The power supply.12V 4A with TYPE-C.it looks so cheap....
4x PVP2150 1/10X switchable probes
power up & about
it based on android 7.1.2 system.
WTF...
When i adjust minimum vertical division,it has a large ripple at 55KHz and large noice....
I guess it may come from power supply.
When i place my hand near the channel inputs,the noise become much more like this
It support PD.I replaced power supply for it from my samsung notebook.Now it looks fine.
The original power supply,it sucks.This is the cheapest power supply without any fliter....
The backside of the mainboard.There is a TF card near RJ45 port.It’s the system rom.
The RK3399 CPU and memories
The Xilinx ZYNQ XC7Z015 Main FPGA.and a 4Gbits ddr3l dram from gigadevice,and the two empty dram for DHO900?
RT8847IQ 2GS/s ADC.the same with DHO1000/4000.
it may limited to 1.25GS/s by software?
RT1642IQ Front End. the same with DHO1000/4000 too.
the other side of mainboard
front panel without logic analyzer port
The AFG for DHO9x4S is a pluggin module.The LA port is directly connect to the main fpga.
The other component looks all populated,
so DHO800 uphack to DHO900 may need to solder up two drams and LA port only and flash the system?
I really hope external power supplies don't become a thing. Who cares if your product is small if you still have to carry random stuff around.
Is this power supply some kind of joke? But after replacing it with a decent one, it seems to be okay. Unfortunately, I can only see a thumbnail on the forum, and when I enlarge the image, it shows a different one.
However, I wouldn't worry too much about it. It's cheap, so the first step would be to replace the power supply. Anyway it's a surprising move, it reminds me that cheap usb "thing" from FNIRSI
Thanks for the tear down.
Does anyone know when this device will be available in Europe?
EDIT: In the meantime I got a reply from batterfly:
Hello, we hope to have them listed into our website https://www.batterfly.com for sale within October 2023.
It would be though gray marked for sure. Officially - it would be strange, but if some retailers can make a deal, it would be nice.
October 2023...Time enough to polish some things.
If the power supply has a type-C connector, then its likely non-compliant as its constantly outputting 12V and will blow up your equipment?
Either way probably some junk thrown in by the seller or a temporary solution for a PSU. No way the real scope would ship with that. Still, indicates lack of filtering within the scope itself.
Previous thread:
https://www.eevblog.com/forum/testgear/rigol-dho800900-pre-sales-begin/
Nope. Type-C can output many different voltages. You can negotiate with the supply and tell it how many volts you want.
