Author Topic: Rohde & Schwarz FSEA 30  (Read 64641 times)
Offline MuxrTopic starter
« on: August 30, 2016, 05:04:01 pm »
There is no thread for this Spectrum Analyser, so instead of derailing other generic SA threads I figure I start a dedicated one. Got mine a few weeks ago, and I have been pretty impressed with it so far. It's a sizeable beast, pretty heavy too.
I am currently in the process of rejuvenating it. Getting to the main PC board is no small task. It involves a number of steps and hard to reach cable jacks. You have to remove the power supply, loosen the bottom rail locking system, so that you can remove one of the RF cards to give you enough room to unplug the power supply. Then it's simply a matter of removing the metal shielding at the back of the instruments where PC boards are located.
This is what the PC board looks like:
Turns out I didn't have an IDE disk enclosure (could have swore I had one) or I can't find it so currently waiting on it to backup the disk and install the CF flash card replacement. I also have some SDRAM so I might upgrade that while I am at it as well. Will also be replacing the battery. Will update my progress..
« Last Edit: August 30, 2016, 06:05:15 pm by Muxr »
The following users thanked this post: Wuerstchenhund, AF6LJ, Bernd
Offline Wuerstchenhund
  • Able to drop by occasionally only
Re: Rohde & Schwarz FSAE 30
« Reply #1 on: August 30, 2016, 05:53:11 pm »
Very nice instrument!  Thanks for posting this :-+
You know that you are now officially owner of one of the best SAs ever made?  ;)
Yours' is a later variant of the FSEx, recognizable on the front panel (older generations have a red-ish front, later ones the blue-ish grey). From the photos it seems you got a nice clean unit in good condition, and even the display seems to be bright.
Going for a CF Card replacement for the HDD is a good idea. If you feel adventurous you could replace the floppy drive with a CF reader so you have the card externally accessible. Which would also give you room to play with different OS setups (Windows NT 4 was an option which if I remember right included more measurements and was the OS required for the latest software update).
When you re-assemble it, could you take a few more pictures of the boards and the inside of the SA?
BTW: you might wanna re-check the thread title  ;)
« Last Edit: August 30, 2016, 06:21:28 pm by Wuerstchenhund »
The following users thanked this post: Muxr
Re: Rohde & Schwarz FSEA 30
« Reply #2 on: August 30, 2016, 06:07:11 pm »
@Wuerstchenhund thanks! Will be posting more photos as I progress with it. As for the title, I was concentrating so hard on spelling R&S that I messed up the model  |O  :-DD
« Reply #3 on: August 30, 2016, 06:25:24 pm »
I thought at first this was about a R&S FSA  ;)
Online nctnico
« Reply #4 on: August 30, 2016, 06:45:22 pm »
May I suggest an mSata to IDE adapter for even better performance?
I know I bought a very nice SA myself recently but I must say I really like the FSEA and would have bought one if it had come up for a price within my budget (where is the drool emoticon?).
« Reply #5 on: August 30, 2016, 06:56:43 pm »
Might do the mSata -> IDE, we will see if it's compatible, that was my original idea. I picked up the CF adapter as well in case I run into issues.. (I have CF cards from my cameras). They are pretty quick too: 160MB/s. Will see which one is more compatible, I can benchmark them too.
I looked at PATA SSDs as well but I wasn't happy with the specs and the no name brands available.
I've been on the lookout for an SA for over a year, and when this one popped up I had to have it. Your Advantest R3477 is really nice too.. I would have had no qualms getting it if I ran into the same deal you got.
« Last Edit: August 30, 2016, 06:58:17 pm by Muxr »
Online nctnico
« Reply #6 on: August 30, 2016, 07:49:13 pm »
The disadvantage of compact flash cards is that most tell the system they are removable media. Over the past years I did several IDE to CF conversions but I was unable to use a CF card in my Tektronix TLA715 logic analyser. However an mSata to 44 pin IDE adapter (for a few dollars from Ebay) and an mSata card (bought locally!) did the trick.
« Reply #7 on: August 30, 2016, 08:12:55 pm »
Yup, that was my fear too.. after some research I found this Syba that could work, according to this review it presents the CF card as a fixed media so it might work: https://www.amazon.com/review/R1VL7K96HDXOPG/ref=cm_cr_dp_title?ie=UTF8&ASIN=B0036DDXUM&channel=detail-glance&nodeID=172282&store=electronics
Will let you know.
« Reply #8 on: August 30, 2016, 09:06:35 pm »
That is mostly true for consumer cards (i.e. the ones used for photography) which don't support True IDE mode. Industrial cards usually do.
But a CF card identifying itself as a removable media device isn't much of a problem for DOS/Windows 3.11 or WindowsNT 4 anyways, as these platforms don't really support removable media other than floppies and tape.
Yeah, Kingspec is crap. But Transcend PSD330 is a solid PATA SSD, fast, and not overly expensive.
The problem with mSATA SSDs is that they generally tend do rely on a modern OS with TRIM support and don't do a lot GC on their own, which is what you want for a non-SSD aware OS.
« Last Edit: August 30, 2016, 09:10:34 pm by Wuerstchenhund »
Online nctnico
« Reply #9 on: August 30, 2016, 09:14:49 pm »
In case of the TLA715 it was the BIOS causing problems. It just wouldn't boot from a removable media.
The following users thanked this post: AF6LJ
« Reply #10 on: September 01, 2016, 12:15:10 am »
The IDE adapter arrived today. Backup and restore was a piece of cake. I used ddrescue (on OS X) but I assume procedure is similar on other OSs as well.
I have also upgraded the RAM.. put it together, it booted without issues:
The speed difference isn't that noticeable, which is understandable, there is much more to the boot sequence than loading the OS of the disk, like onboarding all the component boards. The original disk was 4.87 GB but the Raw files on the disk only take 67 megabytes. The entire disk image compressed is only about 20 MB.
However I am glad I did the upgrade since I didn't like the sound and whine the original hard drive was making. And at the very least I now I have a backup.
Waiting on the replacement battery to arrive to continue this little project.
« Last Edit: September 01, 2016, 12:25:44 am by Muxr »
The following users thanked this post: Wuerstchenhund, AF6LJ, philipz
« Reply #11 on: September 03, 2016, 10:48:04 pm »
Battery has arrived.. time to take the PC board out again. Bottom of the instrument:
« Reply #12 on: September 11, 2016, 11:48:31 pm »
The original battery I ordered couldn't be soldered onto. I know that usually the batteries are difficult to solder on.. but I've had good luck with some by sanding the battery contacts down a bit and using ample amounts of flux. Not this time though.. I've tried 3 different kinds of flux with no luck. So I had to wait on a battery with welded leads.
Corrosion on the original battery:
The new battery:
edit: I've also added a floppy -> USB conversion drive.
« Last Edit: September 20, 2016, 11:15:02 pm by Muxr »
« Reply #13 on: September 13, 2016, 12:29:47 pm »
Why didn't you go for a battery holder instead? You could then place it somewhere where it is easier to reach.
« Reply #14 on: September 13, 2016, 02:00:11 pm »
I thought about it. It's pretty involved just getting to the board, once you get to the board it's easy, sliding it out and soldering this on. If I can get another 10-15 years out of this battery I'll be happy. Not keeping time isn't a huge handicap, I was more worried about a leaking old battery. ;)
Offline CJay
« Reply #15 on: September 13, 2016, 02:18:21 pm »
Same battery as used on countless generations of Macs and Power Macs, I think I even have a few along with the holders.
Thank you for posting this teardown, really nice to see all the high end test gear torn apart, for some strange reason people are somewhat reluctant to let me tear down their lab gear ;)
Offline kazam
« Reply #16 on: September 21, 2016, 07:16:05 pm »
Great thread and with perfect timing! Just took delivery of my R&S FSIQ3 with TG. It runs NT4 and came with the latest firmware, 4.40.3 installed.
