Author Topic: Anritsu MS2721B internal CF card missing  (Read 3141 times)
Offline brainstorm
Re: Anritsu MS2721B internal CF card missing
« Reply #25 on: October 26, 2020, 01:13:53 pm »
Alright, @AnalogRF, my bad.
I hope that the attached photo is much clearer. I annotated the "clean" outputs of the coils as Shariar did in his video with postits (for the "A", mine is "B" series). Here's Shariar's postits for reference:
https://www.eevblog.com/forum/testgear/anritsu-ms2721b-internal-cf-card-missing/?action=dlattach;attach=1096304
My intention was to supply some of the voltage rails on both sides of the coils, but I understand that the switching (MOSFET, or more specifically [LT1765](https://www.analog.com/media/en/technical-documentation/data-sheets/1765fd.pdf) side is not helpful and it looks like healthy switching anyway so not very informative overall.
Please ignore the 535mV figure, that's just the DC Vpp measurement, that's also confusing, sorry about that.
Also, the DC barrel jack has an input voltage range of 12-15V DC, that's why I was confused with your 12V rail... that's just V_SYS, also seen in some of the coil inputs.
In any case, at least 4 of those coils are off... do you think that's a product of the power sequencing/early boot or is some rail is cooked?
The 15-0V postits (2 of the coils) indicate that there is 15V (barrel jack input) present in one side and 0V on the other side.
« Last Edit: October 26, 2020, 01:22:38 pm by brainstorm »
Offline analogRF
« Reply #26 on: October 26, 2020, 01:51:59 pm »
1-did you check all the "test points" (not just the coils) that are marked on the board with various voltages? there are a few test points outside the PSU section for 3.3V and 1.8V and I think a couple of others, too. Those must exist in order to boot.
2-do not inject power to the coils from outside! you can try to supply outside voltage if you desolder the coil first and then use a current limited supply and slowly increase the current limit to check but if there are several rails missing, this becomes tedious...
3-what do you mean by "15-0V" in those stickers?
4-why are there no negative voltages anywhere? I remember there were one or two negative rails in there.
5-those rails that are zero, did you check for any shorts in their outputs? or in their mosfet and diode?
usually it is unusual that 4 rails fail at the same time together but as I recall some rails were the primary for other rails, so if one fails, 1 or 2 others may fail as well. With the help of datasheets you should be able to trace each dc-dc converter to its source/primary.
6-w.r.t. your last question, I wish I could remember exactly how the rails behaved but as far as I remember those power rails under the hood
were present right after power on (maybe except for charging) but the 24V which is marked somewhere outside the shield (near the ribbon connector) will turn on much later. so I believe the voltages under the shield should be present during boot. Now if they are dead, it's either a short in their load or a defect in the dc-dc converter itself.
I would start by checking each dc-dc converter separately from its input to output by following their datasheet. I think some of them had shut down for over current protection and if you look at datasheet you can check if over current has happened
I will try to locate my pictures of the ms2721b which I had taken with voltages written on them. I cannot find them in my laptop so
they are probably on one of the ssd backups... but i remember it was similar to what Shahriar had shown but with a little more detail
Offline brainstorm
« Reply #27 on: October 27, 2020, 11:31:35 am »
Thanks for the advice and pointers!
1- Yeah, 3V3, 5V0 and 1V8 are also present on silkscreen marked vias.
2- Not yet, I will poke at the SHDN (Shutdown) pins for the LT1765's and see if other ICs are keeping those deactivated (or if they are blown or inactive via some other legitimate means).
3- 15V on some of the pins, 0V on the rest... so you can take those as effectively 0V output I reckon, need to study the LT datasheet and see what's going on with those.
4- Good question! the -15V0A rail is not present (0V)... but I guessed that rail just comes later on when powering up RF deck(s)?
5- I checked all diodes with the multimeter and they seem fine, I will proceed checking the LT1765 and LT1377's and their surrounding components next.... if there was a short somewhere, I guess that this thing wouldn't just consume 350mA and there would be something getting hot?
6- I hope it's indeed an overcurrent condition from some of the passives because otherwise I'll have to see how the TI IC immediately on the back of the board (TI TY1543) monitors and controls all of the LT's on the power supply can... a bit of a rabbit hole there, I hope I can find the fault sooner than that :)
Offline analogRF
« Reply #28 on: October 27, 2020, 11:52:51 am »
2-monitor the on/off pins of LT1377(s) and LT1765(s) "during the boot" with oscilloscope to see if and when they are on line.
3-just measure the pin that goes to the big filter capacitor. I think those rails are OK
4-as I remember it, voltages under this shield were all present at the beginning. The voltage for RF deck that comes on much later is a 24V
5-....no, not necessarily. Simply check the resistance to ground at those power rails that read 0V to see what might be going on
try to power it on with the RF deck disconnected. In a normal unit, it will boot.
Offline brainstorm
« Reply #29 on: October 29, 2020, 04:26:29 am »
Thanks @analogRF,
I re-checked the rails as you indicated (via the output cap instead of the coils), I hope it makes a bit more sense now, I've attached an updated post-it screenshot.
