It was quicker than I thought, and a huge thank you to Batronix for making it possible—the service is simply sensational.
Now it's here, an MHO984—I had forgotten how small these things are...
This series also comes in good packaging with foam inserts.
The power supply is a Liteon 100W, as with the MHO98 (anything else would have been surprising), the included probes are 500MHz types and look rather cheaply made, and the accessories are also rather sparse.
The most obvious difference is the BNC connectors, which are not gold-plated.
The housing is transparent, which gives it an interesting look.
Not much has changed in terms of connections compared to the DHO800, except for the two generator outputs.
Still only one USB-A port, which is very meager.
I didn't notice a protective film for the display; it actually seems to be that shiny.
Here are a few more pictures; initial measurements and further impressions will likely follow over the weekend.
