Author Topic: Rohde & Schwarz 4.0GHz Portable Spectrum Rider FPH Review, Teardown & Experiment  (Read 8612 times)
Offline slurry
Yes, spectrogram is in an option called interference analysis, FPH-K15
also i would recommend the preamplifier option FPH-B22
What is your intended purpose with the FPH? general faultfinding measurements or interference hunting?
I use for the latter and it's hard to beat for that purpose, in that case you might want to add the options K7 modulation analysis and K43 receiver mode.
Offline zitoune
  • Country: sg
Thanks for your answer - I will then consider the interference analysis option.
For now I use it for fault hunting - i may add the near field probes + amplifier set HZ15/HZ16
The touchscreen is very responsive and with combination of the keyboard becomes very handy!
Is there any multi purpose antenna you may recommend ?