I need to fix a few issues before I start using mine on a daily basis:
1. I will get the Transcend PATA SSD, any need to stick with the SLC models or is MLC just fine?
2. Where can I source that battery with the solder flaps?
3. Noise is a bit too much, any better fans out there?
4. What kind if memory does it take and is it worthwhile to upgrade?
5. It has a really non-standard looking connector for ethernet. Worth using? I have a GPIB adapter so I plan to just use that for now. Kind if prefer ethernet though, less problems.
6. Where can I get one of those USB floppy adaptor/converters?
7. My display is a bit dim, can I get a new one or upgrade the CCFL backlighting on the one already in there?
Thanks!
« Last Edit: September 21, 2016, 07:20:59 pm by kazam »
« Reply #17 on: September 21, 2016, 08:52:39 pm »
Thanks!
1.) I don't think it will make much difference, or at least it didn't on my model (non Windows NT version). The boot is heavily dependant on onlining all the "transputer" boards and the actual SSD upgrade shaves off very little from the boot process. I would pick whatever gives you the highest reliability confidence. SanDisk has had good track record with me so I just used the CF solution. This is the enclosure I used: https://www.amazon.com/gp/product/B0036DDXUM/ref=oh_aui_detailpage_o04_s01?ie=UTF8&psc=1
caveat: the enclosure has that extra middle pin that won't fit into the cable.. I just cut mine off.
2.) This is the battery I used: https://www.amazon.com/gp/product/B0060ASQDC/ref=oh_aui_detailpage_o08_s00?ie=UTF8&psc=1  notice the welded leads are of different style than in the product picture, but you can just bend them and spin them a bit and they fit perfectly. Just cut off the excess lead.
3.) Just air blowing my fans reduced the noise significantly. I was initially going to replace some of the fans.. but the noise is really not bad at all.
4.) Memory I used: https://www.amazon.com/gp/product/B00006BT1Q/ref=oh_aui_detailpage_o05_s00?ie=UTF8&psc=1  standard 144 pin SoDIMM Only one of the slots were populated on my board. I got two and it's fully upgraded. 1Gb of RAM total. Didn't notice any difference in performance, so you might skip this step.
5.) I have the same ethernet card, it looks like the 10BASE2 which is obsolete. Might be possible to upgrade to a current ethernet card, but I haven't looked into that yet.
6.) USB floppy conversion drives can be ordered on ebay usually.. they are very clunky to use. I did mine just for the looks, although I did test it with a thumb drive and it does work.. although took a bit of figuring out.
Not sure about the screen, mine looks ok, but I would be curious as to what you find out.. keep us posted! And welcome to the RS SA club!
« Last Edit: September 21, 2016, 08:55:14 pm by Muxr »
Offline richpike
« Reply #18 on: September 21, 2016, 09:07:09 pm »
Nice piece of gear!  And your photos are excellent - can I be nosy and ask what camera/lens you are using?
« Reply #19 on: September 21, 2016, 09:48:47 pm »
Thank you.. not at all.. I am a bit of a photography nut, thanks for noticing.
Most were shot with the Olympus e-m5 and the Olympus 25mm f/1.8 lens (love this lens, optically it is excellent and it has a very short focusing distance, so it can double up as a close up macro sort of lens). That battery close up was with the Olympus 60mm 2.8 Macro lens. And that last photo (showing the floppy -> USB conversion drive) was shot with my D600 and an old Nikkor 50mm f/1.2 lens.
The following users thanked this post: richpike
« Reply #20 on: September 22, 2016, 05:27:01 am »
MLC is fine. It will very likely outlive the instrument.
It's not "non-standard", that's probably just an AUI connector (AUI is the interface between the network controller and the physical interface), what you need is a transceiver for the network standard you want (Thin Ethernet, Thick Ethernet, TP, Fiber).
Back then you could choose if you wanted AUI, Thin Ethernet (BNC) or TP (RJ45) as port.
« Last Edit: September 22, 2016, 05:29:42 am by Wuerstchenhund »
Online nctnico
« Reply #21 on: September 22, 2016, 07:42:18 am »
You can find these transceivers on Ebay for peanuts. RJ45 is probably the best choice.
Offline psysc0rpi0n
  • Country: ar
« Reply #22 on: September 22, 2016, 09:01:40 am »
...<removed to shorten the post>
The new battery:
Hi...
Recently I watched a couple of videos about welding batteries...
Wouldn't this be of any usage:
Offline kazam
« Reply #23 on: September 22, 2016, 01:02:36 pm »
Reading the manual I came to the conclusion that the ethernet interface is only for file transfer and printing more or less. SCPI is not supported over TCP/IP.
In that case I don't really need ethernet at all so not worth to pursue. I have the dual GPIB interface option as well but apparently the second interface is for controlling external instruments from the SA. Not really useful for me.
« Reply #24 on: September 22, 2016, 01:37:06 pm »
Don't rely too much on the manual (especially if you have an older version), R&S often introduced new features in subsequent software updates which also resulted in a new revision of manuals.
My memory is to dizzy when it comes to those old SAs but I'd get the last software update for your instrument and check the revision history, you might well find that SCPI over TCP/IP has been implemented later on.
The 2nd GPIB is a host port and, as you said, for controlling external instruments. Like for example using an external RF generator as tracking generator. Newer R&S SAs could also use non-R&S generators (like the HP/Agilent ESG Series) but I'm not sure if that was the case for the FSEx.
« Last Edit: September 22, 2016, 01:39:28 pm by Wuerstchenhund »
Offline kazam
« Reply #25 on: September 23, 2016, 11:45:15 am »
I looked into this a bit more and it turns out it actually is supported through RSIB and a wrapper around the standard VXI interface running on the instrument itself:
https://cdn.rohde-schwarz.com/pws/dl_downloads/dl_application/application_notes/1ef47/1EF47_2E.pdf
However, this seems a bit too much and I will likely just stay with GPIB since I have that working just fine with Keysight VISA I/O libraries and Matlab with instrument control toolbox.
Offline kazam
« Reply #26 on: October 07, 2016, 09:50:15 am »
OK, I have my unit opened up and getting ready to do the HDD upgrade.
Yes, it's definitely involved to get to the CPU board. It seems that it would just be able to slide out with the PSU but strangely enough there's a screw securing it to the main frame from the INSIDE of the CPU module. How did they even get this mounted.
I have a lot of options so the RF board rack is fully occupied. See picture.
Any tips on how to proceed from here? In what order should I continue disassembly?
Thanks!
Offline kazam
« Reply #27 on: October 07, 2016, 09:58:40 am »
Picture!
« Reply #28 on: October 07, 2016, 05:06:35 pm »
Interesting, yours has additional electrolytic capacitors on the power supply side. Wonder if this was a factory bodge or someone did some extra work.
Offline kazam
« Reply #29 on: October 10, 2016, 08:52:56 am »
Yes, I noticed this. Looked a little strange to me as well.
This unit is really difficult to disassemble. Particularly mine which has the Ethernet and extra GPIB port option. Additional connectors that are hard to disconnect due to small lock nuts.
There really doesn't seem to be any way of removing the CPU board without fully removing the computer module from the chassis. How did they even get this together at the factory? Child workers with extremely long and thin arms?
« Reply #30 on: October 10, 2016, 03:06:58 pm »
The way I got to the PC board is following (should be similar for you):
- at the bottom I loosened the rail system screws and unlocked it with a flat head screwdriver.. this let me remove the last RF board (to give me some room), RF cables just unplug, I took a picture to remember how they connected.
- remove the PSU unit.. which sits on the back of the instrument top side. Yeah you're right these screws are a pain.