2- I monitored the two "unresponsive" rails on power-on but there's little difference in the S/S or SHDN pins (LT1377 and LT1765 respectively)... the input is just 0V while on the working rails it reads somewhere in between 1.9V and 3.7V, which seems to match the spec.
3- The two non-postit-labeled rails: upper -15V and lower unknown (since I cannot see any nearby silkscreen indicating expected voltage) are totally silent... but since both are driven by different buck/boost ICs, I find it weird that it's not driven by external signals? I mean, I find it unlikely that both rails have failed at the same time... sounds more like a power sequencing/firmware/other_ICs issue?
4- I would very much appreciate that image in your backups to know which voltages should be present :)
5- Both IC series seem to be on the Mega-Ohm ranges (and both "healthy" and non-working show similar values) according to my multimeter.
I have *everything* disconnected, it's just the bare board sitting on the desk with no screen/backlight circuit/tweeter or anything else.
I followed the SHDN traces for the LT1765 to see if having ~3.3V present there would "wake up" the IC, but no switching activity happens on the other pins... I'll brainstorm a bit on what to do next, but followup suggestions/thoughts and info are super welcome! Thanks for the attention and effort, this is fun :)
« Last Edit: October 29, 2020, 04:30:28 am by brainstorm »
Offline brainstorm
« Reply #30 on: October 29, 2020, 04:45:25 am »
I'm also attaching a picture clarifying a bit my thinking while the tracing of the LT1765's SHDN signal (in red, following it via both sides of the board). Since it was 0V on that pin, I tried "bridging" (direct blue line) it with a wire in an attempt to "wake it up" (unsuccessfully). Here's the datasheet for that component:
https://www.onsemi.com/pub/Collateral/NC7SZ14-D.PDF
It just converts that curvy waveform into a square one by the looks of it... thinking it through that was not a good idea since the healthy rails show a 2.5-3.3V **constant** DC voltage fed on that particular pin and IC (LT1765). On the other hand, I noticed that my "injected" 3.3V input signal got attenuated to around 1.9V, so that makes me think that the line is being actively pulled down somewhere else in the circuit, probably via firmware/software.
« Last Edit: October 29, 2020, 04:53:08 am by brainstorm »
Offline analogRF
« Reply #31 on: October 29, 2020, 03:58:50 pm »
your lucky day  :D ;)
I found my stash of photos when I was troubleshooting and gathering notes on this device.
Here are the pictures that I had taken and annotated at that time.
Strangely the -15V never comes on. maybe it is used with some options like GPS or something....
anyways, I hope this helps
based on my notes, all rails start right at the beginning except the 24.6V which comes on only a short time after power on (still during boot process)
and -15V never came on.
I think the unit will not boot at all if you disconnect the screen, too. at least have everything connected except maybe just the RF deck
even without RF deck it does not boot as I just learnt from my notes. I was under impression that it booted without RF deck but apparently it didnt
Offline analogRF
« Reply #32 on: October 29, 2020, 03:59:55 pm »
...more pics...
Offline analogRF
« Reply #33 on: October 29, 2020, 04:07:53 pm »
based on what I just posted, I think your PSU rails are probably ok. You are stuck very early in the boot
and most probably the problem is somewhere else...maybe the RAM chips...
what exactly are the symptoms? what do you see on screen when you power it on?
Offline brainstorm
« Reply #34 on: October 30, 2020, 02:42:02 am »
Woah, thanks for those pictures and hints @analogRF!
I went through all your annotations and all of them cross-check right on my end **except** the -6.1V **and** the one that has an annotation down below stating that "comes on after a few seconds of power on. not right from beginning"... I suspect that the latter supplies power to the "RF mini-deck" (not the big RF deck instrument half), so I'm not too surprised now that it's not powering on yet since it might be too early in the boot process.
Also, I went ahead and hot-gunned and substituted the RAM ICs with fresh ones I had on stock (see attached), to rule out faults there... same effect, unfortunately, but at least I can now state that it seems unlikely to be a RAM's fault.
This instrument used to work and indeed it hung up on the "Application started" you point out, with working screen and all. The number of "successful boots" up until that "Application running" point decreased until the current situation: **you can see the pixels of the screen getting "active", but no backlight illumination nor any pattern or image"**... this behavior seems consistent with a slowly dying flash memory perhaps? I've heard Teslas go black screen due to dead eMMCs :P
In any case, all those tests we went through, plus thits last IC swap and your images gives me very valuable information:
1) The fault is **VERY** early on the boot process.
2) The processor works fine, clocks and address lines on the RAM are asserted but there doesn't seem to be data/activity.
3) The RAM ICs do not seem to be the main issue and power consumption remains the same pre/post RAM IC swap, that is ~300mA @15V DC.
