Products => Test Equipment => Topic started by: KungFuJosh on May 04, 2025, 10:57:35 pm
Title: Rohde & Schwarz SML Series Signal Generators - SML01 SML02 SML03 SMV03
Post by: KungFuJosh on May 04, 2025, 10:57:35 pm
This weekend I got an R&S SML03 to play with. So far, I like it:
(https://www.eevblog.com/forum/testgear/rohde-schwarz-sml-series-signal-generators-sml01-sml02-sml03-smv03/?action=dlattach;attach=2560470;image)
I cleaned it up a bit, and it looks a lot nicer now. I opened it up and dusted it with some compressed air, and attacked the fan also. That helped reduce the fan noise a little, but it's still a loud ass fan.
Signal quality looks good, and it's pretty darn close considering it hasn't been calibrated since March of 2007. A 500MHz signal shows 499.9995MHz on my SDS2504X HD. 100MHz shows as 99.99990MHz. 10MHz shows as 9.999989MHz, which is about what the internal reference showed over an extended period of time. I may try to do a small adjustment.
Here's some useful info for the series:
Stock Fan: 622N EBM-PAPST
12V DC, 160mA (SML service manual specifies 12V, 170mA max)
Passwords (use at your own risk):
LEVEL 1 Password: 123456
LEVEL 2 Password: 261339
LEVEL 3 Password: 710845
LEVEL 4 Password: 593748
From the manual:
Password 1 deactivates the lock for the calibration of Main Loop, Level Preset, LFGen Level, Leve,
IF Filter, Harm Filter, Mult Filterl.
Password 2 deactivates the lock for the calibration of RefOsc.
Password 3 factory internal
Password 4 factory internal
ETA: I've attached the final firmware version 2.51.15 (with permission) for the SML series. USE AT YOUR OWN RISK!!! It requires a 32bit Windows version to be installed. It took 24 minutes to install for me.
ETA2: Power supply model LPQ154 datasheet added.
ETA3: Maintenance manual section including error codes added.
Thanks,
Josh
Title: Re: Rohde & Schwarz SML Series Signal Generators - SML01 SML02 SML03 SMV03
Post by: KungFuJosh on May 04, 2025, 11:00:35 pm
The only defect thus far appears to be a couple horizontal lines that aren't supposed to be there. This appears to be common with these.
Anybody know any tricks to fix those lines without replacing the screen?
I don't know what causes them, but there's a 3rd line that only appears occasionally, and I haven't seen it yet since dusting this thing.
Thanks,
Josh
ETA: Service manuals attached.
Post by: KungFuJosh on May 04, 2025, 11:24:30 pm
I'm not a fan of the stock fan, and I'm considering replacing it. It's a simple two wire connection.
Here's the specs:
Operating voltage: 8-15V DC
Fan dimensions: 60x60x25mm
Fan efficiency: 40m³/h (~23.5CFM)
Noise level: 35dBA
Rotational rate/speed: 6100rpm
https://www.ebmpapst.com/us/en/products/compact-fans/axial-compact-fans/p/622N.html (https://www.ebmpapst.com/us/en/products/compact-fans/axial-compact-fans/p/622N.html)
What do you think about their air performance curve chart? I wish it specified the voltages on the chart too. Is 40m³/h happening at 12V or 15V?
I was thinking about using this as a replacement:
Noctua NF-A6x25 FLX
12V DC, 80mA
Operating voltage: 12V DC
Speed: 3000 RPM
Airflow: 29.2 m³/h (~17.7CFM)
Noise level: 19.3 dBA
The CFM difference is less than 6. Is 6CFM enough to worry about? The significant noise drop would be nice.
Thanks,
Josh
Post by: KungFuJosh on May 04, 2025, 11:39:05 pm
I think it's cool that the SML can do two three modulations at once.
Here's a 500MHz sine:
(https://www.eevblog.com/forum/testgear/rohde-schwarz-sml-series-signal-generators-sml01-sml02-sml03-smv03/?action=dlattach;attach=2560502;image)
Here it is with FM modulation:
(https://www.eevblog.com/forum/testgear/rohde-schwarz-sml-series-signal-generators-sml01-sml02-sml03-smv03/?action=dlattach;attach=2560506;image)
Here it is with AM modulation:
(https://www.eevblog.com/forum/testgear/rohde-schwarz-sml-series-signal-generators-sml01-sml02-sml03-smv03/?action=dlattach;attach=2560510;image)
Here it is with both:
(https://www.eevblog.com/forum/testgear/rohde-schwarz-sml-series-signal-generators-sml01-sml02-sml03-smv03/?action=dlattach;attach=2560498;image)
Thanks,
Josh
Post by: tautech on May 05, 2025, 01:24:56 am
Amplitude modulation sweep too ?
SSG3021X can do and you can set up some eye catching effects for exhibitions.
You have to do a video to really show that effect.
Post by: KungFuJosh on May 05, 2025, 01:45:23 am
I'd love an SSG3021X. Send me one! 😉
Post by: KungFuJosh on May 05, 2025, 01:47:13 am
Holy Shit, Batman! I love how easy it was to adjust the calibration with this. 🤯
You activate the Adjustment State by setting it on, and then modify the Frequency Adjust setting. That's it. It was set to zero. I connected it to the counter on my SDG2122X and adjusted it there:
(https://www.eevblog.com/forum/testgear/rohde-schwarz-sml-series-signal-generators-sml01-sml02-sml03-smv03/?action=dlattach;attach=2560560;image)
(https://www.eevblog.com/forum/testgear/rohde-schwarz-sml-series-signal-generators-sml01-sml02-sml03-smv03/?action=dlattach;attach=2560556;image)
Now the waveform counters are all spot on:
Adjusted reference output from SML03:
(https://www.eevblog.com/forum/testgear/rohde-schwarz-sml-series-signal-generators-sml01-sml02-sml03-smv03/?action=dlattach;attach=2560564;image)
10MHz RF Output:
(https://www.eevblog.com/forum/testgear/rohde-schwarz-sml-series-signal-generators-sml01-sml02-sml03-smv03/?action=dlattach;attach=2560568;image)
500MHz RF Output:
(https://www.eevblog.com/forum/testgear/rohde-schwarz-sml-series-signal-generators-sml01-sml02-sml03-smv03/?action=dlattach;attach=2560572;image)
Thanks,
Josh
Post by: KeBeNe on May 05, 2025, 04:14:27 am
HI,
try to install an original fan or at least a fan with the same values.
The R&S devices get very warm internally, the Noctua fans are nowhere near the static pressure.
The components usually die slowly due to the heat (in my experience)
You can also look at Sanyo Denki, they also make good fans.
I like to use them and if possible with more thickness, they can build up more pressure with the same noise.
the SSG3021x have a bad phase noise and only go down to -110dbm level, the SML goes down to -140dbm, the phase noise is ok so far, not high end, but normal for the class. (this was/is the “beginner low budget” class)
If you can find the calibration software (service kit) somewhere, I would be grateful if you could pass it on.
Post by: KungFuJosh on May 05, 2025, 05:33:10 am
There's a 25% difference in airflow between the two fans at their stated specs. I'm curious what the stock fan actually runs at though, since it states operating voltage up to 15VDC, and the SML runs it at 12V. I might try a photo tachometer or stroboscope or something to see what the real RPMs of the stock fan are.
Regarding static pressure, I don't really understand that part too well, and the actual airflow/RPMs are still in question with the stock fan. So here's my question: what's the real difference? Stock fan air performance chart says at 30 m³/h, static pressure is under 0.1in H₂O. The internet supplied conversion chart says that's a little bit over 2mm H₂O. The Noctua fan is rated 2.18 mm H₂O at 12V. Seems close to me?
