
- 100uV/div as lowest scale
- 16uV lowest noise may seen as lowest value on DSO entry market
the question rises, as 2 years old design, any newer DSO in pipeline?
Hp
Offline zrq
« Reply #1236 on: June 24, 2024, 05:34:30 pm »
Note that the possibility to hack a DHO1000 for the 50 Ohm input (only for ranges <=100 mV/div and with some offset issues), all software features on DHO4000 and >500 MHz BW has been proven on my 1074. Although I still couldn't find a perfect solution to the 50 Ohm input that gets me the correct gain for the 200 and 500 mV/div range .
Offline David Hess
  • DavidH
« Reply #1237 on: June 24, 2024, 05:58:25 pm »
16 microvolts RMS on a 800 MHz 1 megohm input?  Not a chance, and Dave's video showed much higher noise, although not as high as I would have expected.  Dave's video also showed that the ground input coupling selection does not ground the input buffer, so the noise measurement with ground coupling is useless.
Did anybody investigate the noise claim?
Offline egonotto
« Reply #1238 on: June 24, 2024, 07:17:51 pm »
Hello,
Quote from: hpw on Today at 02:47:54 pm:
"- 16uV lowest noise may seen as lowest value on DSO entry market"
As far as I can remember, this was with 20 MHz bandwidth and a 50 Ohm terminator at the input. With a newer firmware the noise is about 22 uV RMS
Best regards
egonotto
Offline Frunse
« Reply #1239 on: June 25, 2024, 09:59:34 am »
"For audio electronics I will choose Siglent first, because of it's Bode plot capabilities. It can use two channels to analyze and generate Bode plots simultaneous on both channels on a stereo system (pic3)."
This was my only Concern, i wisch i had this on Rigol too but i have an QuantAsylum 403 Analyzer for Audio Spectrum to do great Graphs and FFT.
And for Higher Frequencies I have the little TinySA Ultra but not realy used it much till now.
I am not realy after Radiofrequencies but to watch sometimes the Wlan Channel / Frequencies used, or the Spectrum from an Switched Powersupply (EMV) is a nice Feature ;)
So the Noise and the other Stuff i mentioned before took me to "Dark" Rigol Side also the Possabillity to hack this thing easey ;)
The DS1054Z tooks also long time to get an neare bugfree Firmware so lets look wat Rigol will do in the Future with this Thing "feel the Force Rigol, it will be on youre Side"
The Hardware seems Descend on this Thing only Software seems to be abit behind on some edges.
I will find it out if i got the Scope on Friday ;)
I am an Hobbyist and need to watch my Money so 900$ was much Money for me. And dont want to go higher. \o/
The Rigol 924 and Lower Versions have to little Displays for my Eyes ;) and only 1,25 Gs on one Channel so on 4 Channels not much Left right? like on DS1054Z!
For the Pricepoint i was long time happy with this little Puppy :)
Robert
« Last Edit: June 25, 2024, 10:36:52 am by Frunse »
The following users thanked this post: egonotto, vokars
Offline skander36
« Reply #1240 on: June 25, 2024, 10:23:29 am »
Yes, QuantAsylum 403 Analyzer for Audio Spectrum is a better tool for audio than an oscilloscope.
Robert
Indeed for me 7" and 8 bit is a no go from now.
Offline Frunse
« Reply #1241 on: June 29, 2024, 02:16:47 pm »
Got the DHO1000 Scope from Saelig @ Friday.
so far i am happy with it.
Did Firmwareupdate to the newest 00.02.13.00.07
Also the Hack applyied, works realy well.
BW -3dB @330MHz and still @ 500MHz the Signal dont look to bad.
Signal was from TINY SA Ultra 500MHz Sinewave @ 70mvpp.
For an bought 70MHz Scope not bad @ all ;)
For now the only Bug i got was with Web Controll.
The Scope Window change every some Minutes back to Start Window if i changed the Windows size off DHO1000.
May be an Firefox Problem??? Has anyone else the same Problem?? with other Web Browser?
The same Problem with Microsoft EDGE Webbrowser.
Got me also the Noctua 60mm Fans for Silent Upgrade but will do it after some Time Using the Scope.
The orig. are hearable but not realy bad sounding @ all.
2024.07.04
Installed the Noctua 60x25mm 12DC Fan's and now more silence with more Air is moving if i feel it right.
Original only 60x15 Fans.
