Hi All,
I finally got tired of the small voltage and current error on my M9712 load, so I started doing calibration on it, I did the voltage just fine, then when I went to do current it was fine until it got to the final step, the 4.5A calibration, it is maxing out my power supply at 10A, so I entered the actual current and finished the cal, it is displaying the correct current, but it does not set to the correct current!
If I set it to 1A it actually runs at 1.7A (and shows this on the display), if I try and set anything less than 0.5A it doesn't load up at all... if I set to 3A I get 7A actual and if I set to 4.5A (the set point of calibration) I get in excess of 10A.
Very odd, has anyone else come across this and know how to rectify it ?
I have attached the only calibration info I could find, if you have something better then please post it!
Another interesting error is that if I set it to resistance mode instead, it gives the same results as setting the current, IE 10 Ohms on a 10V supply is giving me 1.7A.
Note that this calibration sheet is a bit mixed up and is based on the M98xx but also shows the M97xx.
I am just wondering if I need an even bigger power supply to see if it needs more Amperage to be able to set it correctly, I do have a 35A Astron supply here, but I am not sure that is the issue at this point.
