Author Topic: 8116A Code 42  (Read 49362 times)
Offline MarkL
Re: 8116A Code 42
« Reply #125 on: November 21, 2024, 08:42:38 pm »
I did find a complement for MPSH10.  Unsurprisingly it is MPSH11.  Unfortunately, besides having limited availability, it can't sustain more than 50mA of continuous collector current.  The second mirror amp circuit looks like it could put at least 100mA continuous through Q262, so no go.
They're probably wanting small collector-base and/or collector-emitter capacitance to keep the trigger output fast.  A non-optimal substitute will likely just result in a slower trigger output.
The only thing I'm coming up with so far is 2N3209.  And availability is not good.  Hopefully your 1853-0357 order will come through.
If all else fails, you could try a pair of common 2N3906 and see what the output looks like.  It won't hurt the unit if it doesn't work.
My trigger output into 50ohms has a T_rise of 4.0ns and T_fall of 3.3ns, for reference.
Edit: Not a current mirror, rather a differential amp.
« Last Edit: November 23, 2024, 04:19:41 pm by MarkL »
Offline MarkL
Re: 8116A Code 42
« Reply #126 on: November 23, 2024, 04:17:07 pm »
I need to make a correction to several posts I made:  You are correct that the transistor configuration is a differential amplifier.  I don't know why my fingers kept typing "current mirror".  I hope it did not lead to any confusion.
The analysis of collector current for a substitute is still correct.
The following users thanked this post: Mick B
Offline Mick BTopic starter
Re: 8116A Code 42
« Reply #127 on: February 17, 2025, 10:52:15 pm »
Hello Mark, and anyone else that has fallen down this rabbit hole with Mark and I. Due to A major health issue in the family, I had to put this on hold. Things will be coming to a head in the next couple of months, but then moving out of state after that when I get settled, I will take this up again...Mark willing and able. It's been fun and a most excellent learning experience. I'm looking forward to the continuing adventure........finding the bottom of this rabbit hole!  :popcorn:
Offline MarkL
Re: 8116A Code 42
« Reply #128 on: February 18, 2025, 12:22:27 am »
I am willing, and hopefully able, whenever you're ready!