- you should now be seeing a metal shroud cover in the back of the instrument which protects the PC boards.. this shouldn't be too difficult to remove.
Offline kazam
« Reply #31 on: October 11, 2016, 07:14:23 am »
Yes, got it. Thanks.
Used a Transcend D330 32GB drive. My image file of the original drive compressed to ~235MB. Didn't bother with RAM upgrade, will order a new battery though.
In the end I opted to snip some plastic off the PSU connector in order to not have to loosen the innermost RF card. This worked fine.
Now I just have to get this thing together again!
Offline kazam
« Reply #32 on: October 11, 2016, 10:20:23 am »
OK, so that's not working.
The BIOS complains that there is no boot disk available. I have tried restoring the image twice. The original drive read fine with ddrescue from Linux.
I'm starting to suspect that the BIOS won't acknowledge drives larger than 4GB or something equally stupid.  :-// There's only one partition on the drive though and that's the original 2GB partition.
I don't need to set a boot flag in the MBR or something to that effect? It's been awhile since I did anything with IDE.
Offline CJay
« Reply #33 on: October 11, 2016, 11:17:46 am »
If the BIOS can see the drive then it should boot as long as the image is good but is your imaging software 'resizing' a DOS partition to something larger than DOS can see?
Is it possible to boot the analyser with a USB stick, DOS floppy or optical media so you can check that you can partition and format the SSD 'in situ'?
« Reply #34 on: October 11, 2016, 01:44:37 pm »
Make sure your ddrescue backed up the entire device and not just one partition from it. Your situation is probably different (different version of software and OS), but my original disk had two equally sized partitions, and one small one.
Offline kazam
« Reply #35 on: October 11, 2016, 09:21:03 pm »
Yes, I did backup the entire device.
I did some reading and it turns out certain BIOS implementations simply can't deal with drives larger than 8GB. So now I'm trying to find a way to reduce the actual disk size as reported to the BIOS.
Offline kazam
« Reply #36 on: October 13, 2016, 08:41:45 am »
HDAT2 could possibly be the solution here.
We're you able to get into the BIOS? I'm thinking of getting a keyboard to have a look around.
« Reply #37 on: October 22, 2016, 03:42:52 am »
I have not tried accessing the BIOS, sorry.
Offline pjm
« Reply #38 on: October 10, 2017, 04:55:09 pm »
Hi Chaps,
Thanks for the suggestion on the HDD replacement. I have an FSIQ3 which is virtually the same internally as the FSEA30 and the HDD which was an old Fujitsu 4.7G thing, was starting to make noises similar to the click of death. Anyway, I have DD'd the image and copied it to an 8Gb UDMA7 transcend flash, system boots quickly and seems very responsive.
I've also added a LAN card, its a 16 bit ISA 10base2 / 10baseT (INTEL PRO/10 S82595 COMBO 10 Mb RJ45 BNC ISA) which NT4 supports. No issues with compatibility and chats on the network nicely - Windows 7 clients have to have a simple mod to allow them to get to the disk shares. Also installed VNC service on the O/S to allow easy remote management, all very good so far.
The analyser certainly is excellent and I can say that its performance is comparable with units many times the price. I've tested the phase noise measurement and the noise figure measurement and both work fine.
Regards,
Paul
@uhf_satcom
Offline technogeeky
  • Older New "New Player" Player Playa'
« Reply #39 on: October 10, 2017, 05:08:48 pm »
Wow. On the plus side, if that instrument ever dies beyond repair that thing is chock full of (probably) very nice cables. Short, but I bet they are very nice.
Beautiful instrument.
Offline Bicurico
  • Country: pt
    • VMA's Satellite Blog
« Reply #40 on: October 29, 2017, 11:17:59 am »
I am going to receive such a unit to try to repair it. It boots with error on STEST ABORTED ERROR ON RF MODUL RF CONVERTER Error 18.
Any idea, apart from usual cleaning?
Looking for manuals and repair info.
Will keep you updated.
Regards,
Vitor
Offline MindBender
« Reply #41 on: April 09, 2018, 08:22:43 pm »
It's a factory bodge; My FSIQ3 has it too.
Offline MindBender
« Reply #42 on: April 09, 2018, 08:45:09 pm »
I'm sorry to dig up such an old thread, but I guess it's justified because the instrument isn't that young anymore either, and my problem is very similar to yours.
It is also possible that your CF card is not supported because it only reports it's size in LBAs, and not in the older CHS (Cylinders/Heads/Sectors). Many CF cards don't do this, because it is not mandatory for the CompactFlash standard. If the BIOS doesn't support LBA, it requires CHS, and hence the machine won't boot.
I too own an FSIQ3 with most of the HW options installed. I got it 6 years ago, and haven't used it very much, unfortunately. When I got it, I did upgraded the RAM: I got it to work with 2 SO-DIMMs of 512MiB each SDR133 RAM. I don't think 1GB PC133 SO-DIMMs were ever made, or are incredibly rare, expensive and unlikely to be supported.
My battery went dead, and because I'm a stickler, I wanted to replace it. Anybody knows how long it will last? Because it's a real journey to get to the battery. I ordered a new one. Tip: If you want one with the leads on it, order an LS14250CNA.
I did not update the HDD when I got the unit, but I'm not waiting until the old Fujitsu MHK2060AT is breaking down. So now it's open, I'm replacing it with a Transcend TS8GPSD520 8GB SLC drive. It's industrial grade, according to Transcend. I hope it really is. I'm not concerned with speed. I'm more concerned with reliability: I have seen NAND flash memory fail in many devices. SLC is a good sign though. I hope my BIOS supports the drive.
After I have DD'ed my original drive to the new and bigger Transcend drive: Does anybody know if I can safely resize the partition so it will also span the extra size of the new drive?
Offline MindBender
« Reply #43 on: April 29, 2018, 10:41:52 am »
Did you get it to work with that Transcend drive? I have tried both the 2GB TS2GPSD520 and the 4GB TS4GPSD520. When booting the instrument into MS-DOS 6.22 by floppy, it doesn't even recognise having a hard disk. I didn't try a CF adapter with this instrument.
These Transcend drives didn't work in my R&S UPL either. They were recognised, but fdisk failed. The BIOS (latest version) mis-identified them, but even with manual geometry configuration, fdisk failed. When dumping the disk contents after fdisk failure, all odd bytes had a value of 0xFF and the even bytes didn't make much sense. None of the many CF cards I have tried worked either. All the exact same failure mode. Really frustrating.
Can anybody confirm what drive/CF-card you have and whether that works with this instrument?
Offline Converter
  • Country: ua
« Reply #44 on: May 14, 2018, 02:59:39 am »
Hello everyone,
Who can answer me? This green LED "SUPPLY-CHECK", which is located at the back of the device (FSIQ3) near the power connector, should glow? Or is it a sign of a malfunction? I checked all the voltages: +12, +15, -15, +5.2, +5.5, +28. It seems that they are all in the normal range. Nevertheless, I get this glowing LED "SUPPLY-CHECK" immediately after the start of the spectrum analyzer.
Nobody has an electric schematic for this power unit? It's strange, but I did not see any tuning resistors inside for any adjustments.
« Last Edit: May 14, 2018, 03:01:27 am by Converter »
Offline sky2city
  • Country: cn
« Reply #45 on: June 07, 2018, 04:04:31 pm »
Hi PAL,
Is there anybody know how to clone the disk of ZVR?
as I know, ZVR have the same CPU card as FSEA.
The HDD of my ZVR is dying and I have to backup and clone it to another HDD.
