EEVblog® Electronics Community Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Products
Test Equipment
TEK 475 Flickers
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: TEK 475 Flickers (Read 3038 times)
PsychoMaster
Regular Contributor
Country:
TEK 475 Flickers
on:
August 17, 2015, 09:54:31 am »
Hello Folk
When I first switch on my beloved Tektronics 475A on channel one the screen flickers about when you touch the vertical selector dial but settles down after ten minutes warm up so I have not messed with it .It obviously won't sort itself out so any advice would be welcome.
Logged
SaabFAN
Frequent Contributor
Country:
Re: TEK 475 Flickers
Reply #1 on:
August 17, 2015, 10:16:34 am »
Try to get some "Kontakt" Cleaner into the knob. It probably is just a little bit dirty inside.
If that doesn't help, it might be necessary to replace the knob or repair it, because some parts are bent or out of alignment.
Logged
PM9610 Replacement for PM6654 Counter
Twitch-Channel - Gaming, Electronics Design, 3D Modeling, Random stuff
PaulAm
Country:
Reply #2 on:
August 17, 2015, 11:35:41 am »
Do not use contact cleaner on the attenuator contacts. I'm assuming you meant the attenuator since the channel selector controls are push buttons.
The contacts on the Tek cam switches are gold plated and should only be cleaned with a small piece of copier paper soaked in IPA. They do get dirty over the years. Cleaning them is a delicate but relatively easy task. The full procedure is in a thread somewhere.
Logged
SaabFAN
Country:
Reply #3 on:
August 17, 2015, 01:24:40 pm »
Is that Kontakt-Cleaner (I have "Kontakt 60" here) bad for gold-plated contacts?
What about Kontakt 200 Oil btw.
Logged
SoundTech-LG
Country:
Reply #4 on:
August 17, 2015, 04:21:38 pm »
In that Front End circuit, anything you put in there that does not evaporate completely will change circuit impedances, and alter the characteristics of bandwidth etc. Do you really want to do that?
Logged
PsychoMaster
Regular Contributor
Country:
Reply #5 on:
September 20, 2015, 09:14:46 pm »
Hi All
Thanks for the replies , I am so late as the caps went on my old motherboard and I am too tight to get a new one so a awkward repair was needed.I reckon on no more than a clean with alcohol and a good blow as a first attempt.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Products
Test Equipment
TEK 475 Flickers
Thanking...
EEVblog® Main Site
EEVblog® on Youtube
EEVblog® on Twitter
EEVblog® on Facebook
EEVblog® on Odysee
