The two waveform-sheets for DG800PRO & 900PRO series.
With the UI bug that NE666 found #234 - you can go way above what the DG800PRO & DG900PRO series otherwise present as limits on most of the other waveforms, incl. the arb-portfolio of inbuilt ones...around 200Mhz seems to be the limit for the arb-catagory that otherwise is limited at 10MHz for 821PRO
Am still on the older fw it arrived with in December 2023 [V01-0.21] so it also works fine there, not sure if it's exactly the same on the later FW2-0.05.
DG800PRO series.
https://static.eleshop.nl/mage/media/downloads/DG800Pro_DataSheet_EN.pdfDG900PRO series.
https://static.eleshop.nl/mage/media/downloads/DG900Pro_DataSheet_EN.pdfTried 40Mhz ramp 20Vpp,and the Ramp is otherwise maxed at just 1MHz for DG821PRO, but its the same for many of the other waveforms that are open for input at way above its official specs, but I'm likely also reaching a ceiling on what my Micsig scope can muster..with its 145Mhz analog bw.. not least at some of the faster-rising waveforms and if its the scope or the sig-gens hardware I'm reaching the limits at.
freq. spot on scope, amplitude down around 17vpp, and symmetry drops.
Arb "Dualtone" 55Mhz so above any of the PRO-model's limits, that on DG821PRO is merely 10MHz..