I had tried "Selfimage" tool running on winXP and "ddrescue" tool running on Ubuntu, without lucky, both is fail.  :palm:
it error said "DISK BOOT FAILURE, INSERT SYSTEM DISK AND PRESS ENTER"
So it there anybody have clone the HDD sucessful? and it is so much thanks to whom, tell me the exactly step?
thanks advance.
Roger
« Reply #46 on: June 07, 2018, 04:20:00 pm »
ddrescue should work.. make sure you're backing up the entire disk, not just one partition. If you're just restoring one partition then the MBR (master boot record) won't be written and your target drive won't be able to boot.
There are also ways to rebuild MBR but I would rather just backup and restore the whole drive with ddrescue.
Can you list your ddrescue commands you used?
Actually, nevermind, saw it in your screenshot.
Try "parted -l" to check the partition table.. and see if the boot flag is present.
« Last Edit: June 07, 2018, 04:30:45 pm by Muxr »
Offline sky2city
  • Country: cn
« Reply #47 on: June 07, 2018, 05:22:52 pm »
Hi Muxr,
thanks for your reply.
pls. refer the pic attached, I am sure I had cloned the whold disk, given the size of ZVR HDD is 4871Mbytes.
about ddrescue command line, I just used one command, it is
"sudo ddrescue -f -v /dev/sdb /dev/sdc";
/dev/sdb is the orignal HDD from ZVR, and sdc is the new CF card, with CF to IDE transfer card.
about the boot flag, I can mount the CF card on my IBM labtop and boot it, I saw the OS loader screen, select the winNT or winNT with VGA mode. so I thinks the  boot flag is corrective.
Anyway, I will double check it again.
thanks for your reply again.
Roger.
« Last Edit: June 07, 2018, 05:57:59 pm by sky2city »
Offline sky2city
  • Country: cn
« Reply #48 on: June 07, 2018, 05:34:17 pm »
Must I format the CF card firstly before I clone it?
Or maybe the BIOS of ZVR can't recognize the CF card?
So, I want to enter the BIOS to see, if the BIOS have found the new CF card disk already.
I have a key board and mouse install in ZVR, when I pressed DEL or F2 when booting, nothing happen. I think maybe that a AWRD BIOS that customized by R&S.  :-BROKE
any idea / advice for the next step?
Roger.
Offline DaJMasta
    • medpants.com
« Reply #49 on: June 07, 2018, 05:42:21 pm »
Definitely could be, I know I've had some trouble with compact flash cards in adapters not being identified by older systems.  If Delete doesn't work, try basically any of the function keys.... there are a few keys it could be, so I usually just end up jamming as many as I can in that initial window.
« Reply #50 on: June 07, 2018, 05:48:44 pm »
sky2city.. from your screenshots it looks like you did everything correctly.
See this review for the IDE to CF adapter I was using: https://www.amazon.com/review/R1VL7K96HDXOPG/ref=cm_cr_dp_title?ie=UTF8&ASIN=B0036DDXUM&channel=detail-glance&nodeID=172282&store=electronics
This user mentions that not all IDE to CF adapters present the media as fixed to the operating system, and instead it presents it as a removable media which could pose a difficulty in booting from it.
I wonder if this is your issue, and the reason why your drive is being ignored when it comes to boot.
Here is another post talking about IDE to CF adapters not being fully IDE compliant: https://retrocomputing.stackexchange.com/a/5827
I don't know if you're able but, perhaps you could try a different adapter?
This is the one that worked for me: https://www.amazon.com/Syba-SD-ADA50024-Interface-Compact-Enclosure/dp/B0036DDXUM/ref=cm_cr_othr_d_product_top?ie=UTF8&th=1
« Last Edit: June 07, 2018, 05:53:01 pm by Muxr »
Offline sky2city
  • Country: cn
« Reply #51 on: June 08, 2018, 04:56:10 am »
Muxr,
I seached this CF 2 IDE adapter you recomended in local E-commerce, taobao.
The  saler said it's same as the adapter you recomended.
I got the pic inside and compare to the CF 2 IDE adapter I used now, it may same, just connect pins from CF card to  IDE inferdace directly. No IC inside, to hanle the data transfering. And I think so, the CF card have the same IDE inferface with HDD disk maybe.
Anyway, I would like to try it, since I have no idea to do for next step.   : (
Hope something happen, and find the root cause.
Thanks.
Roger@2018/06/08
« Last Edit: June 08, 2018, 05:08:37 am by sky2city »
Offline CJay
« Reply #52 on: June 08, 2018, 06:29:27 am »
Will the ZVR boot from a DOS floppy so you can see if the CF card is recognised (have you even got the means to make a DOS boot floppy)?
I've a feeling the problem might be the BIOS not liking the CF card itself, have you a different card (smaller perhaps) that you could put DOS files on to boot the ZVR from and prove it works
Offline sky2city
  • Country: cn
« Reply #53 on: June 08, 2018, 09:53:28 am »
Hi Cjay,
Thanks for your reminder.
I have two plan for finding out the root cause:
Plan A)
As you adviced,  I have bought a folppy 2 USB disk kits, which is same as Murx did, (refer to  Reply #12 of this thead).
then I will make a DOS boot disk , to see if the CF card can be identified.
Plan B)
Several years ago, I had a ZVR with red panel, this is a older type, which is running in DOS system.
There are 2 partitions, one of the partition is intalled DOS and a win 32 sysytem, anther partition is install a instrument software.
I replaced a ZVR disk,with a Fujitsu HDD, 30G Bits capacity.
I remember that the ZVR can identified the new 30G Fujitsu HDD, but the second partition is lost.
As a work arround, I copied all the second partition files to C:\D_Disk, and added a command  "Subst C:\D_Disk d:" to AUTOEXEC.bat,
that mean add a visual D disk running, it work fine!
Few days ago, I replaced HDD of new ZVR with blue Panel,  with the DOS HDD disk in red paneal ZVR.
I  found ZVR worked fine, and just one minor issue: the test data is a little strange, maybe caused by the wrong factory calibration data.
That means the fujitsu 30G HDD can be identified by both ZVRs, the one with red panel and another with blue panel.
I have bought Fujitsu HDD disk, just arrived today. I will try it again as I did before.
any good advice ?
I will update..... stay tuned.
Roger@2018/06/08.
« Last Edit: June 08, 2018, 09:58:12 am by sky2city »
Offline CJay
« Reply #54 on: June 08, 2018, 10:07:08 am »
Well if you can get it to boot from a DOS floppy and it recognises the CF card as a valid disk I would be tempted to try and connect the old hard disk and the CF card to clone in the ZVR with an old copy of Norton Ghost.
I found my CMU200 with the older front panel wouldn't recognise some 2.5" disks and I ended up with a 4GB CF card but it seems other members have had issues with larger CF cards too.
Offline sky2city
  • Country: cn
« Reply #55 on: June 08, 2018, 10:26:18 am »
Oh..... I have a  CMU200 too.
But one question:
How can I connect the old hard disk and the CF card to clone in the ZVR ?  There is only one IDE interface in ZVR.
should I install HDD with orignal system  and  my new CF card on a older computer? The start Norton Ghost?
« Last Edit: June 08, 2018, 10:29:40 am by sky2city »
Offline CJay
« Reply #56 on: June 08, 2018, 10:41:06 am »
If it's PC based then the IDE interface will almost definitely support two devices but you'll need a cable with an extra connector and might need to alter master/slave/cable select jumpers on the drive and CF adapter board.
The following users thanked this post: sky2city
Offline sky2city
  • Country: cn
« Reply #57 on: June 08, 2018, 11:31:15 am »
Oh....I see.
I did it ofen when I was still studied in Univercity.
Offline CJay
« Reply #58 on: June 08, 2018, 11:48:07 am »
Offline sky2city
  • Country: cn
« Reply #59 on: June 15, 2018, 10:40:32 am »
Hi Guys,
I got the solution finally. Thanks all of you.