Thanks,
Josh
Post by: Martin72 on May 05, 2025, 04:21:11 pm
I am responding to this post here because it fits better here.
https://www.eevblog.com/forum/testgear/siglent-sds2000x-hd-12bit-(published-for-chinese-domestic-market-only)/msg5904862/#msg5904862 (https://www.eevblog.com/forum/testgear/siglent-sds2000x-hd-12bit-(published-for-chinese-domestic-market-only)/msg5904862/#msg5904862)
10kHz: 208.6mV = -0.603414 dBm
100kHz: 179.4mV = -1.913251 dBm
500kHz: 131.8mV = -4.591392 dBm
1MHz: 122.1mV = -5.255387 dBm
10MHz: 143.36mV = -3.86114 dBm
100MHz: 122.9mV = -5.198662  dBm
500MHz: 98.5mV = -7.120975 dBm
Phew... :phew:
Is there another filter active, do you have another filter in between? ;)
There should be a self-test, what does it say?
Which output are you connected to?
Post by: KungFuJosh on May 05, 2025, 05:19:21 pm
Phew... :phew:
I'm not using any filters, or terminators. 50Ω termination is set in the scope as usual. The SML03 has auto level correction (called ALC in the menu system).
It's my understanding that ALC is supposed to apply the calibration settings for different ranges. It makes little to no difference whether this setting is on or not. Turning off ALC gives the option of either applying a correction Table, or Sample&Hold. Neither improved the level in any interesting kind of way.
ETA: There is an Attenuator listed in the settings. That is either set to auto or fixed range, and the fixed range is preset and can't be edited. Neither option does anything when tested at a fixed frequency.
There is a Ucor (User Correction) setting I want to try out, but I need to be able to accurately measure and correct this at least up to 1GHz for it to be meaningful for the bw test. I obviously can't do that with my 500MHz scope. So how can I test this accurately? My DAQ6510 seems to be the best option, but I'm not sure if that's sufficient either. Do I need a power meter?
Thanks,
Josh
Post by: Martin72 on May 05, 2025, 05:40:23 pm
Its bandwidth will not be sufficient for this.
"Unfortunately", my SML had been functioning properly in this regard, so I am unable to offer any additional assistance beyond general tips such as using the correct output (RF not LF, then switch on RF in the menu as well) and performing a factory reset. :-//
Post by: KungFuJosh on May 05, 2025, 05:53:19 pm
That's what I figured regarding the DAQ. I'm not sure what power meter would be sufficient, but maybe I'll attack eBay...or see how much cal/adjustment would cost.
The LF output is DDS that only goes up to 1MHz. I've also done a factory reset.
Thanks,
Josh
Post by: KungFuJosh on May 05, 2025, 11:45:20 pm
With the output level set to +5 dBm, this is what it looks like on my scope. A level adjustment should take care of things nicely. Last calibration was in 2007, so there's that.
Post by: KungFuJosh on May 06, 2025, 12:13:11 am
Interesting! I found the level calibration list that was in use. That's exactly what the problem is. The Level cal table is 18 years old, and the values are stupid. 🤣
Post by: KungFuJosh on May 06, 2025, 06:39:35 am
I got the last firmware installed (was 3 versions behind), but it's a 16bit app with a 32bit installer. So WineVDM was useless (it can theoretically run the 16bit app, but can't touch the 32bit installer). I had to find an app to install 32bit Windows on an external drive so I could run it from my wife's old laptop that I'm not allowed to format.
It took 24 minutes to update the firmware, which was hilarious because the SML says FASTLOAD on the screen the whole time. I don't want to know how long SLOWLOAD would have taken! It's a good thing I'm patient sometimes in my old age. 😉
Thanks,
Josh
Post by: pdenisowski on May 06, 2025, 10:33:13 am
 :-DD
Post by: KungFuJosh on May 06, 2025, 03:50:23 pm
After running the firmware install, the internal calibrations were cleared (as expected). What's interesting is that in clearing those level lists, it's already a lot closer to 0dBm, and more linear...except for a few frequencies that put out nothing. 🤔
I haven't run the auto calibrations yet; I'll do that soon.
Right now, I've unlocked Level 2 so I can do the 10MHz ref calibration (without using the user override option). The SML warmed up for over an hour, and it seems stable enough.
Final firmware added to OP.
Post by: KungFuJosh on May 06, 2025, 04:11:46 pm
(https://media.tenor.com/rcZMAz3r-fQAAAAM/borat-very.gif)
Well, that worked!
After installing the new firmware, calibrations cleared, ref adjusted, then running calibrate all- it's MUCH better.
It's pretty stable at 220mV (within -1mV) from 9kHz all the way to 100MHz. Then it drops as follows:
200MHz 213mV
300MHz 201mV
400MHz 191mV
500MHz 176mV
600MHz 136mV
I don't have a proper RF power meter to determine whether that's the scope's limitations or the sig gen, but I assume the former or a combo of both. I might need to get me an RF power meter now lol.
Thanks,
Josh
Post by: Martin72 on May 06, 2025, 04:19:01 pm
Congrats... ;)
Now do a sweep....
By the way:
500MHz 176mV
600MHz 136mV
That could be right; the -3dB point of the scope is somewhere between the two frequencies.
Taking 220mV as a basis, that would be 220mV* 0.707, or approximately 155.5 mV.
Post by: Grandchuck on May 06, 2025, 04:21:46 pm
Have you tried other coax cables ... I find they vary some at the higher frequencies.
Post by: KungFuJosh on May 06, 2025, 04:35:28 pm
Congrats... ;)
Now do a sweep....
Thanks! It's running now. 😉
That's what I assumed...and why I put an offer on an RF power meter. 😉😉
Post by: KungFuJosh on May 06, 2025, 04:38:41 pm
Right now I'm using an RG316 BNC cable with a type N to BNC adapter. I'll also try a cable that's coming this week that's RG142 type N to BNC (no need for adapter), and I'll try an RG58 BNC cable with the N to BNC adapter.
Post by: KungFuJosh on May 06, 2025, 04:58:05 pm
Does anybody else have any thoughts on this? I have an RPM tester coming today. I'll see how fast the stock fan is actually running.
Post by: KungFuJosh on May 07, 2025, 10:44:11 pm
Stability of the internal ref seems okay.
(https://www.eevblog.com/forum/testgear/rohde-schwarz-sml-series-signal-generators-sml01-sml02-sml03-smv03/?action=dlattach;attach=2562406;image)
ETA: Updated photo.
Post by: KungFuJosh on May 08, 2025, 04:39:30 am
I think this is the first time I've ever used the TinySA for something besides it's signal generator. 🤔
Post by: KungFuJosh on May 08, 2025, 06:16:14 pm
Well, I answered my own question about fan speeds. See attached.
At 12V, the stock fan is indeed twice as fast.
At 15V Noctua goes up to ~3558, which the stock fan beats at 8V.
So which one cools more efficiently?
According to my thermal camera, the peak temperature was 100F with the stock fan after hours of running. Currently, the Noctua is holding around 97F after a little over an hour. I'll update in a few hours to see how it looks with the thermal images.
The Noctua fan does not sound half as loud. I might use a dB meter app on my phone to compare, but we'll see. It sounds smoother for sure, but the overall volume change isn't amazing.
Thanks,
Josh
ETA: I tried two different apps on my phone, and both say the fans are about the same dB level. The stock fan has a higher pitch noise, that is more annoying than the Noctua fan, but they're definitely close in volume level either way. The Noctua fan has the softer/consistent Noctua sound, but is louder than I expected it to be.
Post by: KungFuJosh on May 08, 2025, 11:22:26 pm
Final verdict: Not worth the hassle, general waste of time...but still entertaining.
The pitch of the stock fan is slightly higher, but overall seems quieter, despite the piece of crap sound meter app I downloaded thinking they're the same level. I measured both fans in and out of the SML.
Difference in temperature performance is also nothing special in either direction. Max temp with the stock fan was 100.4F, and it was within half a degree over a 5 hour period with the Noctua fan.
I wonder if the voltage of the fan is regulated based on internal temp? That could explain why the Noctua was louder than expected if it was running higher voltage to make up for the temp difference. 🤷
Post by: pdenisowski on May 12, 2025, 12:22:02 pm
The stock fan has a higher pitch noise, that is more annoying than the Noctua fan ....
If you wait long enough, higher pitch noises won't annoy you nearly as much as they do now  :-DD
Thanks for all the great write-ups!
