Author Topic: Rigol MSO5074 vs DHO914s  (Read 9476 times)
Offline franciscoPTTopic starter
  • Country: pt
« on: September 09, 2023, 04:02:40 pm »
Hi, i want to buy a new scope, the one i have right now is a 2ch Hantek, i was looking the models MSO5074 and the new DHO914s, both from rigol, and for me it seems that the only advantages in the DHO914s are the 12bit resolution and the price of course, i need some advices to make my choice, is the 12bit so much better that is worth to give up in other features?
Online Fungus
Re: Rigol MSO5074 vs DHO914s
« Reply #1 on: September 09, 2023, 04:16:38 pm »
That depends on what you're going to use it for.
Online Martin72
  • Testfield Technician
« Reply #2 on: September 09, 2023, 08:24:02 pm »
This question in itself is worth becoming a topic of its own.
Currently there is a lot of hype about the 12 bit, especially with cheap scopes.
Fungus has already said it, it depends on what you want to measure, where your focus is.
To your actual question...
I had the MSO5074 over a year in use, also I had a DHO4204 to test here.
I assume that the software is the same for all Rigol 12 bit scopes, at least it would be strange if not.
Therefore, I dare to say that if you do not need 12 bit (native, because the MSO5074 has 12 bit as Hi-Res mode) and if you do not mind a somewhat dusty UI, the MSO5074 offers div. advantages.
Larger screen, larger bandwidth, more memory, max. 8GSa/s, 2-channel AWG, better FFT, etc., etc....
The biggest disadvantage is the front end noise of the MSO5074, but that only plays a role if you want to evaluate very small signals.
However, I don't think the scope will be really taken care of now that the new 12 bit models are out..
The following users thanked this post: franciscoPT
Offline moffy
« Reply #3 on: September 10, 2023, 12:52:49 am »
Two advantages for the DHO914 that I like are:
1. Built in battery support with USB-C power port, making it very portable.
2. If you want to do PC logging and maybe FFTs on the PC the 12 bit is going to help.
Offline mwb1100
« Reply #4 on: September 10, 2023, 04:06:15 am »
However, I don't think the scope [MSO5000?] will be really taken care of now that the new 12 bit models are out..
You mean they won't be updating firmware or something else?  Is there still much that needs fixed in the MSO5000 firmware?
  • Country: pt
« Reply #5 on: September 10, 2023, 10:15:02 am »
Thats 1 of my concerns, the mso5074 seems that still need to be polish, hope rigol still keep updating it.
Offline NE666
« Reply #6 on: September 10, 2023, 11:18:38 am »
Any/either model is a concern, when it comes to Rigol and their software "management" process.  You, like myself and others, have to / have had to make the decision whether or not to temper that risk against possible rewards, including the price point.
Only time will tell and certainly, the new software architecture demonstrated in the DHO series will likely become adopted across all future models (12-bit and otherwise) as the potential for code reuse greatly enhances the economics of future development and of lifecycle maintenance.
However, it's by no means certain this means no further firmware releases for the MSO5k series.  The latest FW for both the 5k and the DHO1k/4k both date from May this year, so it wasn't "dropped" when the DHO line was first introduced.
And, the DHO800/900 whilst interesting, aren't "God scopes" and don't overlap the MSO5k's capabilities.  So I think ultimately, it will all depend on sales revenue.  Whilst the 5k continues to sell (and by all accounts on other threads, it was doing quite well in the best sellers lists of the likes of Batronix), it will likely continue to receive some development cycles.
« Last Edit: September 10, 2023, 11:45:28 am by NE666 »
Online RAPo
« Reply #7 on: September 10, 2023, 11:50:20 am »
I'll think that the hobbyists will buy both an MSO5000 for the benchwork an d a relatively tested functionality and a DHO8/900 for its newness,12-bit and portability. Both scopes use the same LA-probe so that investment is shared.
  • Country: pt
« Reply #8 on: September 10, 2023, 12:44:48 pm »
I think i will wait for more reviews on the DHO series.
Offline NE666
« Reply #9 on: September 10, 2023, 01:36:48 pm »
Very prudent, I think.  So far we've seen (far too?) much about fan noise and boot time and very little by way of objective review of performance against claimed specification, usability and "completeness".  I'll be holding off until at least I've some confidence that it actually works well as an oscilloscope of its specifications, rather than a cute, portable Android-based, Doom platform / hacker fest, which can also be used to display some waveforms if you're into that sort of thing..