I will post it later on. Given that the CPU fan sounds terrible, I am worry about it a lot.
I can' t find any Fan to replace it since that is a really old one.
if I can not replace the fan, I may add lubricate oil to reduce the noise from cpu fan.
Roger@2018-06-15
« Last Edit: June 15, 2018, 10:42:51 am by sky2city »
Offline sbvr4
« Reply #60 on: June 12, 2019, 11:02:06 am »
Hi sky2city,
Sorry to dig this up, but would you mind sharing your solution? I have a FSEB that is stuck booting.
Thank you,
Sbvr4
Offline OH2LIY
« Reply #61 on: June 13, 2019, 03:29:36 pm »
Hi, last time I used RPi3+PATA2USB converter to make backup/replace my HDD (NT4). Earlier I have used Partition Magic, but it's pita to use nowdays. If it helps someone I can put my notes, what I did last time:
Ramppa
apt-get install ntfs-3g
BACKUP:
ntfsclone --save-image --output backup.img /dev/sdb
Backup the BootSector/MBR:   Some guides show only taking the first 512 bytes (MBR), others show the first 63 blocks (MBR + Bootloader).
dd if=/dev/sdb of=sdb.mbr bs=512 count=1
dd if=/dev/sdb of=sdb.vbr bs=512 count=63   <--this takes all!
RESTORE:
dd if=sdb.vbr of=/dev/sdb  bs=512 count=63
ntfsclone --restore-image --overwrite /dev/sdb1 backup.img
cfdisk /dev/sdb  <-- make disk buutable!
root@shinning_new:/home/ramppa# dd if=/dev/sdb of=sdb.mbr bs=512 count=1
1+0 records in
1+0 records out
512 bytes copied, 0.0847422 s, 6.0 kB/s
root@shinning_new:/home/ramppa# dd if=/dev/sdb of=sdb.vbr bs=512 count=63
63+0 records in
63+0 records out
32256 bytes (32 kB, 32 KiB) copied, 0.103919 s, 310 kB/s
root@shinning_new:/home/ramppa# ntfsclone --save-image --output backup.img /dev/sdb1
ntfsclone v2016.2.22AR.1 (libntfs-3g)
NTFS volume version: 3.1
Cluster size       : 512 bytes
Current volume size: 2146765312 bytes (2147 MB)
Current device size: 2146765824 bytes (2147 MB)
Scanning volume ...
100.00 percent completed
root@shinning_new:/home/ramppa# ntfsclone --restore-image --overwrite /dev/sdb1 backup.img
Ntfsclone image version: 10.1
Image volume size      : 2146765312 bytes (2147 MB)
Image device size      : 2146765824 bytes
Space in use           : 528 MB (24.6%)
Offset to image data   : 56 (0x38) bytes
Restoring NTFS from image ...
Syncing ...
root@shinning_new:/home/ramppa# cfdisk /dev/sdb  <- make it bootable
   Device       Boot      Start       End   Sectors   Size  Id Type
>>  /dev/sdb1    *            63   4192964   4192902     2G   7 HPFS/NTFS/exFAT
The following users thanked this post: sbvr4
Offline sky2city
  • Country: cn
« Reply #62 on: June 13, 2019, 04:03:46 pm »
Hi sky2city,
Thank you,
Sbvr4
My solution is :
1. use corrective  TF CARD. SanDisk is tested to me.
2. use corrective TF to IDE adaptor. I recall the small card marked as AUAS is OK and cheap.
3. Use corrective software tools. those tools are tested by myself.  A)Ubuntu ddrescue  B) DD Ubuntu C) SelfImage-121(remember running in XP windows)
I attached the pic of sreccn shoot of commands that using ddrescue to backup/restore img.
Good luck.
Offline sbvr4
« Reply #63 on: June 19, 2019, 03:06:36 pm »
I have a FSEB with BIOS 3.3 that doesn't boot, 99% of the time. The hard drive was failing and I did everything stated above (CF update, RAM update), but despite multiple attempts with DD and DDrescue, it gets stuck at the same point and corrupts 4096 bits.
The odd thing is the SA will boot occasionally, usually immediately after the cpu has been removed to access the hard drive. It runs normally and passes all self-tests and calibration in these instances. Otherwise, it just hangs at "booting" with the bar spinning. This makes me think its a hardware issue more than software, but cant be sure.
Does anyone have a HDD image or firmware for BIOS v3.3? I believe v2.0 through v3.3 is compatible. Any help would be greatly appreciated.
Thank you
« Reply #64 on: June 19, 2019, 06:16:49 pm »
Here is my FSEA 30 image: http://rev.muxr.org/fsae/fsae30.tar.gz [41Mb]
Even if the version doesn't match perhaps you can dig into and see which file is corrupted. Maybe the particular file hadn't changed between versions. Hope that helps.
ddrescue has a --retry setting you could try as well, and see if that helps.
You could also give SpinRite a try. I had success in the past recovering corrupted drives with it. It's a low level utility (written in assembly) that does some fancy low level stuff to try and recover corrupted data.
It's $90 though: https://www.grc.com/cs/prepurch.htm
« Last Edit: June 19, 2019, 06:19:59 pm by Muxr »
Offline sbvr4
« Reply #65 on: June 20, 2019, 10:23:13 am »
Thank you Muxr,
I'll give that a shot tonight and report back.
Offline sbvr4
« Reply #66 on: July 01, 2019, 03:04:35 am »
Unfortunately, it seems as though I have a hardware issue. I've used the .bin provided (thank you again Muxr) and the symptoms seem to be the same. It usually boots initially, after rewriting the hard drive, but gets stuck booting on attempts afterwards. I'm not sure where to go from here. Does anyone have any suggestions on what to troubleshoot to narrow down the possible cause? Any help would be greatly appreciated.
Thank you.
Offline analogRF
« Reply #67 on: August 13, 2019, 06:56:58 pm »
Does anybody know what the Service PASSWORD is for FSEA/FSEB?
Offline rf-messkopf
  • Mario H.
    • Homepage
« Reply #68 on: August 14, 2019, 12:28:18 pm »
Try SETUP -> SERVICE -> ENTER PASSWORD -> 894129 Hz.
The following users thanked this post: analogRF
Offline analogRF
« Reply #69 on: August 14, 2019, 02:42:56 pm »
yes, R&S tech support also told me that was the password
Offline analogRF
« Reply #70 on: August 15, 2019, 12:43:46 am »
Thank you
read my posts here
https://www.eevblog.com/forum/repair/wanted-rohde-schwarz-fsea-service-floppy-disk-andor-schematics/new/#new
read the readme file in the second attachment that I posted. This is the service floppy for these analyzers and it was supposed
to be used for solving boot problems due to HDD corruption. That might help you
Offline sbvr4
« Reply #71 on: August 15, 2019, 04:44:39 pm »
analogRF that is really helpful. I'll give this a try once I can find a couple 3.5" floppies. Thank you very much!
Offline analogRF
« Reply #72 on: August 15, 2019, 05:59:09 pm »
you're welcome  :)
Give it a try and see if that helps to fix the boot issue and let us know
I have never used this service kit myself and I have not actually made those two floppies yet because my FSEA has more serious
hardware issues at the moment.
If you make those two service diskettes, could you please let me know if any of them contains the FSE_IO.EXE and GR_CHECK.EXE service routines?
These are used in troubleshooting these analyzers and I am hoping they will be on the diskette when it is unpacked.
Offline sbvr4
« Reply #73 on: August 15, 2019, 06:34:47 pm »
Will do analogRF. I'll let you know once I do.
Does anyone have the firmware update available for BIOS 3.XX? I'd like to give that a try if the repair disks don't do the trick.
