I can duplicate the behavior you show in the video by turning on persistence before starting to record the waveforms. Considering what persistence is (making the waveform darker in spots it hits many times) and what playback mode is doing (showing a single waveform capture at a time), this seems to make sense. If I'm correct, try turning off persistence before you record the waveforms, and see if the behavior persists. When you think about it, persistence and playback don't really make sense together anyways.
