Author Topic: Rigol's New Function Generator and DMM: DG800Pro / 900Pro / DM858  (Read 110680 times)
Kurt_! and 3 Guests are viewing this topic.
Offline gbix
  • Country: ru
Re: Rigol's New Function Generator and DMM: DG800Pro / 900Pro / DM858
« Reply #225 on: January 13, 2025, 02:20:04 pm »
The new dg5000 series generator has been released.
With a price of $1700 and an upgrade to the latest version for $5500 with options for $1400, it turns out to be an interesting cheap solution ;)
The following users thanked this post: thm_w, diploe-disciple
Offline Swake
« Reply #226 on: January 13, 2025, 02:41:10 pm »
It has the same optional Li-Ion battery holder as the DHO4000 series. 550€ and it comes without... batteries :wtf:
Will they also bring out black edition as with the 800/900 series?
When it fits stop using the hammer
Offline NE666
« Reply #227 on: January 13, 2025, 02:41:57 pm »
Looks as if they found a way to solve the problem with losing a channel when turning on the frequency counter too  ;)
Offline gbix
  • Country: ru
« Reply #228 on: January 13, 2025, 02:46:54 pm »
yes. it dont have frequency counter  |O :-DD :-DD :-DD
Online DaneLaw
« Reply #229 on: January 13, 2025, 05:01:47 pm »
Hadn't even noticed that the frequency counter was kicked on the bigger brother.
https://www.eevblog.com/forum/testgear/rigol-dg5000-pro-signal-generator/msg5602557/#msg5602557
the DG5000PRO  options include.
IQ modulation, multi-pulse output, multi-tone, pattern, sequence options, ARB length to 128Mpts/CH.
_
DG5000 Pro-IQ
DG5000 Pro-MPUL
DG5000 Pro-MTONE
DG5000 Pro-PJ
DG5000 Pro-SEQ
DG5000 Pro-2RL
https://eleshop.eu/rigol-dg5000-pro-bnd-software-option-bundle.html
Online Kurt_!
  • Country: at
« Reply #230 on: January 13, 2025, 05:22:23 pm »
It's just a cheap addition to the dg800-900.
(maximum 7 places...)
Online DaneLaw
« Reply #231 on: January 13, 2025, 06:12:52 pm »
It tends to be on an entry signal gen but I definitely prefer it over none, and having an aspect of trend plotting.
Cant recall how far up it would play along, but it's like a few gigs with 6 digits.
Offline Benq360
« Reply #232 on: January 13, 2025, 07:34:42 pm »
Hey @gbix,
I’m new here and just got myself a DG821pro (though I haven’t received it yet). I know it can be unlocked, and you’re the master for this 😎.
I can’t PM you yet, but could you PM me to let me know how to unlock when you have a moment?
Big thanks in advance!
Offline thm_w
  • Non-expert
« Reply #233 on: January 13, 2025, 11:19:24 pm »
For anyone else confused about the upgrade instructions, the button does not say "Upgrade" its says "Renew".
   3. Start up, click the "Save" button at the lower right corner of the instrument screen,
       or press the "Save/Recall" button on the right side of the instrument keyboard board to open the storage interface.
       Select the path as "USB Disk (D)", select "AFGUpdate.GEL" in the directory, click the "Update" button in the lower right corner,
       the progress bar will appear on the screen, and the instrument will start to upgrade.
« Last Edit: January 14, 2025, 12:55:26 am by thm_w »
Offline NE666
« Reply #234 on: January 14, 2025, 10:47:14 am »
An observation test. Notice anything unexpected?
Offline Swake
« Reply #235 on: January 14, 2025, 11:33:28 am »
model 822 and pumping the pulse to 50MHz?
and all that stuff says 2023
The following users thanked this post: NE666
Offline NE666
« Reply #236 on: January 14, 2025, 11:45:24 am »
We have our winner  :)
I've not hacked this unit, only applied the new FW. It can be coaxed into exceeding the licensed limits, if you set the desired period when in Gated mode, then switch to Continuous mode.
The following users thanked this post: MarcelMo
Offline Swake
« Reply #237 on: January 14, 2025, 12:00:19 pm »
Had to check on mine (enhanced 821 that now thinks it is a 922, not yet upgraded to last fw) because I was curious how high the pulse would go as it is not something I use frequently. Result confused me as the pulse was limited to 50 MHz. After checking the datasheet, 50 MHz is the limit on all 9xx versions.