Post by: KungFuJosh on May 12, 2025, 03:51:21 pm
I got another SML03, and the stock fan is much better; quieter and no high-pitch noise. So it looks like replacing with a new stock model fan is the best option (besides getting older faster). 😉
Post by: KungFuJosh on May 12, 2025, 03:55:55 pm
Here's a couple photos of another SML03 I got this weekend. This one has the B1 OCXO and B3 Pulse Modulator options.
It also has a defective output unit. I put the output unit from my other SML03 in it, and it worked (then I put the original back in). I'm suspicious there might be something wrong with the B3 module also, but I will figure that out later.
If you're looking for an SML, pay attention to the photos. I've seen some advertised as having options that were clearly not installed.
Thanks,
Josh
Post by: KungFuJosh on May 12, 2025, 04:00:59 pm
Here are some photos of the allegedly defective output unit. Nothing jumped out at me for obvious issues.
Post by: Martin72 on May 12, 2025, 04:17:28 pm
Is the red circle the output?
Then it should be some kind of relay.
The yellow mark looks like a suspicious solder joint.
(https://www.eevblog.com/forum/testgear/rohde-schwarz-sml-series-signal-generators-sml01-sml02-sml03-smv03/?action=dlattach;attach=2565088;image)
Post by: KungFuJosh on May 12, 2025, 04:36:06 pm
Good eye. Yes, that's the output, and it does look like a broken solder joint in the photo. I hope it is! I just reviewed the microscope video I made looking over the board, and that's the one spot I missed. 🤦
The reason I say I hope it is, besides being an easy fix, is that the coating they put on isn't smooth and creates misleading shadows.
Time to disassemble again. 😉
Thanks,
Josh
Post by: Martin72 on May 12, 2025, 04:45:03 pm
I don't know if you can access it while it's running, but you could measure at the input of the “relais” to see if the set signal is still arriving correctly.
Post by: KungFuJosh on May 12, 2025, 05:27:22 pm
It was the ugliest solder joint for sure, but it didn't look broken from other angles. I cleaned it up and resoldered it anyway.
The writing on the part didn't bring anything up for replacement. 5000-0266 C0T0-0815 M? Anybody know what this is?
ETA: My uneducated guess is that this is the only mechanical part on the output unit, and the most likely thing to die without any signs of stress. Despite looking much nicer/newer than the other unit, this one has currently 4410 hours of use.
Post by: Martin72 on May 12, 2025, 08:11:02 pm
That's still brand new; my SML01 had over 100,000 hours on it. ;)
(No  joke)
Post by: KungFuJosh on May 12, 2025, 08:33:46 pm
(No  joke)
Good to know! 😉
I've decided to sacrifice parts from the 1st unit for the 2nd one. I can worry about fixing the 1st one or sell it for parts later.
Post by: Martin72 on May 12, 2025, 08:55:41 pm
Either way, you would then have an SML03 with OCXO reference that looks almost new and has very few operating hours, which is pretty cool....
Post by: KungFuJosh on May 12, 2025, 09:06:15 pm
Exactly. I already swapped it, and it's warming up now so I can calibrate it again (I pulled the battery to force recalibration and wipe the old data).
Before calibration, it outputs 100MHz as ~102.4MHz. After cal, it will show 100.0000MHz on the scope.
Post by: KungFuJosh on May 13, 2025, 08:54:03 pm
I've got the mix of parts in unit 2 now, and it's working great. However, I needed to remove the SML-B3 option (pulse modulation).
I haven't popped the B3 open yet, but something is wrong with it. After running the self calibration with B3 present, the output is too high. After correction, the output is still nearly 50mV too high. Removing the B3 and changing nothing else (not even recalibrating) puts the output damn close to 0dBm at ~222mV. The signal is also cleaner (mostly seems to affect lower range).
Any ideas what would cause this issue with the SML-B3 module?
Thanks,
Josh
Post by: KungFuJosh on May 14, 2025, 02:45:24 am
Here's what the SML-B3 option unit looks like.
Post by: KungFuJosh on May 14, 2025, 02:57:15 am
Just for fun, here are some photos of the PSU.
Post by: KeBeNe on May 15, 2025, 03:49:47 am
Hi, sorry I haven't spoken for a long time.
As far as the pressure static of fans is concerned, there are usually diagrams that show the capacity of the fans and are not linear.
I have noticed that the Noctua fans react badly to high restriction, they get loud and the pressure drops sharply.
Regarding your SML03 and B3, the installation and conversion to B3 requires a factory calibration, as the module is installed in the RF signal path. (Service KIT software + NRVD + Z51)
This is why your levels are not correct.
Better repair the 3Ghz module, I think what you have marked is the RF coupler for the ALC.
The used switches 4227T have errors, replacement is very expensive, an exchange to HMC types is conceivable, work on it again entails a service kit calibration.
Unfortunately, even R&S no longer seem to have this software, at least here in Germany...
Servicemanual: https://manuals.repeater-builder.com/te-files/R&S/R&S%20SML_SHB_BD2_03%20Service%20part%202.pdf
Post by: KungFuJosh on May 15, 2025, 04:05:53 am
You were right anyway. I posted my results above- the Noctua lost. My second SML03's stock fan is much quieter, and not an issue.
That's odd. The B3 came with the SML03 as a preinstalled option along with B1. I swapped mainboards, and I think the B3 was tamer with the one that was not calibrated for it.
Do you know if there's something in the mainboard that needs to be unlocked for the B3 to be used? I haven't tried the original mainboard yet, but with the replacement board, it said something about it not being available despite it being connected. I was hoping it would sense it like it does with the B1.
I don't know which part or photo you're referring to? Do you mean the part I have marked as Main Output Unit (which I think is actually an attenuator)?
4227T sop8 appears to be available at aliexpress, but blocked to the US right now. It's okay; I swapped the attenuator out from the other unit, and it's fine. I'm going to sell the other unit (for parts or repair), and somebody else can fix that if they want it to work.
Your input and help is much appreciated!
Thanks,
Josh
Post by: KeBeNe on May 16, 2025, 02:29:37 pm
If I understand you correctly, you have exchanged the mainboards, as the factory calibration is stored on the mainboard, in the flash, in the protected area, a factory calibration is required.
What I mean by this is that the mainboard with all the assemblies connected in RF path is a calibrated chain, if you dissolve it, it is good luck that it has the correct levels afterwards.
How are the levels measured?
Do you have a spectrum analyzer which is still accurate?
Measuring the values with an oscilloscope is one of those things, as the input of the oscilloscope can also have a mismatch.
The measurements are not optimal and you need more accurate measuring devices than an oscilloscope to test these measuring devices.
Regarding the options, I have never had an SML, but it may be a similar procedure to the SMT/SME/SMIQ, i.e. the modulation type is activated with a key.
You can look in the menu to see if they have the item "installation", this is for installing options, these can be entered by deactivating Protect Level 2, at least with the big brothers.
It would be interesting for me to know whether an SML02 can be turned into an SML03 using a factory key.
With the SMIQ02B and SMIQ04B you "only" need a factory key for the 3Ghz or 6Ghz version to turn an 02B into an 03B and an 04B into an 06B.
I have edited your picture to explain the modules, the OPU1 is on the mainboard, the OPU2 is the doppler/trippler module.
Post by: KungFuJosh on May 17, 2025, 12:33:05 am
The SML series does a self calibration to determine levels. It generally works quite well, but not when the B3 module is installed. The mainboard sets the correct levels, but the B3 boosts what is actually outputted.
Measured on:
SDS2504X HD oscilloscope
TinySA Ultra
Keysight V3500A RF Power Meter
All devices are agreeable (TinySA required minor level adjustment at 1st frequency, then matches levels across the range within reason given its limitations).
There's nothing in the service manual about installing anything except hardware. Hardware is detected when its installed, and the options for it appear on screen. I'm going to swap mainboards back again to experiment with the B3 module.
For example- either mainboard ignores the OCXO if not installed. Either motherboard also gives an oven cold warning on startup when the OCXO is installed.
