I have a working CMU200 -> MMC (SD) card setup. See the pictures below for the PCMCIA adapter and the MMC card I use. I suspect that the it's important to use a SD (or MMC) card below a certain size...
I suspect that your setup works because that is not a simple SD card adaptor. It is an older multiformat SD, Sony Stick, Xd etc adaptor. This meains it has a conroller and probably presents the PC interface as ATA parallel.
Robert G8RPI.
It must have a controller and possibly firmware inside, emulating as a True-IDE mode CF Card.
As far as I know, the front end is different (including a fan to cool the input) so perhaps you can swap out the front end but its not like you can uninstall an option or something
Thanks for the response. Not what I wanted to hear, but an answer I can live with.
Next question: can I use a PCMCIA SD Card reader to load new software? I see most people using PCMCIA CF readers. Just wanted to know if I would run into trouble using a SD reader instead.
Yes, you probably can. I'm using a PCMCIA SD Card reader for making screenshots on my CMU200 without any problem. Disclaimer: I had only attempted making screenshots and using the card in MS-DOS, I didn't try loading new software, so there's no guarantee, but I can't see why it won't work.
The card reader is a no-name brand with a fake "Mercedes-Benz" logo on it, apparently sold as adapters to play music on old cars, nevertheless works fine for my purpose. But you need to make sure the SD card is compatible with the reader itself, and the card formatted properly to be compatible with MS-DOS.
* First, avoid using those super high density 64 GB SDXC cards, a 16 GB one or smaller card should work. Even better, use an old 1 GB card in your desk drawer specifically for the use in CMU200.
* The card must have a MBR partition table with 1 primary partition. Do not create a raw filesystem without partition table. Do not create more than one partition. Do not create extended partitions. The size of the primary partition should not be greater than 2 GiB, even if the card is larger.
* The filesystem on the first primary partition must be FAT16. Do not create a FAT32 filesystem, otherwise MS-DOS will still try interpreting it as FAT16, and corrupt the entire filesystem.
* Use a standard USB card reader on your PC to format the card. Do not plug the CF reader to the CMU200 or your vintage laptop to do it. It seems the firmware on my card reader is rather limited, doing any low-level operation can confuse the firmware and corrupt the partition table. I tried formatting the card in the reader itself on a vintage laptop, after created a partition and putting it in a standard SD card reader, I see a partition table with a 1000 GB partition.
After you've prepared the card, you should be able to make screenshots. On my model, it works in the second slot. Press Alt + F4 to enter MS-DOS, it should be recognized by MS-DOS as Drive D, and "dir" should reports the correct volume size (otherwise it indicates something must be wrong, e.g. DOS attempts to read FAT32 as FAT16). You can also run scandisk on the card, and it should always pass the check.
Incorrectly formatting SD card can freeze and crash the CMU200. But once the card has been formatted, it's just plug and play.