Offline NE666
« Reply #10 on: September 10, 2023, 01:51:20 pm »
Speaking as someone who has already invested in both the MSO5k and the Rigol cable for it, I doubt that I will pay a 200 USD premium (between the DHO804 and the DHO914) just so as to duplicate the exact same functionality I already have.
If you're doing enough microcontroller work to have already gone for the MSO, then that money is better spent being put towards a decent "proper" LA / protocol analyser.  IMHO.  Maybe the extra memory depth or bandwidth together might justify it but it's already starting to appear as if the 800 is hackable in those regards.
YMMV
Online Fungus
« Reply #11 on: September 10, 2023, 07:44:17 pm »
Because not many people have them in their hands yet.
Mine is ordered. Delivery is promised in October.
Offline mwb1100
« Reply #12 on: September 10, 2023, 08:27:32 pm »
The MSO5000 has been out for about 5 years I think.  I also believe most if not all the important bugs have been ironed out.  While they have released a couple firmware updates earlier this year (including VNC support!), I think that anyone planing a new purchase shouldn't count on MSO5000 firmware updates except to handle any hardware changes (such as the new nand chip they're using in manufacturing now) or maybe to fix bugs - and I wouldn't count on much in the way of bug fixes either.
I'm not saying it can't or won't happen, I just think it's something that shouldn't be expected.  I'm pretty sure the MSO5000 is about as polished as it's going to get.
Personally, if I were looking for a new scope right now, I'd almost certainly go for the DHO914 or DHO914S over the MSO5074 unless I wanted the larger screen, 250MHz/lower sample rate/lower memory depth wouldn't cut it, or I really needed the second AWG.  Is there anything else the MSO5000 has over the DHO914 spec wise?
(Note: I'd also look at Siglent's offerings in the same price range and maybe hold out to see where the SDS1000X HD lands pricewise in USD)
I'd also try to hold out for Black Friday/end of year promo season.  I have a feeling there are going to be some good deals again like last year.
Offline NE666
« Reply #13 on: September 10, 2023, 10:12:32 pm »
A non-issue for some and quick becoming a thing of the past across the board but I do still like the separate, physical vertical controls for each channel.
Similarly, the MSO5k has external trigger-in capability, which will be essential for some and of no consequence to others.
The following users thanked this post: Someone, Fungus, tcottle, mwb1100
Offline simone.pignatti
« Reply #14 on: September 11, 2023, 03:52:01 pm »
This is actually a very good comparison, today we had an internal meeting and that was a hot point.
From today, we have the DHO900S for the next two week at our office to make tests.
Any question please ask.
Technical Support
The following users thanked this post: Martin72, mwb1100
Offline tv84
  • Country: pt
« Reply #15 on: September 11, 2023, 04:28:45 pm »
You're very welcome to come here and share your conclusions.
Offline UK
  • Country: ma
« Reply #16 on: September 14, 2023, 01:55:08 pm »
I'm wondering does DHO900 really has a higher sensitivity.
From MSO5000 datasheet:
Vertical Sensitivity Range[3] 500 μV/div~10 V/div
[3]: 1 mV/div and 2 mV/div is a magnification of 4 mV/div setting.
From DHO900 datasheet:
Vertical Sensitivity Range[4] 200 μV/div to 10 V/div
[4]: 200 μV/div and 500 μV/div is a magnification of 1 mV/div setting.
Online Fungus
« Reply #17 on: September 14, 2023, 03:20:18 pm »
Yes. One is 4mV/div and one is 1mV/div.  :-//
(And one of those two is using a 12-bit ADC to measure the signal, the other one isn't)
« Last Edit: September 14, 2023, 03:27:58 pm by Fungus »
Offline UK
  • Country: ma
« Reply #18 on: September 14, 2023, 04:08:07 pm »
I saw in comments higher that MSO5000 can show 12-bit in High Res mode, I know that's just an oversample, but I can't find the same High Res option for the DHO series... does it even exist?
« Last Edit: September 14, 2023, 04:39:11 pm by UK »
Online Fungus
« Reply #19 on: September 14, 2023, 07:19:56 pm »
There's also a thread somewhere that tested that claim and found it to be more like 9 bits in reality.