I am Happy with it ;)
The Probes ar not adequate for the 330MHz -3dB now but i will buy this next Month or so:
Sensepeek 6026 PCBite 2x SQ500 Set
https://www.batronix.com/versand/messtechnik/platinenhalter/sensepeek/6026-PCBite-kit-SQ500.html
With additional 2 SQ500 Probes
Robert
« Last Edit: July 05, 2024, 10:02:04 am by Frunse »
Offline vokars
« Reply #1242 on: July 10, 2024, 08:08:40 am »
""For audio electronics I will choose Siglent first, because of it's Bode plot capabilities. It can use two channels to analyze and generate Bode plots simultaneous on both channels on a stereo system (pic3)."
This was my only Concern, i wisch i had this on Rigol too but i have an QuantAsylum 403 Analyzer for Audio Spectrum to do great Graphs and FFT. "
Another option that I am using for free for the frequency response / Bode plot is python scripting / pyvisa for that. The remote scpi interface of the Rigol DHO1000 works fine and is well specified. At the moment I am using a sweep, download the 2 measurement channels (channel A direct from the signal generator, channel B from DUT) from the scope, and then FFT the B/A ratio.
But a simple scan via scpi remote interface like that done by all of these embedded Bode plot implementations on other scopes would also be an option. By the way: Siglent Bode's plots seem to be rather slow.
Offline Frunse
« Reply #1243 on: July 10, 2024, 10:05:30 am »
Hi, thats sounds good and very interesting.
I never worked with Python right now so i need to look into it i guess.
I have an Siglent SDG2042X (Hacked to 120MHz) with LAN and USB, may be this both Devices could worked together with Pyton.
For Bode Plotting.
Found this as an Starting Point ;)
https://www.siglenteu.com/application-note/programming-example-sdg-waveform-creation-with-python-and-sockets-no-visa/
https://www.siglenteu.com/application-note/programming-example-create-a-stair-step-waveform-using-python-and-pyvisa-using-lan/
I know there is on Githup something like this for the older Rigol DS1054Z Oszilloskopes need to look in to that too.
https://github.com/jbtronics/DS1054_BodePlotter
Would be realy nice.
https://github.com/python-control/python-control this seems also for that Kind of using ;)
https://staff.fnwi.uva.nl/r.vandenboomgaard/SP20162017/Python/bodeplots.html
Need to check that.
Again something new i need to learn ;)
Probably the Pythonscript could also easely used on an Raspberry 5 i guess with an touch Display.
« Last Edit: July 10, 2024, 10:32:53 am by Frunse »
Offline vokars
« Reply #1244 on: July 10, 2024, 07:50:20 pm »
"Need to check that."
I am using the toolchain NI Visa + Anaconda + Pyvisa
https://www.ni.com/de/support/downloads/drivers/download.ni-visa.html
https://www.anaconda.com/download
https://pypi.org/project/PyVISA/
https://tw.rigol.com/tw/Images/DHO10004000_ProgrammingGuide_EN_tcm17-5395.pdf
from Anaconda Prompt type: jupyter notebook
That starts the jupyter server and opens a navigation page in the web browser. There you can load existing or create new notebooks. A notebook has cells that can include python code. With shift + enter the code can be executed.
typical start is:
import pyvisa
import matplotlib.pyplot as plt
rm = pyvisa.ResourceManager()
print(rm)
print(rm.list_resources())
scope=rm.open_resource(<your scope visa id string>)
scope.read_termination = '\n'
print(scope.query('*IDN?'))
Now you can query the scope using SCPI command strings as described in the Rigol Programming Guide.
Note that for query waveforms in raw mode the auto trigger must be stopped first. To check, wether the scope actually has stopped, you can poll with :TRIGger:STATus?
« Last Edit: July 10, 2024, 07:58:27 pm by vokars »
Offline Frunse
« Reply #1245 on: July 11, 2024, 08:15:29 am »
Very Nice and thanks alot :)
I will try it by sure.
Robert
Installed all.
But already the first Command don't Work :(
import pyvisa
ModuleNotFoundError                       Traceback (most recent call last)
Cell In[4], line 1
----> 1 import pyvisa
ModuleNotFoundError: No module named 'pyvisa'
Also tried this:
import PyVISA
Same Error:
Not sure why
I am Installed all on C: with the Default Values the Installation Rutine gave me....
