Warning:
Fanboys should not keep reading this!
I got the Rigol DG812, and i am really dissapointed... say furious. It has some nice features, but some dont work at all, and other issues make the work with it rather challenging. It feels like i bought a chines 100$ wavegen. I just had trouble debugging my code, but it wasnt the code, it was the rigol.
Here is a list i made, hope some might find it useful (Yes, its only negative feedback):
- Socket protrude on the back, almost set it on the back while unwrapping
- The knob works as good as a button. Turning it faster does not speed it up! It does spin wobbly... Its a disgrace!
- Keypad closes unintentionally while seemingly hitting between the buttons.
- Cursor jumps on different place when reached lower limit on setting up amplitude/Frequency.
- Sometimes putting in numbers in the numberpad will replace old value (as it should behave), and sometimes not.
- Ramp wave only 200kHz? WTF? This thing says 10MHz on the case...
- Menu for choosing modulation wave jumps back up or chooses an item after scrolling down.
- No color guidance on the display. The only color is printed at the sockets.
- Text on top sometimes stays the same (Modulation/Continous)
- Square highlevel 1.5V and lowlevel 0V is a 0-3V level!
- Highlevel limit not working on hamonics -> 4.9V with 3V limit. Negative limit is also exceeded.
- Longer dialog messages can not be read, as they appear only for about 1-2 seconds.
- No option to have signals constantly aligned. You have to hit button align over and over again, after settings are changed.
- Activating the counter, and then the generator again: Settings gone!
- USB on backside
- USB sticks are hardly working.
- Major GUI bugs: Menu switches when activating DSSC
- Not possible to set up negative or above 360° phase shift. No rollover either.
- Burst and sweep does not work with ext trigger (only FM mod, or other)
- High or low level limit in general settings can not be set, if the current waveform has conflicting settings.
- Changing PWM period causes pulses to be smaller or bigger than set up values from before or after.
Limits were in place, and one would not know were the conflict were:
- Low level limit only to -1.5V not 0
Dont bother asking me about details, its just not worth it, just buy something else.