The DHO is real 12-bit, so... who needs a hires mode? :-//
Offline NE666
« Reply #20 on: September 14, 2023, 07:57:13 pm »
Yes, for the 1000/4000 series (14- and 16-bit).  No, for the 800/900.
So either a hardware design decision (insufficient sample rate / memory depth / processing), or a commercial one.
« Last Edit: September 14, 2023, 07:59:16 pm by NE666 »
The following users thanked this post: UK
Online Martin72
« Reply #21 on: September 14, 2023, 09:12:38 pm »
The DHO1000 has also only one ADC for all channels.
The CPU also seems to be the same, maybe it is the FPGA that is a different model(and makes the difference).
(Samplerate DHO 1000: 2G/1G/500M, Samplerate DHO800/900: 1.25G/625M/312.5M )
Online Fungus
« Reply #22 on: September 14, 2023, 11:38:14 pm »
Yep, it's the FPGA that's different.
PCB comparison:
Offline BRZ.tech
  • Country: br
« Reply #23 on: September 27, 2023, 12:15:15 am »
Hi.
I have an MSO5074.
@simone.pignati offered the possibility of carrying out comparative tests between the MSO5074 and the HDO914S.
Originally the DHO914S has BW=125MHz and has an AFG (Arbitrary Function Generator).
The MSO5074 originally has BW=70MHz and has 2 Signal Generators, SG1 and SG2.
The BW of the two models are different. And the comparison may not be correct in many tests, near and above BW.
The DHO914S has 12bits of Vertical Resolution = 2^12 = 4096 steps.
And Horizontal Sampling Rate of 1.25MSa/s (for 1 channel connected).
The MSO5074 has 8bits of Vertical Resolution = 2^8 = 256 steps.
And Horizontal Sampling Rate of 8MSa/s (for 1 channel connected).
The DHO914S wins in the Vertical Resolution comparison: 4096/256 = 16x.
The MSO5074 wins in the Horizontal Sampling Rate comparison: 8/1.25 = 6.4x.
As a first idea, I suggest (Preheating = 30 minutes):
1. Simultaneously insert into both Oscilloscopes a Sinusoidal signal, without modulation, of 100mVpp, f=10MHz, with Z=50 Ohm, with a 50 Ohm coaxial cable, RG-58 or RG-316, or other. You can use SG1 of MSO5074.
2. Place a “T-BNC” on CH-1 of the MSO5074, continue with another 50 Ohm cable to CH-1 of the DHO914S, place a “T-BNC” and a terminating resistor of R=50 Ohm.
3. On the MSO5000 and DHO914S, activate Measurements:
Horizontal: Freq
Vertical: Vpp, Vrms
Statistic -> Count = 100
4. After 100 counts -> (STOP/RUN) -> Save the IMG on PENDRIVE, on each Oscilloscope.
Compare the Avg -> VRMS of the two models, and if interesting, the other Measurements in the Statistic mode.
5. Hi Resolution 12 bits on MSO5074:
MSO5074 -> Aquire -> Acquisition -> High Res.
(Repeat item 4) -> (STOP/RUN) -> Save the IMG on the PENDRIVE, on each Oscilloscope.
6. Simultaneously insert into both Oscilloscopes a Sinusoidal signal, without modulation, of 100mVpp, f=50MHz, with Z=50 Ohm, with a 50 Ohm coaxial cable, RG-58 or RG-316, or other. You have to use an external one: RF Generator or Waveform Generator.
7. (Repeat items -> 3, 4, 5).
8. Compare all the results from (item 4), and give your opinion.
Another suggestion:
If possible, use a DHO924S with BW=250MHz, and an MSO5074 with expanded BW=350MHz.
9. Simultaneously insert into both Oscilloscopes a Sinusoidal signal, without modulation, of 100mVpp, f=200MHz, with Z=50 Ohm, with a 50 Ohm coaxial cable, RG-58 or RG-316, or other. You have to use an external one: RF Generator.
10. (Repeat items -> 3, 4, 5).
11. Compare all the results from (item 4), and give your opinion.
12. Place the IMGs saved on the PENDRIVEs in this topic.
13. Comment on the loss of RF signal in the RF cables and connectors used.
« Last Edit: November 16, 2023, 11:42:14 am by BRZ.tech »
Offline BRZ.tech
  • Country: br
« Reply #24 on: November 08, 2023, 01:57:06 pm »
Hi.