Either mainboard doesn't have any pulse options on screen when the B3 module isn't installed. The Pulse menu appears when B3 hardware is installed.
I have no idea on this one. The module says 2/3GHz. It would be funny if there's something like a jumper hiding in there to limit the module.
Thanks. I labeled "main output unit" that way because that's how it's labeled in the service manual. The attenuator is just a part of it. Though you're right, it probably is the hard to find switches that need to be replaced in the defective unit.
Thanks,
Josh
Post by: KungFuJosh on May 17, 2025, 03:23:59 am
Here's some examples. The only changes are the hardware attached.
1st Unit (didn't come with B1 or B3 options) with B1 OCXO connected:
(https://www.eevblog.com/forum/testgear/rohde-schwarz-sml-series-signal-generators-sml01-sml02-sml03-smv03/?action=dlattach;attach=2568828;image)
B3 hardware not installed:
(https://www.eevblog.com/forum/testgear/rohde-schwarz-sml-series-signal-generators-sml01-sml02-sml03-smv03/?action=dlattach;attach=2568820;image)
B3 hardware installed:
(https://www.eevblog.com/forum/testgear/rohde-schwarz-sml-series-signal-generators-sml01-sml02-sml03-smv03/?action=dlattach;attach=2568824;image)
Thanks,
Josh
Post by: KungFuJosh on May 17, 2025, 04:23:42 am
I just put unit 2 back together with unit 2 parts except for the main output module, and 2/3GHz module from unit 1. B3 is installed. It's not warmed up yet, but output is now showing slightly under 0dB rather than being high.
All I did was clean it a little more, and wiggle connections. I bet that wiggling helped. 🤔
I'll let it warm up, and test the levels again. If it's still low, I'll run the self calibration and see how it looks. Hopefully, running calibration doesn't mess it up.
Update:
Warmed up, and ran 'Calibrate all' again.
-0.49dB at 10MHz through 500MHz, -0.75dB at 1GHz, -1.5dB at 3GHz using the V3500A power meter.
That's dead on with the scope showing 211mVrms at 10MHz:
(https://www.eevblog.com/forum/testgear/rohde-schwarz-sml-series-signal-generators-sml01-sml02-sml03-smv03/?action=dlattach;attach=2568888;image)
That must have been some special wire wiggling. 🤷
Thanks,
Josh
Post by: KeBeNe on May 17, 2025, 05:20:53 am
Please look under utilities, there you will find the item Install for SME and SMIQ.
Yes, if you install the B1, you do not need a key, this is the case for all devices, but it is for PM, even if the HW is installed, for the other RF generators this is the option B11(HW). this also includes software keys.
Calibration, the self-calibration has nothing to do with the factory calibration.
The factory calibration is carried out over the entire RF chain and sets a reference point; this reference point is used as the target for the user calibration.
Post by: KungFuJosh on May 17, 2025, 05:36:08 am
This is the SML. There is no item Install anywhere on any of the menus. At least not that I could find. See attached. Maybe a hidden menu? That is possible, but doesn't seem likely. Maybe it's related to passwords 3 and 4 that they don't give us any details about. Still seems unlikely though since B3 showed up on the other mainboard.
B3 PM module shows up on either mainboard. It gave an error once on the mainboard that didn't come with it, but that was more likely me doing weird settings (or an issue with the hardware?). It shouldn't have shown up, or allowed me to do anything if an install key was needed. I could be wrong, I dunno. I'm not plugging back in the other mainboard to find out at this point. 🤷 I will eventually screw around with the B3 module and see if I get that same error again.
Yes, I understand that. The self-calibration does what it's supposed to do, and corrects the levels, among all the other cal stuff it does. It's a great feature so that you don't have to ship it out to a cal lab every 3 months. 😉
Thanks,
Josh
Post by: KungFuJosh on May 17, 2025, 03:12:06 pm
I was able to recreate the error with the motherboard that came with the B3 option. It's odd. The Pulse mod comes up in the menu, but it doesn't seem to do anything.
(https://www.eevblog.com/forum/testgear/rohde-schwarz-sml-series-signal-generators-sml01-sml02-sml03-smv03/?action=dlattach;attach=2569128;image)
Pulse Period, Width, and Delay all say Option Absent.
(https://www.eevblog.com/forum/testgear/rohde-schwarz-sml-series-signal-generators-sml01-sml02-sml03-smv03/?action=dlattach;attach=2569132;image)
Selecting one of them shows "parameter not available."
(https://www.eevblog.com/forum/testgear/rohde-schwarz-sml-series-signal-generators-sml01-sml02-sml03-smv03/?action=dlattach;attach=2569124;image)
But then it shows the current frequency there for some reason. Maybe a 20 year old bug?
(https://www.eevblog.com/forum/testgear/rohde-schwarz-sml-series-signal-generators-sml01-sml02-sml03-smv03/?action=dlattach;attach=2569140;image)
Then when I turned on the Double Pulse State option, it gave the error (same as other mainboard).
(https://www.eevblog.com/forum/testgear/rohde-schwarz-sml-series-signal-generators-sml01-sml02-sml03-smv03/?action=dlattach;attach=2569136;image)
So I restarted the SML holding down the 1 key (which seems to clear errors), now the options for Pulse show up, and can be edited without issue.
(https://www.eevblog.com/forum/testgear/rohde-schwarz-sml-series-signal-generators-sml01-sml02-sml03-smv03/?action=dlattach;attach=2569144;image)
I set the values randomly and pretty high, so now when I turn on Double Pulse State I get an error.
(https://www.eevblog.com/forum/testgear/rohde-schwarz-sml-series-signal-generators-sml01-sml02-sml03-smv03/?action=dlattach;attach=2569148;image)
Post by: KungFuJosh on May 17, 2025, 04:00:00 pm
I RTFM and it didn't help.  :-DD
Thankfully, Paul has an awesome video (as usual):
https://www.youtube.com/watch?v=EXx8mMqJN70 (https://www.youtube.com/watch?v=EXx8mMqJN70)
This one too: video (https://youtu.be/0GPp6ncHaJw?feature=shared) (embedding is disabled in that one).
Now I understand it a little better, and got rid of the error.
Thanks,
Josh
Post by: KungFuJosh on May 17, 2025, 04:22:05 pm
Aaaaaaaaaaaand the Pulse generator works fine...now that I know how to use it. 🤣
Thanks for the awesome videos, Paul!
(https://www.eevblog.com/forum/testgear/rohde-schwarz-sml-series-signal-generators-sml01-sml02-sml03-smv03/?action=dlattach;attach=2569202;image)
Post by: KungFuJosh on May 17, 2025, 10:40:04 pm
Well, I got a 3rd one. 🤷🤣
This one had a dead screen, so I took the screen from unit 1, and poof, it's awesome. I think this one was more recently calibrated than the other 2 units.
(https://www.eevblog.com/forum/testgear/rohde-schwarz-sml-series-signal-generators-sml01-sml02-sml03-smv03/?action=dlattach;attach=2569506;image)
I'm going to sell this one, and unit 1 for parts and keep unit 2 with the B1/B3 options. Or maybe keep this, and just sell the parts unit. 🤔 TEAS is real.
Thanks,
Josh
Post by: KungFuJosh on May 17, 2025, 11:12:02 pm
I dunno if this is helpful / useful to anybody, but, here's a few images of what the firmware update process looks like. This other unit was faster by a whopping 19 seconds!
I also grabbed the temp folder from the firmware updater app. Might be easier to update on a modern computer that way. 🤷
Post by: KeBeNe on May 18, 2025, 04:07:31 am
As I said, I don't have an SML.
But you have re-initialized the device, which must have re-read the assemblies, good advice, maybe I will come across an SML03 at a reasonable price.
I look forward to hearing more about your experiences.
Post by: KungFuJosh on May 18, 2025, 04:46:45 am
Regardless, your input is appreciated! I think you'll like the SML if you find a good deal. It seems good at what it does.
Despite its large footprint, I also like the design choices R&S made. The footprint was obviously to make it fit in a rack. The modular design and layout of everything is brilliant. It still stands up pretty well 20 years later.
