I am in the market for a general purpose DMM. I originally considered BK Precesion 2709B, but after more research I'm considering buying an Amprobe to get the extra protection of the Cat III / Cat IV rating (though my uses should seldom put me in a position to require that protection).
I've read quite a bit here on the AM-270, but there is really no info out there on the relatively new AM-570. The AM-570 has a few features and ranges the AM-270 doesn't: slightly higher count, frequency measurement to 66 MHz, capacitance to 60 mF, duty cycle measurement. The AM-270s main claim to fame is its accuracy that trounces the AM-570 in almost all cases, and a good design based on a tear-down here.
Based on what I've read here, I suspect that the AM-270 is the reccomended choice. Should I even be considering the AM-570? Any info to push me towards (or away) from the AM-570 would be appreciated. (Or you all can tell me to stick with the BK.)