@simone.pignati stated the possibility of carrying out comparative tests.
I post message #23, presenting some suggestions.
@simone.pignati, if you don't understand the questions, or don't have all the instruments to carry out the comparative tests, or don't have an agenda, or something else, let us know.
If you have any difficulty performing the tests, let us know your questions so we can help you.
If you decide not to carry out the tests, please also let us know.
To carry out the tests you will need:
1 MSO5000 with BW=350MHz.
1 DHO924S with BW=250MHz.
1 RF Generator programmable in Frequency and Amplitude, and 50 Ohm output.
Online ebastler
« Reply #25 on: November 08, 2023, 03:36:19 pm »
Since Simone has not been on the forum for a few days, maybe I can chime in.
Simone had stated that he would have the DSO900 around for testing for two weeks, starting on September 11th. You proposed your list of tests on September 27th. So I'm afraid he will not be able to do these tests for you. If you have any difficulty understanding the problem, let us know. ;)
Offline BRZ.tech
  • Country: br
« Reply #26 on: November 08, 2023, 07:03:57 pm »
@ebastler.
I understood the problem, you're right, I sent the question outside the available period so @simone.pignatti could have the HDO900 on hand for testing.
I understand she hasn't been on the forum for a few days.
This way, she is free to not do the rehearsals.
And someone else, if they want, can do the rehearsals.
And then, @simone.pignati can do it too, if she wants.
I use Google Translate for all translations into English. I'm sorry if any words weren't translated well.
All the best.
Offline Geotekds
« Reply #27 on: November 27, 2023, 12:08:03 am »
I have an MSO5104, MSO5074, and a DHO914s.  I bought the DHO914s to see how good the 12 bit resolution was, especially for audio FFT.  It is a bit better, but the MSO is still far superior from the operator's standpoint.  The large screen on the 5000 will spoil you.  Also the MSO5000 supports VNC, which allows rapid control from though the net.  With the VNC, you can put the display on a giant screen and zoom it to fill the screen.  The DHO914s does have better response on a browser connection.  The biggest problem with the DHO914s is the necessity of switching channels to control a channel.  Many times you might be thinking you are controlling channel 1 when in fact channel 2 was still selected. I do like the VESA mount which allows the dho914s to be mounted on a bracket.
Offline Tarloth
  • Country: ar
« Reply #28 on: November 28, 2023, 11:33:37 pm »
Sorry, any news from the users that have both oscilloscopes? I want to replace an old four-channel agilent with something that has a logic analyzer included, LIN/CAN decoding and an AWG is appreciated to test some analog sensor circuit, but essentially I am going to use it in digital applications. Is the usability of the DHO914s reasonable? I would greatly appreciate personal experience from those who have used both models. Thank you
Online Fungus
« Reply #29 on: November 29, 2023, 12:10:46 am »
I'd want a big screen for looking at all those logic channels.
You don't need 12 bits if you're using it in digital applications.
The following users thanked this post: Tarloth
Offline Tarloth
  • Country: ar
« Reply #30 on: November 29, 2023, 03:23:46 am »
I agree with you, what gives me doubts is that the MSO5000 has already been around for 5 years and I suspect that they will stop supporting it soon. In that sense, the DHO surely has more bugs but it has a more modern design, it will age more slowly. I am very attracted to the 8GSa/s that allows me to detect glitches 3 times faster than those detected by the DHO, half of my use of the oscilloscope is that, detecting glitches (although to be honest they last longer than those detected even by the DHO ). The screen and independent controls per channel for the vertical one are a very strong advantage, but on the other hand those who have the MSO say that the interface is much slower and clunkier than that of the DHO.
The possible battery use of the DHO is also a very strong point in its favor since many times I have to monitor CAN lines far from the AC line but with 24 volts easily available. 12 bits don't really interest me, they are not a decisive factor but it scares me a little that everyone says that the analog front end of the MSO is really very noisy (how much?), but sometimes people exaggerate in order to favor the brand that has been bought versus the one that the neighbor bought.
I'm really in doubt, clearly there are features that I find very attractive about both but I don't have the budget to buy both. That's why I'm "desperately" asking for opinions from those who have them.
Thank you very much for any opinion you can give me.
Online Fungus
« Reply #31 on: November 29, 2023, 07:49:27 am »
The MSO5000 isn't going to stop working. They're not going to add more features to the DHO900.
