Author Topic: Rohde & Schwarz CMU200  (Read 50860 times)
Offline Qw3rtzuiop
Re: Rohde & Schwarz CMU200
« Reply #175 on: January 26, 2019, 08:27:08 pm »
Hello,
R&S calls it the TXDSP MODULE. So it is plausible that your generator didn't work.
I have a spare broken DIG board that contains this module. I had rx problems with that board. The tx worked fine. But you have the newer version 1100.2130.03. The one at mine is the older 1100.2100.03.
I don't know if they are compatible.
The following users thanked this post: Kribok
Online Ice-Tea
    • Freelance Hardware Engineer
« Reply #176 on: January 27, 2019, 11:23:04 am »
I'll check if I have the right version somewhere.
eBay shop with all the gear you need!
FS: Agilent 54825A, R&S CMU200, CRTU, SMIQ06L, Marconi 6201B, Lecroy WP 950, 9354TM, 9354M, 9374L LC584A, Tek THS720P, TDS7154B, Anritsu MG3671A 2.75G I/Q RF gen, Keithley 238 SMU, HP 8642B, 8903A, 8110A, 8156A
Offline Kribok
« Reply #177 on: January 27, 2019, 09:54:27 pm »
This small PCB is damaged at 100%, because after replacing it with another CMU it works normally. Thank you for your answer, and I will gladly buy back such an efficient one, of course if someone has such a plate for sale. Possibly any suggestions, what usually goes bad on these PCBs, if someone has already repaired it?
Offline Kribok
« Reply #178 on: January 28, 2019, 07:04:47 pm »
This is the PCB that is damaged - the smaller one with the inscription in the middle of the DIG. In the pictures I showed the connectors. I do not know if there are any other versions of this tile, but after converting it to another, the CMU worked normally. During the test I did not even check the subtitles on this board, because it looked similar and when it was put in its place it worked normally. I do not know if there are other versions of this PCB that may not work in my CMU, if anyone knows something about it, please write. I greet everyone
Online Ice-Tea
« Reply #179 on: January 28, 2019, 08:09:50 pm »
Got one :D
Offline Qw3rtzuiop
« Reply #180 on: January 28, 2019, 09:09:06 pm »
The soldering at the yellow tantalum cap looks sketchy.
Offline Kribok
« Reply #181 on: January 29, 2019, 07:40:42 am »
I checked this with a multimeter, and it turned out that there is a short circuit, just like you, I thought it was a tantalum capacitor, but after desoldering the PCB did not work, as before. The colleague dismantled this PCB from his CMU and soldered it something, because it also showed a short circuit, but the PCB was working and working in CMU, it turned out that it has an inductance, i.e. a choke! That's why I sold it back to my PCB.
Greetings.
Offline Ivan_Vetrov
  • Country: ru
« Reply #182 on: February 01, 2019, 12:52:07 am »
Hello! How to make a calibration after replacing the hard drive? I now have the level of the generator from the level of the analyzer differs by 3 dB. When the generator level is set to -27 dB, the analyzer level is -30 dB. The D-Line marker shows -22 db. What do I need to do to calibrate?  |O Thank .
« Last Edit: February 01, 2019, 01:02:38 am by Ivan_Vetrov »
Offline Kribok
« Reply #183 on: March 05, 2019, 07:30:29 pm »
Thank you very much for the positive transaction and delivery of a working PCB to my CMU 200.
Now the RF generator works like new.
The repair of my CMU is closed, but no further modifications, I really like this machine and it is worth attention!
Thank you again to the Ice-Tea forum user
Greetings to all Kribok
Offline axel
« Reply #184 on: April 08, 2019, 06:59:17 pm »
Hi all!
Wondering if anyone is using their CMU200 with an external reference. I've got an HP Z3801 feeding into the unit at the REF IN port, and I keep getting "Reference frequency not locked" on the screen when I select external reference mode. I've verified that the output of the 3801 is a clean sinewave at about 3.5V pk-pk. Is the CMU picky about its input waveform, or is something else up?
Cheers!
Offline MarkW
« Reply #185 on: April 11, 2019, 06:51:46 pm »
Hi All,
Maybe it is just me, but when I try to download the FreRes software from the R&S website I get a 'page not found'. Does anyone still have this laying around somewhere?
Thanks!
