Author Topic: Rohde and Schwarz Spectrum FSEK30 image disk  (Read 798 times)
Offline TardzTopic starter
« on: September 08, 2022, 05:16:13 am »
Hi, I was able to get a spectrum analyzer, a R&S FSEK30 20Hz-40GHz.
The problem is that the data on the hard disk is corrupted, and when powering on, all the initialization by BIOS and preliminary tests work (no display errors). But after the initialization of the hard disk, a message appears "SELFTEST DONE", "SYSTEM IS BOOTING" and everything stops, it does not go further, only the cursor is active (animation).
I could check that the hard disk is functional, since it is detected when I put it on a PC (IDE port).
I was able to make a copy of some files, only, for the rest, there are too many errors on the disk and I can't correct them.
What I need is a disk image of a working system or a link to download what I need to fix this problem.
This spectrum has BIOS 2.1.
Yves
Offline g7kbr67
Re: Rohde and Schwarz Spectrum FSEK30 image disk
« Reply #1 on: July 18, 2024, 09:28:00 am »
Hi
Did you ever find a link to the operating system for this unit?
Regards
Paul
Offline Harry_22