What you see today is pretty much what you'll see five years from now.
Yep.
Doesn't matter for digital. Digital is all about timing and squareness of edges. Sample rate and bandwidth is king.
Offline NE666
« Reply #32 on: November 29, 2023, 09:12:55 am »
I have both the MSO5k and the DHO1000.  Sure, the 5k UI now looks a little dated as compared to that of the DHOs but I find it perfectly useable in absolute terms.  I don't perceive any lack of response, not to any significant degree.  And as it has already been said, the physical vertical controls I actually prefer, at least in my workflows.  It could be increased familiarity (I've had the 5k longer) but I actually find the 5k faster to use sometimes. YMMV.  The DHO screen is noticeably brighter, which is welcome but it's also significantly more reflective, so it's a mixed bag.
I initially bought the 5k rather than DHO, since I also am working predominantly in the digital/microcontroller domain.  My rationale being that the best bang for the buck comes from buying features you will benefit from e.g. significantly increased sample rate rather than those you won't e.g. 12-bit resolution.  Unless you're planning to work with small signal levels, the front-end noise argument is moot imho.
Also, you're likely younger than I am and may hence have better eyesight but - I'm glad I went with 9" and 10" screens respectively.  MSO operations with any significant number of channels on a 7" screen would be pushing it I think, at least for me.  You can, of course, always make use of the HDMI output on any of these machines but only if you want a monitor on your workbench too.
I'll add too that the reason I subsequently purchased the DHO was "because I can" and "it was cheap" (40% discount during Black Friday week) rather than needing to make up for any deficiency in the 5k.  It could still find it's way onto an auction site yet.
Offline UK
  • Country: ma
« Reply #33 on: November 29, 2023, 09:57:21 am »
Sorry for being off topic, but when we talk about only digital signals, bigger screens and dreaming about working from battery power... why not just grab a logic analyzer + tablet/laptop with the desired screen size, instead of this big heavy guy MSO5000?!
For example something like DSLogic U3Pro32 for half of the price of MSO5104.
The following users thanked this post: ebastler
Offline Tarloth
  • Country: ar
« Reply #34 on: November 29, 2023, 03:45:57 pm »
UK, now I have a LA connected to a laptop. Decoding signals from the PC has many disadvantages for me, it is perfectly usable but not ideal. Among the disadvantages is that whenever I need to decode it is because I have to see signal degradation at the same time the error occurs, so then I have to use the external LA, the laptop and the oscilloscope and on top of that I see the analog signal on a screen and the digital decoded in another. I prefer to see all in the same screen in real time to see jitters for example.
Another issue is that essentially the laptop plus the LA costs more than the oscilloscope, it's not as compact, and I don't have all the other features of the oscilloscope on hand or its robustness. Laptops can be fragile in field conditions and those that aren't cost much more than an oscilloscope in this price range.
Offline Tarloth
  • Country: ar
« Reply #35 on: November 29, 2023, 03:53:30 pm »
The same on this side, microcontrollers essentially and although lately I never monitor more than 4 or 5 lines at the same time, I perfectly understand what you indicate about the screen and it is one of the strong points of the MSO along with its much better bandwidth.
Now, a very important question, where did you get a 40% discount on DHO?????? THANKS
Online ebastler
« Reply #36 on: November 29, 2023, 04:03:26 pm »
Rigol Europe, Rigol North America and their local distributors are offering 40% on the DHO1000 series -- until tomorrow in Europe, apparently until December 4th in North America. Not sure whether you can get the same deal locally; Rigol NA's website says "US and Canada only".
Offline Tarloth
  • Country: ar
« Reply #37 on: November 29, 2023, 04:06:46 pm »
Thanks Fungus!, I understand that digital noise surely does not influence signals of at least 0.7 volts in digital, but how much noise does your unit have on analog the front end? Less than 10mv? Many times I evaluate sensors and when the signal varies slowly I use a very good multimeter and that's it, but sometimes the signal that I need to it process cannot be followed by the multimeter obviously and I need to see it in the oscilloscope, which is why I am concerned about noise. I don't need 12 bits (they are very appreciated of course) and I don't need the noise to be in the microvolts range either, but I would be worried if it is greater than 10mv. In the forums I have read atrocities about the noise in the MSO, I don't know if it is due to malicious people, poor measurement or defective units.