For the reasons stated above I'm tempted to believe that the next most likely candidate for troubleshooting could be the Flash ICs (256P30T) since the program might not be successfully read anymore and copied to the RAM perhaps?:
https://www.dataman.com/media/datasheet/Intel/P30Family.pdf
https://www.aliexpress.com/item/32838590465.html
I would like to be extra sure that this is the next step though since a 64 "easy" BGA package can be a bit of a pain to work with :/ So I went ahead and looked at the datasheet above and noticed that there's a silk screen near the 256P30T IC marked as "WAIT" with a VIA, which seems to be a prominent signal for this IC according to the datasheet since on page 20 of the P30Family.pdf it states that:
In synchronous array or non-array read modes, WAIT indicates invalid data when asserted and valid data when deasserted. In asynchronous page mode, and all write modes, WAIT is deasserted.
Probing it with the oscilloscope, it seems like it is asserted (high) all the time at 3.3V... there could be many other glue logic involved here, but I'm trying to think this out loud, feedback welcome as always!
« Last Edit: October 30, 2020, 02:46:23 am by brainstorm »
Offline analogRF
« Reply #35 on: October 30, 2020, 03:03:04 am »
No, I was not talking about those two RAM chips. I have yet to see them fail in these units. The RAM chip that I had to replace once (also Shahriar replaced in one of his videos) was one of those 6 chips that are on the lower right side of the board (top and bottom side).
i think there was more DC=DC converters on the backside. you can check them too. I have no picture. If there is no backlight, you should check the inverter and its input voltage.
flash chips would be the very very last thing I would touch really. besides I am sure there must be a serial console port somewhere on this board
I tried a little bit to figure it out but I gave up. If you can find that, you can probably force it to boot from a usb or tftp and bring it back to life
if it is indeed the flash corruption. yours seems to stop very early, so i dont think you still have LAN activated but it's worth checking
if you can telnet to it.
by the way, have you tried to power it on in recovery mode as per service manual?
But the symptoms you describe, point to a hardware failure rather than a flash corruption which I consider a software failure. So I would stll investigate hardware issues like other DC DC converters and RAM chips
Offline codex0
« Reply #36 on: October 31, 2020, 10:50:51 pm »
Could you describe the instrument behavior and how you diagnosed the RAM chip as bad in your case? Shahriar's chip was hot and the unit did not boot fully, I'm curious to know if yours was the same or different in both identifying the bad chip and how the instrument behaved.
Offline brainstorm
« Reply #37 on: November 01, 2020, 12:39:22 am »
@analogRF: those SRAM chips you mention (6 of them on one corner and both sides of the board, near the DSPs) were fine when the instrument was functioning and going all the way towards "Application loaded!"... I did buy and substitute all them by fresh SRAM ICs (3 on each side) and the result was exactly the same: all good all the way up to "Application loaded" (with or without RF deck attached)... so those are also unlikely to be the issue either I guess :/
The Ethernet port is the one I was using back when the instrument was working and how I wrote my initial blogposts as well (dumping the RAM via metasploit against VxWorks debug functionality w/ telnet):
https://blogs.nopcode.org/brainstorm/anritsu-ms2721b-spectrum-analyzer-repair-part-2/
At present, ethernet's link doesn't go up at all, I bet it doesn't even reach anywhere near the so-called "emergency mode" (TFTP) either... and USB software recovery never worked either back then, actually. I have not poked serial ports on the SuperH4, but I doubt I can get anything meaningful there either, it very much seems like pre-boot electrical issue, but I'll check them out anyway.
Yes indeed, no effect :/
When you say "other DC-DC converters" do you mean those inside the PSU can or elsewhere?
@codex0: The ICs were never hot as Shariar's video. When I received the instrument I substituted those ICs almost right away because I suspected that it was a common fault mode, but it doesn't seem to be the case with mine :-S
The current behavior is 15V@300mA on power on, pushing the button next to the red LED turns in on (according to ON_OFF_FLAG silkscreen via next to the RAM ICs, going from 0V to 3.3V). Pushing that button does NOT turn the screen's backlight on, but you can see how *all* pixels change (from default "off yellowish" color of the screen to a darker color as a result of the pixels being turned on). That's all really, unfortunately :-S... under the hood it's interesting because most of the rails are up, reasonable signals are happening all across the board but there's something buggering it all XD
Thanks much for following along, much appreciated ;)
Offline analogRF
« Reply #38 on: November 01, 2020, 01:06:16 am »
those chips are 512Kx8 byte 3.3V SRAM. It's a tedious work really but in my case I monitored the chip control pins (CS,  OE, WE) along with data bits (I/O) and address bits (4 channel Lecroy 2GHz scope with AP020 FET probes)
and luckily on the second chip that I tried I noticed the data coming out of the chip in read cycles looked very crappy (well others didnt look good either but on this one the data was very crappy). but for that you really need very low capacitance probes otherwise the signals look very bad no matter what
Offline analogRF
« Reply #39 on: November 01, 2020, 01:10:48 am »
oh OK, I didnt know you had replace those SRAMs already. Let's hope they are indeed all OK though.
No, I meant I think there were some more DCDC converters on the back of the board. I cannot remember exactly. I might be wrong
the fact that you do not have the -6.1V (which is designated by -5V8 on the board and in the instrument self test) might be a clue.
as I said, all rails except that 24V come online right after power on. Even 24V comes on very shortly after (even with no RF deck attached)