Installed Python 3 than Anaconda and as last NI_VISA all on C:
Jupiter starts and i open an Notebook session but it wont't work :(
So not sure whats going on
Also this way i Checked it:
(base) C:\WINDOWS\system32>py -m pip install --upgrade pip setuptools wheel
Requirement already satisfied: pip in c:\users\frunse\appdata\local\programs\python\python312\lib\site-packages (24.1.2)
Requirement already satisfied: setuptools in c:\users\frunse\appdata\local\programs\python\python312\lib\site-packages (70.3.0)
Requirement already satisfied: wheel in c:\users\frunse\appdata\local\programs\python\python312\lib\site-packages (0.43.0)
(base) C:\WINDOWS\system32>py -m pip install PyVISA
Requirement already satisfied: PyVISA in c:\users\frunse\appdata\local\programs\python\python312\lib\site-packages (1.14.1)
Requirement already satisfied: typing-extensions in c:\users\frunse\appdata\local\programs\python\python312\lib\site-packages (from PyVISA) (4.12.2)
May be something is wrong with the PATH Variable on Windows ???
Found Help need to instal pyvisa this way on Conda Shell:
conda install -c conda-forge pyvisa
Now it looks like this but something didn't work also no massages whats going on here??? See attached picture.
Anaconda Shell tells that!!!
[I 2024-07-11 13:32:00.389 ServerApp] Connecting to kernel d89653e5-2b7f-4a61-a3fc-ac3fdfc1d611.
[I 2024-07-11 13:32:00.389 ServerApp] Restoring connection for d89653e5-2b7f-4a61-a3fc-ac3fdfc1d611:70119777-695e-4c42-bc23-ee2fd58194cb
0.00s - Debugger warning: It seems that frozen modules are being used, which may
0.00s - make the debugger miss breakpoints. Please pass -Xfrozen_modules=off
0.00s - to python to disable frozen modules.
0.00s - Note: Debugging will proceed. Set PYDEVD_DISABLE_FILE_VALIDATION=1 to disable this validation.
It seems realy slow here now i gott all Informations and it works like suggested!
So Kommunication with Generator works also ;)
generator=rm.open_resource('TCPIP0::192.168.0.103::INSTR')
generator.read_termination = '\n'
print(generator.query('*IDN?'))
Got this:
Siglent Technologies,SDG2122X,0123456789,2.01.01.38R4
If i am right i need to do this next:
Commands for Generator to start an sweep between Start and Stop Frequencies with @ specified Voltage
Commands for Scope to get the recordet Values from SCOPE ADC after DUT (Filter or anything like this) on specified Channel (Triggering ?)
Commands to Plot an Graph from transfered Values.
Easy ....LOL ....NOT Realy ;)
Colected some Commands that works so far with my Generator as Example:
Preparation for Sweeping Wave:
generator.write('C1:SWWV STATE,ON')
generator.write('C1:SWWV TIME,30S')
generator.write('C1:SWWV STOP,20000HZ')
generator.write('C1:SWWV START,20HZ')
generator.write('C1:SWWV CARR,AMP,0.5V')
generator.write('C1:SWWV CARR,OFST,0.1V')
generator.write('C1:SWWV CARR,PHSE,20')
generator.write('C1:SWWV STATE,OFF')
Output Aktivation Settings:
generator.write('C1:OUTP LOAD,50')
generator.write('C1:OUTP ON')
generator.write('C1:OUTP OFF')
Bassis Wave Command:
generator.write('C1:BSWV MAX_OUTPUT_AMP,2')
More next days ;)
Robert
« Last Edit: July 11, 2024, 05:44:55 pm by Frunse »
Offline zrq
« Reply #1246 on: July 11, 2024, 08:40:13 pm »
Noise of a hacked DHO1000 (actual bandwith conservatively estimated to be >500 MHz) with input terminated with 50Ohm. Note that in the one with 500 uV/div, the scope seems to apply a 250 MHz bandwidth limit which can not be disabled.
And DSOX3034T at work for comparsion (forgot turning off 50 Ohm though).
« Last Edit: July 11, 2024, 08:46:38 pm by zrq »
Offline vokars
« Reply #1247 on: July 12, 2024, 06:27:38 pm »
"More next days" ;)
I have created a simple Bode Plot script blueprint. Is a starting point and can be modified for personal needs:
# Script Initialization
import pyvisa, time, math
import numpy as np
import matplotlib.animation as animation
%matplotlib inline
#%matplotlib notebook
print(rm)
fg=rm.open_resource(<Your function generator VISA string here>)
fg.read_termination = '\n' # See programming manual for your function generator
print(fg.query('*IDN?'))
scope=rm.open_resource(<Your scope VISA string here>)
# Bodeplot Scan Method
# Only 1 channel. Final version should use a ref channel from the function generator without DUT and substract the log amp.