Thank you,
sbvr4
Offline sbvr4
« Reply #74 on: January 20, 2020, 12:48:29 am »
Hi Muxr or anyone with knowledge regarding opt B15 computer function.
Where does the 50pin connector that comes off the processor daughter board plug in to? I ask because I wanted to add the "computer function" opt to my SA. I bought a processor board with the daughter and hard drive off of a FSIQ. I plugged the 50pin connector into X350 on the motherboard, but i get a blank display when powered on. I read that Windows NT requires an additional VGA card. Does anyone know if there is a VGA card present with this option?
Thank you,
Sean
« Last Edit: January 20, 2020, 02:12:17 pm by sbvr4 »
Offline sbvr4
« Reply #75 on: January 22, 2020, 11:33:33 am »
Update. So I think I've got it figured out. The service manual is a bit confusing as it only references the older 486 style processor w/computer function which requires a graphics card. Newer Pentium processors with the attached daughter board do not. Turns out the processor board I bought with B15 was dead. When I added the daughter board to my non-B15 Pentium processor, and swapped hard drives and it works. Now I need to figure out how to swap cal data and serial number.
BTW, let me know if anyone needs a image. Firmware 4.0 w/MSNT seems impossible to find. I also have images of 3.2 and 2.1.
Thanks for the help all.
Sbvr4
Offline sixtimesseven
    • Flickr
« Reply #76 on: January 25, 2020, 05:49:20 pm »
Sbvr4
Hi Sbvr4
I have a ZVR with Bios 3.3 which run a Windows NT 4.0. However, unfortunately the HDD has died :( I would be interested in the 4.0 Firmware with or without the instrument drivers (ZVR drivers are still available for download).
Thank you in advance :)
Andreas
Offline sbvr4
« Reply #77 on: February 05, 2020, 02:45:26 pm »
Hopefully you got your ZVR up and running Andreas
    • Flickr
« Reply #78 on: February 06, 2020, 08:34:10 am »
Yes, it works again.
Turns out the CF replacement card was at fault  |O
https://www.eevblog.com/forum/repair/rohde-schwarz-zvr-vna-repair/msg2891896/#msg2891896
Offline paul@yahrprobert.com
« Reply #79 on: June 16, 2020, 03:13:11 am »
Hey you folks!
  I've got a ZVK network analyzer that won't boot, and looking through your thread on the FSEA I notice that the CPU board looks exactly the same.
  Couple questions:
    - my unit doesn't do anything at power on.  Nothing on the screen or on either VGA port, no beeps, no blinking lights on the Floppy.  All the power supply lines are good and flat and in spec.  Anybody solve this kind of problem?
    - If my CPU board is dead, where can I find a replacement?  Some place in Germany?
Thanks in advance!
Offline jbruneaux
« Reply #80 on: September 18, 2020, 05:14:57 pm »
Hi all,
This very first message to try to answer the last post (I will later make a more complete post about the repair of a FSIQ3 unit that we had at work).
On the FSIQ that I did repair, the CPU board was also faulty (same behaviour as paul above. Power up but screen stays black and nothing else).
After some long 'reverse' of the board, I found that there's a small PIC16 microcontroller underneath the HDD (you must remove the drive and caddy). Long story short, This PIC16C has a 4MHz resonator that was dead on my board. I replaced it with a new resonator and the unit started again (more details in the post I will do to share all the things I collected during this repair).
I hope yours has the same fault (to ensure, simply sold a wire to the resonator pin next to the LT1431 SO8 chip, close to the PIC16C, and hook a scope. If there's only a flat 2.5V, then the resonator is dead).
Regards, Jerome
P.S : I'm trying to find a way to enter BIOS, does anyone succed doing this ?
The following users thanked this post: Bernd
« Reply #81 on: September 26, 2020, 10:28:51 pm »
Hi Jerome,
  Nice bit of detective work finding that bad crystal!  I had tried swapping the pentium, the memory, and checked all the voltages, but no digging like that.  But then I happened upon a cpu board on ebay that fixed it.  See my post here: https://www.eevblog.com/forum/testgear/rohde-schwarz-zvk-network-analyzer-wont-boot/msg3117922/#msg3117922
  I'm tempted to look at that crystal but I think I'll wait until something else forces me to open up that unit.  I was not able to get into the BIOS either.
Paul Probert
Offline vincenza
« Reply #82 on: January 18, 2021, 10:26:04 pm »
hello, I ask for help, I have a rohde & schwarz fsea 30, I would like to replace the hard disk because it causes problems, I cannot access the bios screen, I read in the forums that the procedure to access is: connect a keyboard and start repeatedly click the DEL key on the keyboard, but it remains still at the booting screen but does not access the bios. I ask for your help, thank you and goodbye
Offline analogRF
« Reply #83 on: January 19, 2021, 01:49:07 am »
I am not 100% sure about this but I believe you can only access the BIOS if you have option B15. They call it computer option or controller option.
That gives you a "separate" VGA output that does not show the SA screen but instead you get a WinNT or DOS computer screen.
Offline analogRF
« Reply #84 on: January 19, 2021, 03:21:24 am »
why do you need to access BIOS anyways?
I replaced my HDD with CF card and never needed to access bios.
Offline sbvr4
« Reply #85 on: January 27, 2021, 08:49:31 pm »
All,
For anyone interested in a solution in removing the old 2.5 HDD, I can confirm these will work even with older DOS 2.1 version. Best part is you aren't limited to HDD size. Mine booted just fine with a 256GB micro SD card. Ironically, its slower to boot with this conversion (even with a 2GB SD card) than the old 2.5 HDD. I'd recommend buying the card and 3D printed mount. Makes install easy. No affiliation with seller, just have personal experience and can vouch that it worked well.
Sbvr4
« Last Edit: January 27, 2021, 08:54:49 pm by sbvr4 »
Offline Bernd
« Reply #86 on: March 02, 2021, 09:13:01 am »
@ jbruneaux
Where can I find the post about the repair?
I am very interested on the details and the long story.
Regards
Bernd
Offline Extrasolar
  • Country: ie
« Reply #87 on: July 04, 2021, 09:40:47 pm »
Is there a chance that FSEA image will work on a FSEM30 ??
I have a rather disturbing problem on my unit; Its working all fine from 0 to 26.5 GHz but somehow some options are disabled or replaced by the EMI RECEIVER mode. Plus the I\Q CAL does not save the cal data on the disk because of that(I believe). Before it was doing just fine, I just added some Firmware options and somehow one of them got stuck at some eeprom memory address and wont go away  |O |O |O
Offline YetAnotherTechie
  • Country: pt
« Reply #88 on: July 05, 2021, 09:03:04 am »
I have some fsem firmware, i'm not sure if it's also for the unit you have which is latter than mine. I can only get it in a couple of weeks, and i don't know were it is, but i need to get it anyway, so when i do i'll let you know.
The following users thanked this post: Extrasolar
Offline Extrasolar
  • Country: ie
« Reply #89 on: July 05, 2021, 08:13:55 pm »
Thanks for the response. I will really appreciate it if you send me a FSEM image, it makes no difference if it is FSEM20 or 30, should work nonetheless.
Hopefully will restore the Spectrum Analyzer ...
Thanks again and kind regards !!
Offline Der_Rudy
« Reply #90 on: August 14, 2021, 09:24:38 am »
Hello you all,
I hope someone can help me with my problem.
A friend of mine had 2 FSEA 30 analyzers, an old one (version 1.63) and a newer one (3.2).
The old one was still in use so we started with the newer one to upgrade the HDD to Compact Flash.
This went with no problem at all. cloned the HDD wrote it to the 2GB CF, mounted the CF with converter board in the analyzer and booted fine.
Now it was the turn for the old version.
cloned the HDD, wrote it to the 2GB CF card, mounted the CF with converter board in the analyzer and nothing. okay, changed the converter board, nothing... changed the CF card ... nothing.
