I could see this being interesting to look at several stages of active filter at the same time on single correlated screen.
Or a test of an active crossover and plot 3 frequency bands simultaneously so you can see overlap.
Also, since Siglent uses external SG, in theory you could go quite high in frequency with SDG5000 and SDS5000X....
Another interesting thing about that scope.
Keysight 3000T FRA app is very nice and works real good. It maxes out at 20MHz because of siggen.
Of course you mean SDG6000X ^
Performa01 has the 500 MHz version and of course a pre-production SDS5104X.................
Well I have the SDG6000 but no SDS5000X...
Which, as the time goes by, I itch more and more to compare it to my MSOX3000T to see how it fares.
Unlike specification comparisons, I would like to make direct comparison how it is when doing real world tasks, like measuring, decoding, how good is MSO integration etc etc.
From what I tried quickly, it felt real nice and quick... But I would like to try side to side comparison.
For instance, I have a NFC devkit on my desk now. Keysight 3000T has NFC triggers, but if you capture whole packet it starts undersampling severely. I have to enable peak detect mode to see propper amplitude of signal. There is even a trick that Keysight devised to route trig out (that works at full sample rate) back to second input channel as a decoded signal, and then you use that to decode with Manchester decode.
That kind of thing happens all the time. It would be much better if it had more memory. I use Picoscope quite often because of that.
Having both good responsive scope and long mem would be nice...