Mark
Offline ZL1CVD
« Reply #186 on: April 11, 2019, 09:41:22 pm »
I saved them a while back. You can download then from here:
https://drive.google.com/open?id=154oZ86KouXtVO8aD0SCfACZSBnVj5Qa6
73s
Chris ZL1CVD
The following users thanked this post: MarkW
Offline MarkW
« Reply #187 on: April 15, 2019, 06:49:08 am »
Thanks!
Offline MarkW
« Reply #188 on: April 16, 2019, 04:04:19 pm »
I tried out the FreRes application from R&S and I had two issues with it:
- It crashes when you try to normalize to a calibration run.
- It does not run on Linux.
So, I made a small python script that can do more or less the same and runs you through a calibration process. It works for 'thru' and 'reflection' measurements (when using a coupler or RF bridge). Hopefully it is useful for someone, feel free to modify or update it. The script assumes that you have linux-gpib running on your system.
The script is in the attachments, together with an example antenna measurement and filter measurement.
EDIT: updated the script to use 'read' instead of 'fetch' so it is synchronous with the initiated measurement.
Best regards,
Mark
« Last Edit: April 16, 2019, 04:59:00 pm by MarkW »
The following users thanked this post: sab, _Wim_, ZL1CVD, Octane
Offline pedroavex
  • Country: pt
« Reply #189 on: May 26, 2019, 01:41:57 pm »
Hi Manuel!
I have been looking for the R&S Remote Service Tool software to download, but cannot find it anywhere...
I've noticed you said something about having used it some time ago.
By lucky, do you still have its installation file?
Thanks from your neighbour from Portugal!
Offline lordium
  • Country: cn
« Reply #190 on: May 27, 2019, 12:43:22 am »
Here you go
Offline cdorsat
  • Country: hk
« Reply #191 on: July 20, 2019, 10:37:05 am »
Is your problem solved?  Is your problem solved? I have a CMR200 with FMR7. I don't know how to install the wiring of CMU-B41. Which master can help me?
Offline markus_jlrb
« Reply #192 on: July 22, 2019, 09:08:45 am »
Some infos concerning option B41  you will find
https://www.mikrocontroller.net/topic/432327#new
in the mc-forum (in German)
Markus
PS.: See https://www.mikrocontroller.net/attachment/338280/CMU-B41-Cabeling-Schema-missing-cabels.jpg
for cageling schama.
« Last Edit: July 22, 2019, 10:27:58 am by markus_jlrb »
The following users thanked this post: Dynamix
Online Ice-Tea
« Reply #193 on: July 22, 2019, 08:12:56 pm »
Wiring schematics is on the lid of the modules, no?
Offline cdorsat
  • Country: hk
« Reply #194 on: September 03, 2019, 01:31:13 am »
Thank you very much for your help, I have completed the installation of CMU-B41. It is not difficult.
Offline sab
« Reply #195 on: September 22, 2019, 11:53:57 pm »
I corrupted my 64bit version of FreRes v5.30. Does anyone have a copy? I've scoured the web and been through the messages on eevblog and I've only been able to find v5.22.
I like 5.30 because you can do multiple measurements on the same screen and the values appear in different colors.
Thanks,
Sanjay
Offline _Wim_
« Reply #196 on: September 24, 2019, 08:22:07 pm »
Thanks,
Sanjay
Just sent you a pm (was to big to upload here)
Offline sab
« Reply #197 on: September 24, 2019, 11:32:09 pm »
Many Thanks _Wim_.
Sanjay
Offline mdmbc
« Reply #198 on: September 24, 2019, 11:34:40 pm »
Any chance I could get a copy too? I've been searching for it for days..
Offline lordium
  • Country: cn
« Reply #199 on: September 25, 2019, 01:13:29 am »
https://www.mediafire.com/file/r20db9wsidjljkx/1MA009_FreRes32_5.3.0_a.exe/file
https://www.mediafire.com/file/1ryfcvox40o6lhq/1MA009_FreRes64_5.3.0.exe/file
or
链接:https://pan.baidu.com/s/1hky2fhkAUIkuu1J1mN74lQ
提取码:4pa4
if you have baidu. The baidu link contains a lot more. Including some pictures of the inside of my unit and the DD image from the HDD etc.
« Last Edit: September 25, 2019, 01:15:08 am by lordium »
The following users thanked this post: mdmbc
