I would like to ask about the capabilities of the R&S SFU with option K35: ARB generator and option K37: Interferer management. My question concerns the document "Digital dividend: testing of TV receivers":
https://www.rohde-schwarz.com/sg/applications/digital-dividend-testing-of-tv-receivers-application-card_56279-12352.htmlIt states that the interferer signal can be played using the ARB generator. The document states that the I/Q file can be played in R&S format or generated by "R&S®WinIQSIM2" - in this case the corresponding option is needed - for LTE signal e.g. R&S®SFU-K255.
If I would like to play e.g. LTE signal in the ARB generator without the corresponding option K255, is this possible if the I/Q file is in R&S format? Is it possible to synthetically generate such a file or is it possible to upload it?
Thanks....