Thanks in advance
Offline Tarloth
  • Country: ar
« Reply #38 on: November 29, 2023, 04:07:55 pm »
I will buy in USA today! I'll check that discount right now, thanks!
EDIT: I just saw it, great price, but the DHO1000 series does not have a logic analyzer and I would prefer to integrate it. While it has more bandwidth than the 900 and a larger screen, it lacks a built-in signal generator too. The AWG of the MSO5000 or the DHO900 are not wonderful, especially when compared to higher budget instruments, but they are sufficient for me to evaluate signal adaptation circuits for sensors. It seems to me that the alternative is still the DHO900 or the MSO5074 (hacked of course). Thank you!
« Last Edit: November 29, 2023, 04:18:47 pm by Tarloth »
Online Fungus
« Reply #39 on: November 29, 2023, 04:36:31 pm »
It's not an absolute number, it's more like a percentage. Think of it as thick traces on screen.
How much noise that represents depends on your vertical scale.
There's features to mitigate it but they usually come with conditions, like needing a repeating signal and averaging several copies of it together ("waveform averaging" mode).
As noted earlier though, it's moot for digital work.
« Last Edit: November 29, 2023, 04:38:29 pm by Fungus »
Online tszaboo
« Reply #40 on: November 29, 2023, 05:04:37 pm »
Yep, the lack of AWG and LA really hurts those two families. Like what are you even supposed to do with a 2 channel scope alone? Cannot decode any serial protocol and see the results the same time. Siglent has this nice feature that you can connect an AWG to a scope with an USB cable and the scope will do Bode plot with it, Rigol, this is missing. It's only software. I don't see why would you buy that 12 bit scope, unless it's your 3rd scope or something.
Offline Tarloth
  • Country: ar
« Reply #41 on: November 29, 2023, 05:35:33 pm »
I don't understand you tszaboo, sorry, my English is not good and I'm probably missing your point. The two oscilloscopes we are talking about have 4 channels and both have at least one AWG integrated (included in the cost, the MSO actually has two but both enabled by a hack). AWG in rigols have the same functionality of siglent that is external via USB and a added cost. I consider a disadvantage and external device that could be integrated inside the same device. Both have BODE analysis (with limitations in the DHO900 and apparently some bug) but from what I observe with the same functionalities as the siglent. It is true that the siglent has, according to the reviews, less noise than the MSO, but no less than the DHO900.
What would be your real point in favor of Siglent?
Offline Tarloth
  • Country: ar
« Reply #42 on: November 29, 2023, 06:15:09 pm »
I see it, I have more noise in my old Agilent (rigol?), it's not relevant in digital signals.
Yes, abussing from the 8GSa/s I can average 6 points and still has the same bandwidth of the DHO900
Agree, THANKS for help me
Online tszaboo
« Reply #43 on: November 29, 2023, 06:15:40 pm »
I was talking about the DHO1072 and DHO1074.
Offline Tarloth
  • Country: ar
« Reply #44 on: November 29, 2023, 06:19:08 pm »
Ahhhh, ok, yes, I don't dispute that the DHO1000 model has better analog characteristics than the 900, but I need the logic analyzer and to a lesser extent the signal generator, but I need both.
Online Fungus
« Reply #45 on: November 29, 2023, 06:52:27 pm »
The BIG weakness of the DHO900 is the sample rate when everything is turned on simultaneously. It's not enough.
This is the decider for me.
Offline Tarloth
  • Country: ar
« Reply #46 on: November 29, 2023, 07:12:05 pm »
Yes, the bandwidth of the DHO900 is really disappointing, 2Gsa/s would calm my concern.  |O
I really think that the MSO5000 is a better oscilloscope, I have to decide in the next few hours so that a friend can buy it in the USA and bring it here to Argentina. I am saddened by the fact that at first what interested me most about the DHO914s is the possibility of using it on battery power to decode signals in the field.
Thanks to your information I was able to eliminate the ghosts read in the forums regarding the MSO5000, now unfortunately I have to choose between better bandwidth and portability.
Thank you all
The following users thanked this post: Fungus, NE666
Offline TELCO
  • Country: hn
  • "Life is too short and it's all about the ride".
    • TELCO
« Reply #47 on: February 20, 2024, 03:13:07 am »
That is exactly what I am going to do since I already own the MSO5K and I like the DHO900.  :popcorn: ;D :) :clap:
"Live Long and Prosper and May the Force be With You, Always".
