Anybody please check DG9XX Pro maximum sample rate!
It's simple:
1) Load the maxFreq.arb in the "cont" mode.
2) Switch from frequency to period setting, set period to 26.2144 µs (38146.97265625 Hz), there should be 312.5 MHz frequency output.
3) Set period to 13.1072 µs (76293.9453125 Hz), there should be 625 MHz frequency output, if generator supports 1.25 GSmpl/s sample rate. If not, there should be slowly drifting voltage output, as the case with my liberated unit.
