Author Topic: Rigol MSO5000 - Custom Label for Parallel Decode Bus?  (Read 603 times)
Offline meener777Topic starter
« on: August 03, 2022, 05:29:04 pm »
Hey all, I have a Rigol MSO5000 scope and I am trying to decode some digital information using two parallel busses. I would like to label them so instead of Parallel 1 and Parallel 2 they would say e.g. Row, Column (this is a 41416 ram chip, I am looking at address info coming in). Labelling LA lines is easy to find but I cant seem to find any way to customize the labels for the decode lines. Anyone happen to know how to do that?
Offline Marko56
Re: Rigol MSO5000 - Custom Label for Parallel Decode Bus?
« Reply #1 on: August 07, 2022, 08:21:56 pm »
With LA on select Label (above More) -> select Display-ON. Select the Data Line(D0-15) and select Label. Keyboard will come up and you can set Label name
« Last Edit: August 07, 2022, 08:26:49 pm by Marko56 »
Offline Kean
    • Kean Electronics
« Reply #2 on: August 08, 2022, 02:21:37 pm »
OP wants to change the label on a parallel decode, not on a single data line.
I had a look and cannot find any way to do that on my MSO5000, while it is possible on my RTB2000 >:D