Offline MarcelMo
« Reply #238 on: January 18, 2025, 04:22:47 pm »
Thanks,  I managed to get even 200Mhz out of the RG822pro (not hacked either)  :)
The following users thanked this post: thm_w, NE666
Offline NE666
« Reply #239 on: January 19, 2025, 09:27:51 am »
I'll invite anyone to "review my paper" but - in so far as I am able to tell using my MSO5000 (opened up to 350Mhz, but able to trigger and display to at least 1Ghz, sampling at 8Gsa/s with dots mode on not vectors), I think it is also reconstructing at the higher sampling rate of the 9xx series too, when set at these frequencies.
Online DaneLaw
« Reply #240 on: January 19, 2025, 09:14:26 pm »
How did you manage that?
Offline NE666
« Reply #241 on: January 19, 2025, 10:54:37 pm »
Go into Burst mode, set the *period* of the waveform as desired, then revert to Continuous mode. The 'elevated'  frequency setting will be held.
However, if you then try to adjust frequency when back in the Continuous output mode, the license limits will be reasserted.
The following users thanked this post: DaneLaw
Offline probe
« Reply #242 on: January 21, 2025, 07:13:52 am »
....And another DG821 Pro is a tad confused and now thinks it's a DG922 Pro.
Many thanks to @gbix for making this possible (and in less than 2 minutes no less)!
« Last Edit: January 21, 2025, 07:17:35 am by probe »
Offline gorannik
  • Country: hr
« Reply #243 on: January 21, 2025, 04:24:52 pm »
My dg822pro has grown thanks to gbix, I'm a bit confused if everything is working correctly, here are a few pictures so please give your opinion, it's about the voltage drop at higher frequencies. Thanks Goran
I hope I didn't go too far with the pictures
Offline NE666
« Reply #244 on: January 21, 2025, 05:20:05 pm »
I think it has been said before that 'unlocking' these instruments is one thing, actually having them calibrated for flatness of frequency response across that extra working range is another. i.e. they aren't calibrated at the factory for higher frequencies than they are licensed for. If so, then that would be a factor.
Also, at those frequencies, I'd be using a 50ohm termination at the scope.
Offline Frex
« Reply #245 on: January 21, 2025, 06:04:16 pm »
Hello,,
I already reported the output flatness of hacked DG821 Pro
beween 100kHz~200MHz here :
https://www.eevblog.com/forum/testgear/rigol-just-launch-its-new-function-generator-dg800pro-900pro/msg5779245/#msg5779245
I measured less than -1dB amplitude drop max.For "uncalibrated" device, it's very good.
(the official DG992 Pro datasheet say +/-1dB flatness for F>100M).
Note that as NE666 say, to check this you must use 50 Ohms end load,
and use a good coax cable is also very important.
Even at 200MHz, some cables will add many drop more !
Of course too, the use scope bandwidth must be much higher than test frequency.
otherwise you add it's own drop.
Frex
Offline gorannik
  • Country: hr
« Reply #246 on: January 21, 2025, 06:57:14 pm »
I just tried it with 50 ohms, as recommended by NE666, the same thing, it obviously needs calibration, here are a few more pictures where you can see that there is no symmetry between the channels at higher frequencies, maybe someone can solve the calibration, that would be the right thing. The oscilloscope is 200MHz, all in all, it's not bad, at least now I have 200MHz of some kind
Offline Benq360
« Reply #247 on: January 21, 2025, 07:06:16 pm »
Hello,
I’ve just received my DG821Pro and I’d like to unlock the extra options. I saw some mentions that the process is really simple and only takes about 2 minutes.
If anyone has a moment to guide me or share how it’s done, I’d really appreciate it! 😊
Thanks a lot in advance!
Offline gbix
  • Country: ru
« Reply #248 on: January 21, 2025, 10:02:16 pm »
calibration test of dg821pro.
dg821pro after calibration from 100khz to 200mhz.
the rigol mso5000 was used as a meter.
gif file is animated. to view need to download it
Offline TeNQ
  • Country: ru
« Reply #249 on: January 22, 2025, 05:25:57 pm »
Hi @gbix
I’m new here and just got myself a DG821pro. I can’t PM you yet, but could you PM me to let me know if you can help to unlock that device and have time for it.
Thanks,
Andrey.
