Author Topic: Rigol Image Burn (DP832A Triple Power Supply)  (Read 970 times)
Offline DA-N-NYTopic starter
« on: June 08, 2023, 01:55:20 am »
I just received a used DP832A that supposedly was in "Good Condition" but has significant screen burn in.  See pic below.  It was calibrated in summer of 22.  Just a bit older than a new DP832A I already had (based on serial number).  The burn-in is pretty significant and is of the "Normal" display option.  I use the "Classic" display.   I also noticed a constant white wash flicker.  It's bad regardless of display settings (brightness, contrast etc) and included a pic against my newer one with the same settings.  However, even looking closer at my new one, it looks like it is starting to suffer the same issue.  I wonder if anyone experienced a similar problem with their equipment?  I have mostly Siglent of which get a lot more use and have not noticed any burn in.
Edit:  The burnin issue is the second pic.
Edit 2: I added another pic to show how washed out it looks from the top (but page displays the same thumbnail???) So you may have to click to view it correctly.
« Last Edit: June 08, 2023, 02:19:05 am by DA-N-NY »
Offline Fungus
Re: Rigol Image Burn (DP832A Triple Power Supply)
« Reply #1 on: June 08, 2023, 02:35:00 am »
Looks like they used an OLED screen in which case there's not much you can do except replace it.
Online RoGeorge
« Reply #2 on: June 08, 2023, 07:47:57 am »
That's a defective LCD, maybe a bad contact somewhere, the image shouldn't look like an interlaced TV raster.  If that's only remaining burns shadow, I think there is a screen saver feature, but I never used it.  Mine doesn't show any remnant shadows, though it's used only rarely, for hobby projects, was never left on for more than a few days continuously.
« Last Edit: June 08, 2023, 07:54:54 am by RoGeorge »
Offline tooki
« Reply #3 on: June 08, 2023, 09:01:36 am »
LOL no.
« Reply #4 on: June 08, 2023, 02:48:50 pm »
The shadow burn is the screen from the last user that used "Normal" mode for display.  It's now burned in regardless of what is displayed.  I am seeing my newer Rigol unit is starting to do the same after only maybe 50-100 hours of use.  It's subtle and you would not see it unless you look for it.  But given that the "burn in" is already started, I assume that it will get worse to the point of the used but "very good" condition of the other Rigol.  Yes it has a screen saver and I just enabled it across all my Rigol equipment.  I see it on the two DP832A's (one very faintly) but not on the DP821A or the DL3021 yet, although they should have more hours of use.
Offline Fungus
« Reply #5 on: June 08, 2023, 03:56:23 pm »
LOL no.
So what's your helpful explanation/fix?
Offline Fungus
« Reply #6 on: June 08, 2023, 04:02:15 pm »
Yep, that much is obvious.
If it's an LCD then it might fix itself with time. The usual trick is to "exercise" the pixels by alternating between full white/full black for a while but that's going to be difficult to do on a power supply.
The other option is to take it apart and look for a part number on the back of the screen. Google that number.
Yep. If it's "interlaced" then there's probably a bad cable or bad contact somewhere. Take the lid off and press/wiggle things.
Online bdunham7
« Reply #7 on: June 08, 2023, 04:53:44 pm »
Burned in OLED or AMOLED screens (like my old Samsung Galaxy AMOLED phone) will be inverse images since the most-used OLED elements become dimmer.  What is shown is some sort of LCD persistence, along with a pretty bad looking screen.  Ordinarily I'd expect that to go away if you turned the unit off overnight.  If it persists long term, my guess would be that Rigol used a particularly crappy LCD panel, which would be really annoying since it is pretty obvious how it is going to be used.
« Reply #8 on: June 09, 2023, 05:16:07 am »
While the pictures I took could not capture all the issues, I am observing three as follows
1) The burned in (Ghosting of) the "Normal" interface page.
2) Very washed out display.
3) Screen flicker which is hard to capture on camera.
Think I will just return it to Amazon at this point.
Offline tooki
« Reply #9 on: June 09, 2023, 09:08:25 pm »
LOL no.
I don’t have one.
But unlike you I didn’t add misinformation, which is worse than adding nothing at all.
