Author Topic: Rigol MSO7034 vs MSO5354 price  (Read 789 times)
Offline MorazanTopic starter
« on: December 05, 2023, 07:59:15 pm »
I'm trying to buy an oscilloscope and narrowed it down to the MSO7034 and MSO5354. The 5354 is $1,999 USD and the 7034 is $5,099. Both are the 350MHz BW version. I don't know why the price difference is so large. The 7034 has a bigger screen and a few more features but I can't believe that alone makes it more that 2x the price of the 5354. Most of the specs between the two are identical. I don't care about a bigger screen since I'm going to connect external monitor anyways. So I can't justify spending so much on the 7034. Heck, I can buy two 5354 and still have money left over for more equipment.
Does anyone know why the 7034 is so much expensive? I'm just asking out of curiosity.
Thanks!
Offline Martin72
  • Testfield Technician
Re: Rigol MSO7034 vs MSO5354 price
« Reply #1 on: December 05, 2023, 08:43:22 pm »
A few things are already different.
More memory, more sample rate, higher DC-gain accuracy, higher timebase accuracy, larger screen, 50 ohm inputs, connection for active probe...
Whether this is worth 3000$ more, I cannot judge.
But how did you come up with this older scope series from rigol?
If it doesn't have to be MSO, but has to stay rigol, I would rather get a DHO4204 and hack it to 800Mhz.
