Author Topic: Waveform characterization using an oscilloscope vs a DC source  (Read 1806 times)
Offline SharpEars
« on: October 13, 2015, 05:29:24 pm »
Some of the more expensive DC sources (e.g., Keysight 66312A, 66319B/D, 66321B/D) can perform waveform characterizations with 2048-4096 data points and voltage/current measurements and less than a 50 uS sample rate. I am wondering if there are any advantages to using them vs a cheaper DC source and a decent oscilloscope?
In other words, these sources seem to combine oscilloscope functionality with a power supply, if I understand how they work properly. However, is there some killer feature that they offer that cannot be accomplished using a cheaper source and a scope?
Online Marco
Re: Waveform characterization using an oscilloscope vs a DC source
« Reply #1 on: October 13, 2015, 05:54:16 pm »
They can put a current measurement shunt above a MOSFET pass element so it has no burden voltage, can't do that with your scope.
Offline SharpEars
« Reply #2 on: October 13, 2015, 06:08:39 pm »
So if I wire a low resistance current shunt in series with the device under test, which will be bypassed for purposes of voltage measurement/regulation due to the sense wires that will be connected to the device under test, I will not get the same effect?
Online Marco
« Reply #3 on: October 13, 2015, 06:17:32 pm »
Yeah, if your power supply has a sense wire my argument is wrong in retrospect.
Offline SharpEars
« Reply #4 on: October 13, 2015, 07:45:28 pm »
So it seems like these expensive mobile test sources have no advantages at all, except for perhaps very fast transient response to changing loads?
Offline Someone
« Reply #5 on: October 13, 2015, 10:29:20 pm »
You could end up paying more for a current probe than the power supply to make the same measurement, the other value in these power supplies are their fast transient responses.
