What "Standby Mode" is this? I have never seen a standby mode option and checking the last two user manual versions I have to hand give no hint of such an option. The power indicator LED, whilst excessively bright (use of a black marker pen cures this), is completely extinguished when the meter is switched off.
P.S. I forgot to mention that my bench meter is the SDM3065X model. This might explain the difference.
Also, on closer examination of the power button this morning, I see that, despite its emulation of a simple on/off toggle switch like those used by the SDL1020X-E and the SDG2042X, that it is in fact a momentary on/off switch.
Presumably, if there is a later software update available and I upgrade it, I too might experience the pulsating power led effect (although not quite so annoying in my case on account of the black marker pen 'mod')