The analyzer still booting fine fron the original HDD.
Can someone help me out with this problem ??
It looks like the older bios version has no auto HDD detection or something like that.
  • Country: pt
« Reply #91 on: August 14, 2021, 05:52:11 pm »
Please find the files here, they expire in one week. https://we.tl/t-B8AkCIUenD
The following users thanked this post: N_basil
Offline Der_Rudy
« Reply #92 on: September 21, 2021, 04:12:27 pm »
Ik hope someone can take a moment to answer my question, the HDD is making more noise every day, R&S can't help with this problem anymore and I'm afraid the HDD can stop at any moment now.
  • Country: pt
« Reply #93 on: September 21, 2021, 04:15:45 pm »
Are you using industrial CF cards?
« Reply #94 on: September 22, 2021, 05:18:49 pm »
hi,
On my ZVK I replaced the HDD with a SD card solution, see this post:
Not sure it would work for you but its pretty cheap to try.
Offline N_basil
  • Country: by
« Reply #95 on: October 05, 2021, 09:38:37 am »
Please find the files here...
I hope you can help me with my problem )
I have a Rohde&S FSEM30 20 Hz-26.5 GHz. Unfortunately, it has a completely damaged HDD and I have been unable to extract information from it.
If possible, could you re-upload the disk image that you suggested in August 14, 2021?
Thanks and kind regards!
  • Country: pt
« Reply #96 on: October 07, 2021, 08:42:12 pm »
https://we.tl/t-F3BiMnmLBS
Please post if it works, original disk has 3 partitions, i don't know if this set recreates them. Did you try DDRescue? disk is 6GB but only aprox 25MB used.
Offline N_basil
  • Country: by
« Reply #97 on: October 08, 2021, 03:19:41 pm »
 YetAnotherTechie
thank you so much!!!
No, I did not use ddrescue, my HDD failed catastrophically(  |O
Please post if it works...
Yes, later on.
Offline N_basil
  • Country: by
« Reply #98 on: October 12, 2021, 08:13:29 am »
to YetAnotherTechie
Friday was a "lucky day" ) In addition to receiving a link to the update from you, I was able to successfully booting this exact file in SA:
https://disk.yandex.by/d/8KHYiPSTViZtNg
But I have not tried the update yet...
Offline N_basil
  • Country: by
« Reply #99 on: October 12, 2021, 09:07:33 am »
I will really appreciate it if you send me a FSEM image...
Let try the image I linked in the post above.
Offline Tracker
« Reply #100 on: October 30, 2021, 08:40:36 pm »
Hi Folks,
I have a FSEA 30 which was working fine up until the other day, I had it stored away for about 9 months and took it out for a show off... but...
It powered up ok and the display 'seemed' to show the boot screen but it was very gray and dull, over the next 60 seconds it gradually got dimmer and dimmer until it was completely blank.
The trigger seems to be sweeping and the other functions appear to respond to input.
I checked the CFL and it's bright as ever, and the screen still radiates light, but all the pixels are dark if you know what I mean  :P
As a basic check I re-seated the Processor and Graphics cards, re-seated ribbons, checked CFL voltage etc, but no change.
I don't believe there is a service manual available .. at least nothing showed up on the internet.
Any suggestions on how to prove out the LCD ???
Open to all and any suggestions at this stage.
Thanks folks,
Tracker
« Last Edit: October 30, 2021, 08:56:18 pm by Tracker »
  • Country: pt
« Reply #101 on: October 30, 2021, 09:22:36 pm »
http://ko4bb.com/getsimple/index.php?id=download&file=Rohde_Schwarz/Rohde_Schwarz_FSEAB_2030_Service_Manual.zip
Should be close enough. What you describe sounds like the internal supply of the lcd failing.
Offline Tracker
« Reply #102 on: October 30, 2021, 10:05:38 pm »
Thanks for the link.
I will take a closer look the LCD unit tomorrow, there are two PCB's inside under the case which probably do some form of regulation, hopefully it wont be too hard to resolve.
Watching it fail in front of me was weird, I felt a cold chill as it went dark and I just knew it was permanent.  :palm:
Cheers
Tracker
Offline N_basil
  • Country: by
« Reply #103 on: November 08, 2021, 02:02:05 pm »
I hope you watched it:
Offline Tracker
« Reply #104 on: November 08, 2021, 09:31:30 pm »
Yes thanks, watched and learned!
Offline smps
  • Country: sg
« Reply #105 on: January 10, 2024, 03:17:05 am »
do you have hdd image of 3.2  and 2.1 for FSEB? The hdd of my FSEB is dead, need an image to restore. thanks
Sbvr4
Offline dwight_talley
« Reply #106 on: February 29, 2024, 07:07:56 pm »
I just received a FSEA 30 yesterday and expect to receive a FSEB 20 later next week.  Both systems have problems, which is why I got them for a very good price.  The FSEA 30 does not turn on.  The standby light is on but turns off when pushing the power button. I have had other R&S equipment not work due to a bad power switch. I will test this switch as soon as I can get my bench setup.  Is there anything else I should look for before I remove and start working on the power supply?
The FSEB 20 does not fully boot. It shows the system going through the startup but then stops. I was told the hard drive is bad. I will see once it arrives. It has Bios 3.3.  Is there a copy of the drive software for me to use if the drive is bad?
Thanks for the info on this site. I can see how much of a pain it will be taking apart both units and working on them.
Dwight
« Reply #107 on: March 02, 2024, 06:39:07 am »
I need some info on the power switch of my FSEA 30.  The switch has been removed and another switch has been wired to the device. I am not sure that the new switch is wired up correctly. Does anyone have a diagram of where the switch is connected to on the circuit board and the function of the switch?  The standby light is on when the power is off, which is a good thing. However pushing the power switch causes the standby light to go off but nothing happens, the SA does not turn on.  I have had experience with a R&S function generator that  had a bad switch which I repaired without removing it from the circuit. This switch could be wired up incorrectly and causing a working SA to not start.
So, anyone with a diagram of the power switch setup? I have the service manual, but it does not show any schematics.
Thanks
Dwight
  • Country: pt
« Reply #108 on: March 02, 2024, 02:54:40 pm »
you can find old version of service manual online, search for:
FSEA20_FSEA30_FSEB20_FSEB30-Service_Manual.pdf
and
R+S FSEA 20 serv.pdf
« Reply #109 on: March 02, 2024, 06:19:59 pm »
Thanks for the reply.  I have all of the service manuals, they don't provide schematics for the SA.  They only show block diagrams of the circuits, which does not give me the switch wiring diagram.  I have three wires on the switch but the block diagram only shows one.
I haven't put the unit on the bench yet so no rush.  My guess is the power supply is not fully functional, since the "power supply good" light on the back is not lit, even though I have the standby light on.
Dwight
« Reply #110 on: March 08, 2024, 01:12:57 am »
Ok, The FSEB 20 has arrived.  Turning it on only get to the booting screen.  From reading the posts here, I need to replace the hard drive with a CompactFlash drive.  Software to backup the bad drive would be ddrescue.
If my drive is toast, does anyone have a copy of the software that I could restore to a new drive?
Thanks
Dwight
« Reply #111 on: March 09, 2024, 07:29:05 am »
Ok, I started working on the FSEA 30 today. It is only showing the standby LED which goes off when pushing the power button.  I removed the power supply and noticed that there were only two black wires going from the power supply to the motherboard. The thin gray ribbon cable was not there.  I thought it was strange and verified that there should be a thin ribbon cable, which has the on/off switch circuit.  Opened up the power supply and inside, was the missing ribbon cable. Now, what is the previous tech telling me? Does he not want the power supply running or does he want to keep the SA from running for some reason?  There is no note with the hidden ribbon cable.  My guess there is a problem with the power supply, why else would you open one up.  Could be he never had a chance to fix what ever is wrong and hid the switch cable until time for him to finish the work on it? Your guess is as good as mine.
