Author Topic: Rigol MSO 5000 hardware/software revisions  (Read 78209 times)
Offline skander36
Re: Rigol MSO 5000 hardware/software revisions
« Reply #350 on: June 04, 2020, 11:37:15 am »
It seem that the keyboard input is not accepted. Every keystroke determined closing the form you are trying to fill .
Offline Gandalf_Sr
« Reply #351 on: June 04, 2020, 01:00:04 pm »
I was going to say that I didn't think the MSO5000 supported a keyboard.
If at first you don't succeed, get a bigger hammer
Offline skander36
« Reply #352 on: June 04, 2020, 01:03:52 pm »
Yes, it can spare the keyboard an buy only a mouse. I also use the M185 . It has good battery life .
Offline ve2mrx
« Reply #353 on: June 04, 2020, 01:19:56 pm »
You should try a USB hub?
Martin
Offline skander36
« Reply #354 on: June 04, 2020, 01:50:40 pm »
Martin
No need for keyboard, because it cannot be used with Rigol 5000 .
Offline noreply
« Reply #355 on: June 17, 2020, 11:14:15 am »
Martin
Is 'keyboard & mouse' OFFICIALLY unsupported?
I heard that by using USB hub (system knows there is more than one USB port) a keyboard / mouse can be used??
If there is absolutely no support for K&M, then has anyone tried to install a suitable USB driver for K&M support which is compatible with the Kernel??
You would think that this 'feature' (especially when you are in a lab environment) would have been trivial to implement by RIGOL - so why leave it out  |O
Offline noreply
« Reply #356 on: June 17, 2020, 11:20:41 am »
Martin
OK ...
- I can offically confirm that K&M does indeed work  :clap:
- if USB hub is plugged-in and system is rebooted  :popcorn:
Offline skander36
« Reply #357 on: June 17, 2020, 11:29:27 am »
Martin
Mouse is supported, even plug&play and some of numerical inputs parameters are managed by scroll wheel.
Keyboard is not unsupported but somehow banned in a way that any input from keyboard make the forms that you try to edit to be closed.
That is what I have observed until now, maybe my keyboard is not supported . I'm using wireless kb and mouse.
Offline noreply
« Reply #358 on: June 17, 2020, 11:37:12 am »
Martin
Hmm ...
I can confirm KB works OK
- using email settup form
- perhaps it could be a KB specific issue??
I can also confirm that if USB mouse & keyboard 'wireless dongle' is removed from hub
- it will not remount device once you plug-it-in again
- so definately not full plug and play  :(
Perhaps this is specific to the K220 & M150 logitech devices I have :-\
Offline tv84
  • Country: pt
« Reply #359 on: June 17, 2020, 11:42:39 am »
Shouldn't be as logitech dongles tend to be pretty good in HID compliance.
Maybe Rigol just doesnt implement full plug&pray but nonetheless it seems a nice addition.
Offline noreply
« Reply #360 on: June 17, 2020, 11:43:03 am »
BTW
I just got a new 5074 (Build: 2020-02-26)
Am trying to do a 'step-by-step' hands-on review :)
Will be posting my (notable) 'findings' as I discover them ...
The K&M issue was the first thing I noticed
- I'm glad that it is resolved
- at least we CAN use an external USB K&M :popcorn:
Offline noreply
« Reply #361 on: June 17, 2020, 11:47:16 am »
Yep ...
Exactly my sentimets and I was very surprised when it did not work
After a few calls to Rigol, I got a cryptic answer that K&M is supported via hub (makes sense)
- but it does not 'recognize' hub until you do a reboot
- definately something Rigol can do to fix I hope  :-\
Offline skander36
« Reply #362 on: June 17, 2020, 12:01:41 pm »
It work every time when I remove and plug dongle with my M185/K270. Until last version it was not plug&play. What fw version are you using ?
On email setup the form is indeed accept inputs from keyboard after a short "fight" with a virtual keyboard.
I did not try with hub .
Offline jemangedeslolos
« Reply #363 on: June 17, 2020, 12:12:37 pm »
I tried with my cheap Tecknet mouse and as you had suggested to me, it works very well if the dongle is here before a power on cycle.
So the MSO7000 behave like the 5000.
I always leave the dongle plugged now. It's convenient to have 3 usb ports.
I bought a compact mouse + keyboard set.
it will be more convnient to enter the label for example hoping it works.
