Author Topic: Rigol MSO1074Plus vertical issue  (Read 1474 times)
Offline ProfesszoreTopic starter
  • Country: hu
  • Measure twice, then check calibration.
« on: June 01, 2018, 09:46:22 am »
Dear All,
Recently I've experienced an unusual behaviour on my Rigol MSO1074Plus Scope. A set of very basic settings, two measurements have been done one after another. First is at 500mV/div vertical and the second with 1V/div vertical. It is clearly visible that the second measurement is completely useless and lacks anything important for debugging/inspection. I experience the same with anything over 1 V/div setting. I've also tried many other settings (timebase, Display, Acquisition etc.). Same is true for all four channels with all available probes.
All hints are welcome and highly appreciated. Thanks in advance!
Yours Sincerely,
Tamás
Re: Rigol MSO1074Plus vertical issue
« Reply #1 on: June 01, 2018, 09:55:20 am »
Oh no not another one !
It's normal.
Your waveform must be completely on the display, or within the max offset listed in the scope specs.
The channel 1 0V level indicator pointing down shows the level is clearly off the display.
Get it back onto the display and normal programming will return.  ;)
Avid Rabid Hobbyist
Offline JPortici
« Reply #2 on: June 01, 2018, 10:05:54 am »
suggestion for the siglent development team: add an OVERLOAD label in future models (or updates, if they have a way to detect the condition)
  • Country: hu
« Reply #3 on: June 01, 2018, 10:41:17 am »
Thanks for the suggestion!
Done it, please, take a look at the results!
Ch1 (yellow) completely on the screen, 0 V offset, 5V/div.
Ch2 (blue) -12 V offset, 200mV/div.
Specs: max offsets at 1× probe ratio are
+/-2 V from 1 mV/div to 499 mV/div,
+/- 100 V from 500 mV to 100 V/div.
Ch1 is within the accepted maximum offset (no offset) and shows corrupt waveform,
Ch2 is way off the maximum accepted offset and shows the expected waveform.
I am slightly confused.
Online 2N3055
  • Country: hr
« Reply #4 on: June 01, 2018, 10:39:50 pm »
No, CH1 is within specifications and shows GOOD waveform.
CH2 shows scope's input chanel overdrive recovery oscilations...
That 2V pulse would be visible on CH1 if existed....
Suggestion for ALL SCOPE manufacturers....  :-+
Offline CustomEngineerer
« Reply #5 on: June 02, 2018, 12:21:36 am »
https://www.eevblog.com/forum/testgear/siglent-technical-support-join-in-eevblog/msg1531802/#msg1531802
Excellent explanation of what can happen when you overdrive the inputs on a scope by forum member Performa01
The following users thanked this post: Professzore