Thanks,
Josh
Post by: KungFuJosh on May 19, 2025, 03:27:15 am
Yesterday I was playing with the pulse generator "video out" which directly outputs the set pulse. Today, I played with the pulse modulation.
(https://www.eevblog.com/forum/testgear/rohde-schwarz-sml-series-signal-generators-sml01-sml02-sml03-smv03/?action=dlattach;attach=2570304;image)
It gets weirder when you combine Pulse + AM + FM modulation.
(https://www.eevblog.com/forum/testgear/rohde-schwarz-sml-series-signal-generators-sml01-sml02-sml03-smv03/?action=dlattach;attach=2570308;image)
Messing with these settings also helped improve my triggering skills, which was a nice bonus. 😉
Thanks,
Josh
Post by: tautech on May 19, 2025, 03:44:38 am
1st grade simple stuff !  :P
When you need a Zone trigger or 2 things are really getting interesting.....  :scared:
Post by: KungFuJosh on May 19, 2025, 12:21:01 pm
If you knew what I was actually referring to, you'd call it kindergarten. 😉
Post by: KungFuJosh on May 19, 2025, 10:08:08 pm
Is it correct that those RF switches marked 4227T are actually SSW-124?
Post by: KungFuJosh on May 20, 2025, 03:37:32 am
More modulation fun.
(https://www.eevblog.com/forum/testgear/rohde-schwarz-sml-series-signal-generators-sml01-sml02-sml03-smv03/?action=dlattach;attach=2570776;image)
SML03 settings:
100kHz -10dBm
AM Modulation: 80%
Phase Modulation: 1.800 rad
LFGen Freq: 100Hz
Post by: KeBeNe on May 21, 2025, 02:46:09 am
Yes, that is correct.
You can check if the switching voltage is +/-6V, R&S has sometimes operated them with up to +/-8V to improve the isolation, which is outside the specifications.
An exchange for HMC270 would be conceivable, but you would then need the calibration software
Post by: KungFuJosh on May 21, 2025, 03:10:55 am
I found a source for the 124s, but they're $6 a piece...which isn't terribly terrible.
I might experiment with the parts unit with the dead output module (attenuator).
That calibration software doesn't seem to exist anymore. I really hope somebody finds it and shares it with us...but I won't hold my breath. 😉
Thanks,
Josh
Post by: KungFuJosh on May 23, 2025, 02:21:46 am
Should I be concerned about this intensity fluctuation at all? Do I need to improve filtering or something in the SML? I see similar movement from the SDG, but the intensity color grading is generally consistent.
(https://www.jmpguitars.com/images/scope1.gif)
(https://www.jmpguitars.com/images/scope2.gif)
Post by: kmoonwalker on May 23, 2025, 03:02:04 am
you can check SML output with some spectrum analyser to see if there isnt something faint coming out or some tiny instability of main frequency
Post by: pdenisowski on May 23, 2025, 10:25:06 am
Agreed.  Does the scope have an FFT?
Post by: KungFuJosh on May 23, 2025, 12:08:02 pm
Of course! Siglent has a good FFT, far better than my skills of utilizing it. ;)
Great ideas, thanks. Now to figure out the test setup, and avoid temptation to buy better SA... 🤔
Post by: KungFuJosh on May 23, 2025, 01:58:18 pm
How's this look? Did I set it up correctly?
SML03:
(https://www.eevblog.com/forum/testgear/rohde-schwarz-sml-series-signal-generators-sml01-sml02-sml03-smv03/?action=dlattach;attach=2572470;image)
SDG2122 for comparison:
(https://www.eevblog.com/forum/testgear/rohde-schwarz-sml-series-signal-generators-sml01-sml02-sml03-smv03/?action=dlattach;attach=2572466;image)
Thanks,
Josh
Post by: kmoonwalker on May 23, 2025, 02:02:02 pm
hmm you written some time ago about it being able to modulate the waveform etc - did you disabled all tricks from settings after playing with fancy signals? ;)
other than that something maybe broken (or cable or something on signal path is not good enough and scope reacts to that)
also thing that I noticed (but it maybe due to not some huuge signal amplitude and scope approximation) - the amplitude is fluctuating a bit - from my university time old Rohde generator was so steady we tested all new ones against it and they usually failed ^^
Post by: KungFuJosh on May 23, 2025, 04:15:06 pm
I think you hit the answer right there. I connected both gens with 50MHz 0dBm signals to my scope. Look at the Vrms stats, that looks pretty clear. A small difference, but a noticeable one, and not in the direction your experience would suggest.
(https://www.eevblog.com/forum/testgear/rohde-schwarz-sml-series-signal-generators-sml01-sml02-sml03-smv03/?action=dlattach;attach=2572608;image)
It's probably obvious from this conversation that C1 is the SML03, and C3 is the SDG2122X.
Now, the question is, how can I stabilize that voltage further?
Thanks,
Josh
Post by: kmoonwalker on May 23, 2025, 04:21:47 pm
now this is more like Rohde I remember - glad you have it pinpointed :)
I did asked about setting due to fact that often with layered menu we do not see everything like on old equipment with knobs etc on front panel so check was a quick look - nowadays it is a good practice to twice/triple check everything in case of crucial measurements with expected result
Post by: kmoonwalker on May 23, 2025, 04:30:02 pm
I would need to dig into complete specs of that generator but keep in mind that there are several factors:
- not so big amplitude of signal so lot of things can impact it and will impact it
- results are calculated so oscilloscope noise may play bigger impact than one could think for result
- scope has limitations on approximation and thus calculations
- your cabling may receive something even from your body, some EM, etc
- something maybe coming thru filtering of generator/scope both from mains...
Generator is old so filtering in PSU maybe maybe not great nowadays (but it should).
There is some crosstalk between scope channels - you have some 2000x HD model if I remember correctly so it has a nice dampening compared to most but this can also play a factor in some cases.
There is a reason why we use one and "best" channel in scope in a room with stabilized mains power, controlled EM etc to make small values measurements (thou usually smaller than this)
but with this we are getting into metrology area with all its oddities, fancies etc and sometimes the question is if you really wanna know or can achieve it ;)
You may also develop an sickness/need for top notch equipment just to be satisfied but it may not play a role at all on daily tasks.
For example I would not have paid any attention to such small variation on my old 1054Z that I use for usuall stuff and it is more than enough for it - but its resolution is to small to see things. If I would shown you side by side for example HD314MSO with 14bits we could estimate which scope does a better job or second unit like yours to see if this is an expected behaviour for this ADC and maths conversion. Thing is that you have a very nice scope but diggin too much you may stop liking it. This applies to every scope on planet if you find a proper angle ;)
Post by: KungFuJosh on May 23, 2025, 04:52:41 pm
M&P connectors and Hyperflex 5 cable used for the tests.
The scope's voltages, etc. have all been accurate, and in agreement with the V3500A RF power meter.
I tried two different PSUs, and that didn't affect the fluctuation at all. Both looked generally the same, though were also around the same age.
All tests prior to the Vrms comparison were done on C1 with nothing else plugged in. The Vrms comparison test is using C1 and C3 as they don't share the front end toys.
Let's stay just shy of that rabbit hole. 😉
Thanks,
Josh
PS. You can see in the attached image that it's very clear on this series when modulation is active. It shows that modulation is on, and which types are active (up to 3 at once).
Post by: KungFuJosh on May 23, 2025, 06:15:17 pm
I think it was the cable after all. I think there might be an issue with the shielding on the cable I was using.
I made a shorter hyperflex 5 cable, and the voltage fluctuation is gone, and the consistency of the color grading is much more stable.
(https://www.eevblog.com/forum/testgear/rohde-schwarz-sml-series-signal-generators-sml01-sml02-sml03-smv03/?action=dlattach;attach=2572752;image)
Post by: kmoonwalker on May 23, 2025, 06:18:20 pm
the higher the freq -> more problems with everything which was supposedly good - now you have a scope that you can see literally everything instantly is something is wrong/off - congrats :)
Post by: Martin72 on May 23, 2025, 08:40:23 pm
SML03:
Thanks,
Josh
I recreated this earlier.
