Author Topic: Rigol MSO5104  (Read 521 times)
Offline bigendianTopic starter
  • shutdown -h now
Rigol MSO5104
« on: February 12, 2025, 12:09:49 pm »
HI, was looking at this scope specs
They says 8Gs/s.   This data is true ? What are then they needed for ?
Also they say 100 Mpts (likely per channel) . this also seems much more than needed, but good.
Any general feedback on this instrument, compared to similar more expensive stuff as tektronix ?
Thanks
Online Aldo22
Re: Rigol MSO5104
« Reply #1 on: February 12, 2025, 12:31:54 pm »
Yes, if you only use one channel.
With 4 channels it is 2 GSa/s and 25 Mpts per channel.
That is good.
Sample rate
1 channel with 8 GSa/s
2 channel with each 4 GSa/s
4 channel with each 2 GSa/s
Memory depth (standard)
1 channel with 100 Mpts
2 channel with each 50 Mpts
4 channel with each 25 Mpts
Offline mwb1100
Re: Rigol MSO5104
« Reply #2 on: February 12, 2025, 08:12:10 pm »
So many threads with so much information.  For a while you couldn't swing a cat on eevblog without hitting an MSO5000 post.
EEVblog #1146 - New Low Cost Rigol MSO5000 Oscilloscope
Rigol MSO5000 Threadlist
Some threads that might not have made it into the above linked thread list:
Is a Rigol MSO5000 still worth it after the new DHO's have arrived?
Is a Rigol MSO5000 overkill for a hobbyist?
Hacking the Rigol MSO5000 - Dr Mefisto Licensing Method
For anyone in the US reading this and interested in the MSO5000, Saelig has the MSO5074 for $720 until the end of month with coupon FEB2025
« Last Edit: February 12, 2025, 08:45:30 pm by mwb1100 »
The following users thanked this post: bigendian
  • shutdown -h now
Re: Rigol MSO5104
« Reply #3 on: February 12, 2025, 08:43:45 pm »
Thanks a lot.
Will look in those threads.
Offline nexus1972
Re: Rigol MSO5104
« Reply #4 on: February 13, 2025, 04:39:18 pm »
I bought my 5104 from telonic in the black friday sale - the main reason being I needed something that had a logic analyser that I can trigger on whilst also monitoring multiple voltages.
It came with a free bundled rigol LA probe which is a few hundred on its own - I know theres an aftermarket one but from memory its much more limited in its ranges.
Also when buying it you could get a big discount on a licences pack for the 2 arbitrary waveform generators and some other bits I had an interest in.
I was looking at the siglent and rigol 12bit scopes but I didnt need that functionality and once I added a LA probe set it was much more expensive. I also have the option in the future to extend the scope if the need arises.
Been very happy with how its performed.
The following users thanked this post: Fungus
  • shutdown -h now
Re: Rigol MSO5104
« Reply #5 on: February 18, 2025, 11:23:51 am »
good to know, thanks a lot