# If you wanna see the progress live, use Python animation framework
# For test run without DUT but just 1 channel function generator uncomment the function generator amp model creation
# ********** Config ***********
gl_points_per_decade = 2.0
gl_decade_start_log = 2 # Min 2, otherwise Autoset unstable
gl_decade_stop_log = 7.2
y_axis_is_dB = False # choose between dB or vpp y axis scaling here
lc_f_log = gl_decade_start_log
f_log_list = []
dB_list = []
vpp_list = []
scope.timeout = 5000
fg.timeout = 5000
scope.write("*WAI;:MEASure:ITEM VPP,CHANnel1")
scope.write("*WAI;:MEASure:STATistic:RESet")
# Loop: Set function generator frequency and measure amp with scope
while lc_f_log <= gl_decade_stop_log:
    lc_f_Hz = pow(10.0, lc_f_log)
    # function generator set frequency
    lc_str = "SOURce1:FREQuency " + str(lc_f_Hz) # for Tektronix AFG 3022B; exchange if other function generator
    fg.write(lc_str)
    # time.sleep(1.0) # Settlement Time for function generator
    fg.query("*OPC?")
    # Only Test
    # Function Generator emulates DUT, use comments for real DUT
    lc_amp = 5.0/lc_f_log # Model
    #lc_amp = 5.0 * (gl_decade_stop_log + 0.5 - lc_f_log) / (gl_decade_stop_log - gl_decade_start_log)
    lc_str = str(lc_amp)
    #print(str(round(lc_amp,2)))
    lc_str = "SOURce1:VOLTage:LEVel:IMMediate:AMPLitude " + lc_str
    fg.write(lc_str)
    #time.sleep(1.0) # Settlement Time for function generator
    fg.query("*OPC?")
    scope.write(":AUToset")
    # scope.query("*OPC?") # Not working: ToDo Rigol Firmware Update
    time.sleep(3.0) # Workaround that wastes time. Would be better to query if Autoset is ready. Change value if read errors occur
    # scope measure amp
    # ToDo: Average instead of current value for higher precision. In this case increase sleep for settlement
    lc_vpp = float( (scope.query(":MEASure:STATistic:ITEM? CURR,VPP,CHANnel1")).strip() )
    # store log f
    if lc_vpp < 1E3: # check for read errors
        f_log_list.append(lc_f_log)
        vpp_list.append(lc_vpp)
        dB_list.append(20.0 * math.log10(lc_vpp))
        print("*", end="")
    else:
        print("!", end="")
    lc_f_log += 1.0/gl_points_per_decade
# Show result
print()
plt.title("Bode Plot", fontsize=14, pad=12)
plt.xlabel("log(f) / log Hz")
plt.grid()
if y_axis_is_dB:
    plt.ylabel("dB Vpp") # With second Ref channel this becomes real frequency dependend attenuation
    plt.plot(f_log_list, dB_list)
else:
    plt.ylabel("Vpp / V")
    plt.plot(f_log_list, vpp_list)
plt.show()
« Last Edit: July 13, 2024, 09:45:56 pm by vokars »
The following users thanked this post: egonotto, thm_w, Frunse, skander36, core
Offline skander36
« Reply #1248 on: July 13, 2024, 07:30:12 am »
Congratulations for your work!
With DHO1000XHD and SDG2000X the script work in the limits you mentioned.
The command "%matplotlib inline"  is not working on mine(SyntaxError: invalid syntax). Need to be commented for the script to run. I'm running the latest version of Python.
« Last Edit: July 13, 2024, 07:58:30 am by skander36 »
Offline Frunse
« Reply #1249 on: July 13, 2024, 08:43:47 am »
Hello and thanks,
Yeah thats will help a lot!!!
I got yesterday my DSLogic U3Pro32 so i was playing with it around. Big Problem is my Computer is on  the other Side of my little room and the USB3 Connection is realy Short.
An 5 Meter USB3 Kabel was not working (LA was only in USB 2 Mode recogmnised) so i need to rethink / Rework my little Lab LOL
Also need to Settup all Ethernetconnection for my Measument devices for Remotecontrol ;) Neare all new Equipment has Ethernet  LOL .
Now i will check youre Script.
Dude, that would took me half a  year to get such a scrpit running i guess ;) But i never give up  .....LOL
My little Main Project right now (Picture attached) ;)
Robert
« Last Edit: July 13, 2024, 08:59:31 am by Frunse »