Source SDG6052X, Scope SDS3104X HD, Magnova BMO350.
Coefficients for siglent Hamming and Hann, for Magnova Hamming.
Post by: kmoonwalker on May 23, 2025, 09:04:53 pm
Hi, do you have similar noise floor without averaging on SDS3000?
Both look way better than on Josh setup so I wonder if his hoise floor is impacted externally or this is the difference between 2000 and 3000 series
Post by: tautech on May 23, 2025, 09:14:56 pm
Maybe they might chose to display the Siglent FFT menus for you to examine the many ways FFT can be configured.....
Post by: kmoonwalker on May 23, 2025, 09:20:33 pm
as you can see on pictures posted by Martin - two first are from Josh and later ones from Martin settings looks same for Siglent just Martin used averaging - anyway they have at least 10 dBm noise floor difference which makes me wonder if there isnt really something that Josh could improve on his setup
or 3000 series really has such better dynamic range for fft
Post by: Martin72 on May 23, 2025, 09:28:21 pm
Except for the averaging, I followed Josh's settings, which he shared in the post I quoted(picture).
Post by: egonotto on May 23, 2025, 09:30:08 pm
Martin uses 65536 samples while Josh only uses 16384 samples.
Best regards
egonotto
Post by: tautech on May 23, 2025, 09:34:51 pm
A Peak Hold setting might account for that.
Without a Menu showing how might anyone know ?  :-//
Post by: Martin72 on May 23, 2025, 09:37:02 pm
@egonotto:
My scope has twice the sample rate with the same time base.
I followed Josh's post, where he took the measurement at 2 µs/div, not the one I´ve quoted before, sorry.
Then he has 32k points and I have 65k.
https://www.eevblog.com/forum/testgear/rohde-schwarz-sml-series-signal-generators-sml01-sml02-sml03-smv03/msg5923934/#msg5923934 (https://www.eevblog.com/forum/testgear/rohde-schwarz-sml-series-signal-generators-sml01-sml02-sml03-smv03/msg5923934/#msg5923934)
Post by: kmoonwalker on May 23, 2025, 09:37:44 pm
yep but samples amount should not impact the noise floor level - just better representation
I think we need to wait for Josh to share a pic with full scale alike Martin shared cause he cutted bottom part on pics after cable repair.
Also there the fall towards noise floor looks closer to Martins current results so maybe that fixed it for him, too
I am curious also due to fact I am considering to purchase some scope and such comparison (expecially with Magnova added) is very nice to see :)
Post by: Martin72 on May 23, 2025, 09:39:57 pm
I mentioned earlier that Josh had also posted a screenshot of his FFT settings.
Post by: kmoonwalker on May 23, 2025, 09:40:22 pm
from what I saw on Martins pictures from both Magnova and 3000 series I gotta say both are tempting still I need to settle for one :/
Post by: tautech on May 23, 2025, 10:06:32 pm
I'll put up some examples of 50 MHz FFT with a few scopes in the next day or so, SDG6000X and SSG3000X will be the sources....gotta big mess in the engineering shop to clean up first from yesterday's Ag equipment modifications......
And it's perfect weather to check zero of my new to me shooter......
Never enough time....
Post by: KungFuJosh on May 23, 2025, 11:46:52 pm
Martin's time base and span were different than mine. In this one I matched his settings (+4 avg), and it might look similar to you now. 😉
(https://www.eevblog.com/forum/testgear/rohde-schwarz-sml-series-signal-generators-sml01-sml02-sml03-smv03/?action=dlattach;attach=2572920;image)
Post by: KungFuJosh on May 23, 2025, 11:57:22 pm
And since sampling was brought up, here's a comparison with the same cable and setup, but connected to the SDS5054X. It has a higher sampling rate than both of the HD scopes, but a slightly higher noise floor also.
(https://www.eevblog.com/forum/testgear/rohde-schwarz-sml-series-signal-generators-sml01-sml02-sml03-smv03/?action=dlattach;attach=2572930;image)
Post by: KungFuJosh on May 24, 2025, 05:00:59 am
I just made another cable, this time I did a much better job on the shielding braid than I did on the other one. It improved stability even further.
(https://www.eevblog.com/forum/testgear/rohde-schwarz-sml-series-signal-generators-sml01-sml02-sml03-smv03/?action=dlattach;attach=2573116;image)
Thanks,
Josh
Post by: kmoonwalker on May 24, 2025, 05:09:29 am
now this is a proper noise floor - congrats
just one question - is this taken with SDS2000x hd series or your 5000x scope?
Post by: KungFuJosh on May 24, 2025, 05:15:33 am
Thanks!
This is with the 2000X HD. The easy giveaway is the GSa/s rate is maxed at 2 on the 2k and 5 on the 5k. That and the 5k is slightly noisier (see reply 90 above). 😉
Post by: kmoonwalker on May 24, 2025, 05:23:27 am
Thanks!
This is with the 2000X HD. The easy giveaway is the GSa/s rate is maxed at 2 on the 2k and 5 on the 5k. That and the 5k is slightly noisier. 😉
I do not have Siglent specs so well in my head and on some scopes there are settings to tamper with so better to ask and be on safe side :)
Means that noise floor is pretty good on 2000 and 3000 series and that is valueable info for me - Many thanks!
Post by: KungFuJosh on May 24, 2025, 05:58:21 am
Noise floor is practically the same between those two. In theory, the 2000 might be slightly better because of the higher range of the 3000 series. I've not seen anything that convinced me one way or the other tho. Both are excellent.
Post by: tautech on May 24, 2025, 10:04:29 am
Means that noise floor is pretty good on 2000 and 3000 series and that is valuable info for me - Many thanks!
You ain't seen my contribution yet !  :P
Started building a series of screenshots before a planned dinner with lifelong friends interrupted proceedings and now with 3 too many under the belt will need to wait until tomorrow to complete.....  :=\
Post by: egonotto on May 25, 2025, 01:19:40 am
surprisingly, the noise of the SDS3034X HD in the 1 V/div range is slightly better than that of the SDS2104X HD.
With the SDS3034X HD with a bandwidth of approximately 420 MHz, the noise is at 4 mVrms.
With the SDS2104X HD with a bandwidth of approximately 180 MHz, the noise is slightly above 5 mVrms.
Best regards
egonotto
Post by: tautech on May 25, 2025, 08:00:28 am
I'll put up some examples of 50 MHz FFT with a few scopes in the next day or so, SDG6000X and SSG3000X will be the source.
50 MHz 0dBm FFT tests with 50 MHz span using SSG3021X only...too much dicking around with cabling otherwise.  :horse:
Siglent 6 GHz rated 600mm N type cable with N-BNC adapter used for all tests, except SDS800X HD when a Tek 50 Ohm feedthrough was also used to mimic the 50 Ohm input 800X HD models do not have.
All screenshots used a Max Hold setting and max FFT pts (2-8 MPts) available in each model provided and last we played with some ERES and a narrower Span with SDS6204A.
Take note of the Span used, RBW settings, reported frequencies and amplitudes in each screenshot.
Attachment filenames represent the model in use.
We start with a FFT from SVA1032X and work to SDS6204A.
Post by: KungFuJosh on May 25, 2025, 02:19:53 pm
Our time bases were at 2us/div. Here's 1ms:
(https://www.eevblog.com/forum/testgear/rohde-schwarz-sml-series-signal-generators-sml01-sml02-sml03-smv03/?action=dlattach;attach=2574438;image)
Same setup, switched to 2us:
(https://www.eevblog.com/forum/testgear/rohde-schwarz-sml-series-signal-generators-sml01-sml02-sml03-smv03/?action=dlattach;attach=2574444;image)
There's no comparison if we don't keep our setups consistent.
Post by: kmoonwalker on May 25, 2025, 03:39:56 pm
many thanks to everyone for all effort :)
Post by: KungFuJosh on May 27, 2025, 02:56:45 am
I thought this was an interesting comparison. SML03 sweeping with the same short hyperflex 5 cable. SDS5054X vs SDS2504X HD.