Offline noreply
« Reply #364 on: June 17, 2020, 12:21:08 pm »
Because I'm trying to get 'hands-on' (my first Rigol) .. I'm not jumping-in with FW upgrade just yet ...
The device is new - build 2020-02-26, but FW is 00.01.02.00.03
So there definately (he thinks he is correct - but probably not) was 'later' FW available prior to OS build  ::)
But yeah, cannot be definative with anything as yet - perhaps the 00.01.03.00.01 has resolved the K&M / hub P&P issues  :-\
I will get to it soon - but thought to report as i go along  :P
BTW: like the 'black' look - hate the fingerprint & everything static magnet :(
« Last Edit: June 17, 2020, 12:35:12 pm by noreply »
Offline noreply
« Reply #365 on: June 17, 2020, 12:35:49 pm »
Some more observations ...
Screen Brightness - for me its perfect - in room with ambient / low lights
Fan noise - not noticably louder than my Siglent SSA (Now SVA - thanks tv and the group)
Initial fiddle with menu structure is OK
- but don't like the - what appears (because this is totally new to me) not intuative layout
- because I need to think 'where is that menu for the function I want'
The 5074 has no inputs as yet
- nothing to analyze
- after 10 minutes I can feel 'heat' at the rear
- non fan side
- not hot
- just normal
- but quite warm air
- so even in static state
- it does produce some heat
- wonder what will happen during heavy load :-\
Offline ve2mrx
« Reply #366 on: June 17, 2020, 02:10:51 pm »
Just something to watch out for: keyboard layouts! Keyboards send scan codes, not characters!
For this reason, maybe the scope "dislikes" some of the typed-in keys?
Is there a place to set the keyboard layout in the scope?
Offline noreply
« Reply #367 on: June 17, 2020, 05:19:44 pm »
There does not appear to be any configurations relating to Keyboard / Mouse
The OS Kernel simply picks-up the HID device it (should) sees in the USB hub and 'deals with the internal data' as per defined protocols - much like it would in a regular PC
Offline ve2mrx
« Reply #368 on: June 17, 2020, 05:58:13 pm »
Meaning we have no way to match our typing expectations to the scope's actual character selection?
What layout is set in the scope's linux? For some reason, I expect En-US...
Martin
Offline noreply
« Reply #369 on: June 17, 2020, 10:44:02 pm »
I can now OFFICIALLY confirm that with the latest FW - 00.01.03.00.01 (build 2020-03-30)
The USB port - without hub - fully supports the Logitech MK220 wireless mouse / keyboard combo.
This KB / Mouse is very compact (minimalistic design - see image) and is 'black' in colour - so goes well with the MSO5000  :-+
Also in the UK can get at < GBP20 ;)
BTW
Regarding keyboard layout
- my version is UK / US
- so most likely En-US
Offline Gandalf_Sr
« Reply #370 on: June 18, 2020, 09:40:57 am »
I have a Logitech M185 mouse that works well but only on the front Type A USB port; has anyone made a mouse work from the rear Type B port?  I bought a B to A USB adapter and it didn't work with the Logitech dongle.
Offline aristarchus
« Reply #371 on: June 18, 2020, 10:16:15 am »
Isnt the rear one a "USB DEVICE Interface" ?
I guess it is not host, so it is used only to connect the oscope to your PC as a device.
The following users thanked this post: Gandalf_Sr
Offline luma
« Reply #372 on: June 18, 2020, 01:04:37 pm »
That's correct - front USB A port is a USB host, meaning it can have devices plugged into it and control them as normal.  Rear USB B is USB device, meaning it can be plugged into a host for remote control of the scope.  If you need more USB A ports to connect additinal devices, use a hub connected to the front port.
« Last Edit: June 18, 2020, 03:49:23 pm by luma »
Offline Gandalf_Sr
« Reply #373 on: June 18, 2020, 01:06:13 pm »
Isn't the rear one a "USB DEVICE Interface" ?
I think you're right, not being a USB expert, the idea that it is only a 'device' totally escaped my feeble mind.  Anyway, the slight irritation is that, if the front USB port is used for a mouse dongle, then there's no USB port available to run a USB drive to save screen captures to - unless you run a hub.
Offline Gandalf_Sr
« Reply #374 on: June 18, 2020, 02:10:27 pm »
So, a hub seems like a good purchase.  Can anyone confirm what works with the MSO5000?  I think it's USB 2.0 and wondered if this one from Amazon would do?