I will have to look for any obvious issues with the power supply. With the Standby voltage working, 12 volts, that makes one less circuit to work on.
Dwight
« Reply #112 on: March 19, 2024, 01:02:40 am »
While I wait for parts and a break in my work schedule, I took a look at the motherboard.  I did not see any issues. I measured the battery and it was flat, so I will replace it with a new one this coming weekend I hope.
« Reply #113 on: March 20, 2024, 05:14:53 am »
Tonight I was able to do a little test of the power supply. I made all of the suggested resistor connections to the digital and analog supply connectors.
When I plugged in the power cable, the standby 12 volts was there. When I switched the power supply on, I was able to get all of the voltages for the big 3x3 block plug of the digital power supply. (5.2 and 12 volts) Good.
My next move is to measure the analog supply. The Supply check light did not turn on, so the prior tech hid the power switch ribbon cable because there was a problem with the supply.
Dwight
« Reply #114 on: March 20, 2024, 05:38:24 am »
Ok, I did not want to go to bed without knowing.  :=\   So I checked the Analog supply and found some issues with the voltages.
Pins 1 and 2 were fine at 5.5 volts
Pins 5 and 6 were not at 15 volts, varied down to 12 volts and up to 14 volts.
Pin 8 was at 15 volts and not at -15 volts where it should be.
Pin 10 was at 28 volts where it should be.
So I need to check the 15 volt section to see what is not working correctly. If anyone has any suggestions, please pass them on to me.
Thanks
Dwight
« Reply #115 on: March 22, 2024, 11:25:22 pm »
I think I have someone looking over me.  I examined visually the power supply innards and did not see anything burnt or broken. So I put it back together and powered it up one more time. IT Started up without any problems. Green power supply light was on and the fans were running. My guess there was a loose connection in the supply that I wiggled and got it working again.  So I am happy I did not have to troubleshoot the supply.  I know as soon as I said this it will not run again.
I connected the supply to the SA and hit the makeshift power button.  Nothing happened.  I removed the ribbon cable and did the jumper to start it and the SA started up, indicator lights came on.
So, I will have to determine the correct way for the power switch to be connected.  The last tech removed the switch and connected three wires going to a switch.  Three wires.  Not sure where they really need to be connected on the switch.
Next problem.  The floppy drive did a seek so something is working.  I did not see any lights on the display which I will need to look at. I wish I had a diagram to know where the power was coming from for the display.
So, so one big step forward with the power supply so I am not complaining about the display, yet.
Dwight
Online KeBeNe
« Reply #116 on: March 23, 2024, 04:01:56 am »
Thanks
Dwight
(Attachment Link)
Hey,
Windows NT4 runs normally on the FSEB.
I have made an image of my FSIQ7 and also converted it to CF.
The FSIQ7 is an FSEB30 with PC and B7 option, you can change the type of analyzer with a service command.
So if you need an image, I can give you mine.
« Reply #117 on: March 23, 2024, 04:22:57 am »
Thanks a lot.  I will take you up on that. Or can it possibly be put in the files section so others can use it?
« Reply #118 on: March 23, 2024, 04:35:21 am »
Another step forward today.  I figured out the issue with the power switch. The previous tech had tried to wire in a switch for the missing one but got lost with the wires. I spend about a half an hour to get the wires onto a new switch, the one he used was shorted. I was able to turn on the SA at will now.  Still no display but the fans are running and the floppy drive is being searched.
I took a look at the CCFL 12 volt supply and it is working. Tomorrow I will check the inverter itself to see if it is producing the required voltage.  There are many options, replace the whole setup with LCDs or buy a new inverter and bulbs.  Will see tomorrow.
Online KeBeNe
« Reply #119 on: March 23, 2024, 06:45:07 am »
the LCD's are no longer available new, what you find on ebay are refurbished ones of poor quality.
Convert the LCD to LED, which is also better for the future.
Look for 8.66 inch (220mm) LED kit, it fits very well.
« Reply #120 on: March 23, 2024, 11:06:34 pm »
Update for today.  I tested the CCFL hv power supply and it seems to be working.  I was getting sparks when I got near the output wires with my probes.  My Meter only registered 156 volts though.  Should be in the range of 600 volts.  Does not matter.  I took a look at the CCFL and determined that it was broken, thus the reason why the screen was black.  Time for a backlight change.
I decided to get two LED backlights strip kits and supply for only $12. I will just replace the CCFL with the LED strip and go from there. Too bad nothing is sold here in the states. I will have to wait for the shipment from China.
The SA is still powering on, so that is a good thing.
Dwighrt
« Reply #121 on: March 24, 2024, 04:59:24 pm »
While I am waiting for the parts to arrive, the FSEA 30 that I am working on is missing the power switch that the previous owner had removed trying to fix a problem. I have gotten the SA to work and need to find a new power switch to fill in the hole where the original button was. I am asking anyone that has parted out a SA that has a power switch sitting around looking for a new home.  I have had no luck on eBay, unless I want to buy a whole pallet of broken equipment for one switch or spend $700 for a face plate.
If not available, has anyone used a non OEM switch in the square space instead?
Thanks for checking.
Dwight
Online KeBeNe
« Reply #122 on: March 24, 2024, 07:29:50 pm »
maybe the switches from the CMD could work?
« Reply #123 on: March 25, 2024, 02:05:13 am »
I took a look for CMD and all the ones I found were working and in the $400 price range. So no, not going to tear apart a perfectly working item just for a switch. I never got a look at the switch on those anyway. I expect the switch to be different.
Offline Harry_22
  • Country: hn
« Reply #124 on: March 25, 2024, 04:14:27 pm »
Hello!
Just in case, information on how to enter the BIOS:
Connect external monitor to "PC MONITOR" and AT keyboard
2084267-0
Push and hold "BACK" button
2084243-1
Switch on the device
2084249-2
You will see following screen
Press DEL button
2084255-3
2084261-4
« Last Edit: March 25, 2024, 04:23:10 pm by Harry_22 »
The following users thanked this post: paul@yahrprobert.com
Offline Harry_22
  • Country: hn
« Reply #125 on: March 28, 2024, 11:13:30 am »
If you don't have "PC monitor" connector you can use ISA video card to connect a monitor.
« Reply #126 on: April 07, 2024, 01:14:50 am »
Ok, more steps forward.  Today I received the LED replacement for the CCFL backlight in the FSEA 30. Came in from China, a little quicker than expected.  The LED strip lets you adjust the size of the strip to fit the spot where the CCFL was. I applied a couple of small pieces of tape to hold the led in place, facing the diffusion grating, to give the best light coverage.  I then put everything in place and fired it up with a 12 volt supply. Looked great.  I then reconnected everything to the main chassis of the SA and crossed my fingers and hit the power button.  (which I still need to find a replacement for).
I had never seen what this SA would do on power up since the monitor had been broken, so I was hoping that It would at least get to the boot screen. It booted all the way to the main menu!  Man that felt great. I did a self test and it passed without any problems.  The only thing I need to do is replace the battery on the motherboard and close it back up.
Here are some photos of the unit.
The following users thanked this post: KeBeNe, KungFuJosh
Offline Bicurico
  • Country: pt
Re: Rohde & Schwarz FSEA 30
« Reply #127 on: April 07, 2024, 05:37:38 am »
I'm happy for you!
As a note: the trick for this exact problem is to hold a flashlight against the screen. This will allow you to kind off see what is going on. Had you done this, you would have know that the SA is working. But this way the surprise was bigger.