Green is the 2000X HD for anybody that doesn't know the model differences. ;)
Thanks,
Josh
Post by: KungFuJosh on May 29, 2025, 08:16:28 pm
Man, I really need to get my hands on that calibration software.
Does anybody have any idea where to find the R&S calibration software for the SML series?
Thanks,
Josh
Post by: KungFuJosh on June 03, 2025, 03:01:39 am
OTOH, some dumbass tried to do a bandwidth sweep with a 20M filter on the scope, and didn't realize it right away.* Then he went and connected a V3500A to the SML03, and stepped in 10MHz intervals from 10MHz to 1GHz, and the SML was actually in spec including linearity.
From 10MHz to around 700MHz, the SML was within ~0.2dB of the value, and only when it got close to 1GHz did it almost reach the ~0.5dB datasheet spec.
*thought there might be something wrong with the new attenuator. 🙄🤣
Post by: Jörg on February 23, 2026, 11:07:56 am
Hello. Does anyone know if the R&S SML B5 hardware option will also work if you transfer it from one SML unit to another that wasn't originally equipped with it?
Regards, Jörg
Post by: KungFuJosh on February 23, 2026, 04:34:21 pm
Regards, Jörg
My experience with this series was that things can be plugged in as swappable hardware modules without worrying about it needing activation. You will need to run self cal though.
For example, I had no issue with or without B5. I could also swap the 2G/3G board, or run without it. I swapped mainboards between units, etc.
Thanks,
Josh
Post by: d-el on March 12, 2026, 01:47:17 am
Has anyone been able to find a replacement display for this generator?
Post by: KungFuJosh on March 12, 2026, 04:43:31 am
Yeah...that's why I have a parts unit available with a dead display. ;)
But no, outside of buying parts units, there hasn't been a great option for it. You can buy a parts unit with a (at least mostly) working display IME for less than the replacement screen.
Post by: charliedelta on March 14, 2026, 08:41:45 am
 I like you could not get the pulse generator to work.  I will watch the video and try again.
Do you mind listing what options are showing on your unit? I have the SML01.
Can you just change the coin cell battery or do you have to apply voltage and then change the coin cell battery to save the memory contents? I will also upgrade to the latest firmware.
Post by: charliedelta on March 14, 2026, 09:00:05 am
And asking Rohde for any service help is a waste of time. They told me they "dispose of all documentation and firmware and everything else" when they discontinue a unit. Their main market seems to be government and their attitude to smaller businesses is not that great.
 I have a few pieces of their equipment and every time I ask for a firmware updates I get the same answer. The make the most expensive disposable equipment in the world with the shortest possible support life. And for this reason when I was in a position  of buying equipment for my company  I would not buy their new equipment. To me it was simple when a company does not want to release user, service, firmware or service bulletins they not really interested in customer support or building a loyal customer especially if the equipment is still working and calibrated. Agilent/Keysight were good in this regard  so  I purchased their equipment  since they were very accessible and their support and calibration centre was very easy to get in contact with  and to deal with. They even calibrated their older discontinued models.
Post by: KungFuJosh on March 14, 2026, 08:24:59 pm
My pulse generator works great. I didn't know how to use it initially. ;)
IME with the SML series, any hardware option you install correctly will become available without much effort.
I didn't bother applying voltage. The only thing you'll lose is the user calibration, which you'll want to run again anyway.
Regarding support, Keysight is not better than R&S at all. The difference is that Keysight will happily overcharge you for calibration. Better to go to an independent cal lab instead either way.
Both companies prefer large businesses, and neither care about small biz or hobby users. I have products from both companies, and between the two, I've found R&S easier to deal with. That being said, both of them are ridiculous.  :-DD
For the R&S stuff that had publicly available firmware, it's mostly available on their site if you have a company login.
Post by: pdenisowski on March 16, 2026, 11:00:56 am
Who told you that???  If you have an email from us or the name of the person you spoke to, please PM them to me.
We (R&S) normally provide full support for products for at least 5 years after we officially discontinue it, and often provide best effort service and calibration after that.  I have personally seen repairs and calibration performed many, many more years that than after instruments were discontinued.
Post by: Jackob on March 29, 2026, 06:12:09 pm
Hi
Does anybody have experience if SML02 boots and runs without the display module and cable, not just the LDC but the whole unit? I have a parts donor SML02 which has lost its display unit and I wonder if I still could use the generator via the GPIB or RS232 interface with a PC and some simple app.
Br, jackob
Post by: CuriousBaho on April 01, 2026, 06:51:23 pm
Currently i dont know what to say but, as far as i can see SML03 devices can output 10 to 500kHz from its LF output using its internal LFGenerator.
Is that correct? If so, what a nice device to have.
Post by: KungFuJosh on April 01, 2026, 10:38:58 pm
The LF gen can go up to 1MHz, but in general, it's not great. It does well for its intended use for modulation on the main RF output, but the LF output isn't pretty. I dunno if it can modified or optimized to be better, but I've had a few of these, and I've never seen an LF output on them that didn't make me think I should use something else for that instead. ;) ...though I guess that depends really on what you need it for.
Post by: KungFuJosh on May 31, 2026, 10:46:24 pm
I finally found some rack ears for my SML03. I got a used set from ArtisanTG for $80+$26 to ship. Bastards are expensive, but it was still better than buying them new for $188 which is mildly insane for a pair of 2U rack ears.
Post by: TylerPeppy on June 13, 2026, 12:31:11 pm
I am going to jump on this thread with some issues. Who knows, might even be able to fix them.
I got my dirt-cheap SML03 with B19 rear IO and B3 pulse mod a couple days ago and... Issues. The output power is almost consistently 25dB down from the 0dBm I tested it at across its entire range.
I do a sweep on my SA here to show (Picture is dark to enhance screen details). First step will be tracking the signal through the RF paths. I am suspecting one of the GaAs switches has gone bad in the 1GHz module + RF attenuator as they usually do, but will have to test them to be sure nonetheless.
- Tyler
Post by: KungFuJosh on June 13, 2026, 03:27:11 pm
I don't think that's likely since it's consistent across the board. I suspect 1 of 2 things:
1. Either your SA is measuring incorrectly, or
2. The B3 module might be dropping the output level
If you have a different power meter, then you can rule out #1.
To rule out #2, you can bypass the B3 module and test again.
You can also run through a full self calibration after a good warmup, and if you're lucky that might have an impact on the output level.
ETA: Just looked closer at your SA. It says input attenuator 30dB. Does that mean the input is dropped 30dB, and your output is actually close to 0 dBm? I dunno if it compensates to adjust the displayed level or not.
Thanks,
Josh
Post by: TylerPeppy on June 13, 2026, 07:02:03 pm
Thanks,
Josh
Number 1 can be ruled out. My U2000H reports the exact same power level as the SA.
As for the attenuation 30dB on the SA, the system compensates already for that, which was indicated by my 8594E, and the U2000H measurements.
I will have to try and bypass B3, see if it makes a difference. Given I see no ALC error, and I assume this is in the 2/3G board, it could potentially be.
I will have a quick look, see if that fixes it.
- Tyler
Post by: TylerPeppy on June 13, 2026, 07:26:38 pm
Well, looks like that fixed it. B3 is the problem, now time to investigate why.
Post by: KungFuJosh on June 13, 2026, 07:56:06 pm
That's what I figured. It also has an attenuation level thingamabob inside. B3 also lowered my output, but only a couple dB.
Do the full self calibration though before you do anything else (with B3 installed). I think I posted how to do it earlier in the thread.
Post by: KungFuJosh on June 13, 2026, 08:02:47 pm
Oh, I was wrong. It has three of those bastard switches in it.
Post by: TylerPeppy on June 13, 2026, 08:30:49 pm
No joy with the selfcal, seems about the same now. Also noticed that this issue is dumping a bunch of harmonics into the signal output... First harmonic of 100MHz for example, is only about 15dB down. This wasn't present when I had the module bypassed. Something fishy going on here.
Post by: TylerPeppy on June 13, 2026, 08:49:00 pm
As a follow up, I can see something is wrong here. Referring to the service manual under sec. 6 for the Pulse modulator, they have all the test points written out with the expected values. Everything was fine when testing with the built-in utility (Even the GaAs pin voltages...), but the post-N8 rf level (TP902) seems to be troublesome.
Should be: 150 - 250mV
Was Tested: 4.196mV
- Tyler
Post by: KungFuJosh on June 13, 2026, 09:22:51 pm
I wonder where that tp actually is. Anyway, review this thread a little. It seems I corrected my output level issue at B3 by cleaning and wiggling things.  :-DD
https://www.eevblog.com/forum/testgear/rohde-schwarz-sml-series-signal-generators-sml01-sml02-sml03-smv03/msg5917594/#msg5917594 (https://www.eevblog.com/forum/testgear/rohde-schwarz-sml-series-signal-generators-sml01-sml02-sml03-smv03/msg5917594/#msg5917594)
And here's the firmware update info if you need it: https://www.eevblog.com/forum/testgear/rohde-schwarz-sml-series-signal-generators-sml01-sml02-sml03-smv03/msg5918402/#msg5918402 (https://www.eevblog.com/forum/testgear/rohde-schwarz-sml-series-signal-generators-sml01-sml02-sml03-smv03/msg5918402/#msg5918402)
Post by: TylerPeppy on June 13, 2026, 09:50:23 pm
This reset the cal after updating, did it not?
Post by: KungFuJosh on June 13, 2026, 10:05:22 pm
I don't think fw update affected factory cal, but I've done the self cal a bunch of times after that anyway. No issues with mine other than 0dB might be slightly lower than 0 last I checked, but I don't need it to be perfect.
Post by: TylerPeppy on June 13, 2026, 10:09:41 pm
I just read through the service docs again, and looks like N8 is the output amplifier stage at the end of the module. It is probably not an overly complex part (hopefully), but if not misbehaving, would explain the extra harmonics I see with it introduced into the RF path.
I did try the "tap the parts and see if it fixes itself" method to no avail.
- Tyler
Post by: KungFuJosh on June 14, 2026, 12:48:41 am
Did you clean anything with IPA? I'd clean anything suspect and all the signal path connectors.
You might need to replace the SSW-124 (marked 4227T) in there. Those are not easy to find parts though. It's easier to find an R&S donor unit to scavenge parts from. You could also try reflowing and cleaning the one you suspect. It might be a good idea to clean the whole module anyway.
Post by: TylerPeppy on June 14, 2026, 01:15:29 am
On that thought, I actually used my near field probes to trace the input signal through the 4227Ts. I have actually seen no significant signal attenuation until the signal trace arrives at the B3 amp section (closest box to output connector, and the hottest part on a thermal camera).
Apart from that, all the connectors were cleaned, and re-torqued to 0.90N•m. The board was scrubbed, and I reflowed almost all the joints on the board top and bottom side.
A donor unit is likely going to cost multiple fold compared to what I spent already, so I will keep looking at either component-level repair or just bypassing the module.
- Tyler
Post by: KungFuJosh on June 14, 2026, 01:52:23 am
Can you share some thermal images of it?
What do the 4227Ts voltages look like inside of B3?
Post by: TylerPeppy on June 14, 2026, 03:17:47 pm
Tested all 3 switches:
SW1:
- CTRL1:  1.522V
- CTRL2: -6.066V
SW2:
- CTRL1:  1.512V
- CTRL2: -6.052V
SW3:
- CTRL1: 0.7891V
- CTRL2: -6.003V
I am guessing SW3 might have some sort of problem. But, when I select the pulse gen modulation options in the menus, CTRL1 goes to 1.5 or so volts... UTSource has some of these switches, but they're USD$ 102.76 each plus USD$ 30.00 ship... No thanks!
Attached a thermal shot of the module.
- Tyler
Post by: KungFuJosh on June 14, 2026, 04:01:57 pm
If you're comfortable soldering/desoldering those, you can swap SW2 and SW3 and see if the voltage difference follows the chip or not...or if it magically fixes the problem. ;)
It's been a while since I checked UTSource for those, but they were $6 at the time.  :palm:
Post by: TylerPeppy on June 14, 2026, 04:22:20 pm
Interestingly, my module seems to differ from your B3 in two small ways...
The inductor near the output connector is seemingly bodged on in mine, with a wire connecting one side of it to the cap near it.
Other one, is that I have two white switches, and one SOP-8 looking one.
Not sure if it's just a component shortage that would have mixed these, but the inductor thing was interesting. I will get a picture of it when I have it open again.
Post by: KungFuJosh on June 14, 2026, 04:24:26 pm
I definitely want to see some photos. I wonder if somebody previously attempted repair.
Title: Re: Rohde & Schwarz SML Series Signal Generators - SML01 SML02 SML03 SMV03
Post by: TylerPeppy on June 14, 2026, 04:34:33 pm
Here ya go... Photos are quite hi-res, but it doesn't seem to show well on the forum.
You can also see the main output module was RMA'd in '04
- Tyler
Post by: KungFuJosh on June 14, 2026, 07:24:12 pm
You can right-click and open the image in a new tab to view it full size.
Anyway, since your worst case scenario is to bypass B3 and not have any issues anymore...
How do you feel about swapping SW2 and SW3? I'm curious about that voltage.
Post by: TylerPeppy on June 14, 2026, 08:16:48 pm
Tried removing SW3, it's bolted down pretty good with these tabs on the side, my hot air has a difficult time getting it pulled up.
Post by: KungFuJosh on June 14, 2026, 08:24:24 pm
It might be easier with some flux and an iron, but you'll need to do a good job cleaning again.
Post by: KungFuJosh on June 15, 2026, 01:44:01 pm
I requested a quote for these: https://www.utsource.net/itm/p/12607896.html (https://www.utsource.net/itm/p/12607896.html)
They quoted $10 each for a quantity of 10 (used  :palm:). I don't know if quantity effects it or not. If you requested what they show as 4227T, then it's probably the wrong part anyway.
Post by: TylerPeppy on June 15, 2026, 02:38:02 pm
These are the ones I was looking at: https://www.utsource.net/itm/p/9271510.html?srsltid=AfmBOopPQx8MNEpC7gQIxkpv9SFEWlaXGT0B78kVxJB8Olxne8BJL4qE (https://www.utsource.net/itm/p/9271510.html?srsltid=AfmBOopPQx8MNEpC7gQIxkpv9SFEWlaXGT0B78kVxJB8Olxne8BJL4qE)
Probably were the wrong part then.
- Tyler
Post by: rf-messkopf on June 15, 2026, 03:31:16 pm
MASWSS0157 from MACOM and AW002R2-12 from Skyworks both come in SO8 packages and seem to have the same pinout as the P35-4227-3T. The control voltage is similar since they are also GaAS devices (i.e., depletion mode MESFETs), and both are rated to 2.5 GHz. Unfortunalety they are also obsolete.
Then there is the HMC234C8 in a SO-8 package but with different pinout. Obsolete as well. Maybe you can find a suitable GaAS SPDT switch in a SOT23-6 package and bodge that in if all else fails. This will likely distort amplitude flatness, but you should be able to calibrate that out if you can get your hands on the required cal software.
These old GaAs devices are prone to failure as the processes apparently weren't yet well under control back then.
Edit: I just realize that the P35-4227-3T is a terminated switch, i.e., the switch terminal that is not in the active path is terminated into 50 ohms. You should look out for that when searching for a replacement.
Post by: KungFuJosh on June 15, 2026, 05:59:59 pm
Be careful with part identification. It's a switch (DC - 6GHz High Isolation SPDT GaAs MMIC Switch); not an oscillator or a JFET or a 2 pin socket. All of which can easily be confused by the part numbers.
This is the correct replacement (the only source I know of, unfortunately questionable being sold as used): https://www.utsource.net/itm/p/12607896.html (https://www.utsource.net/itm/p/12607896.html)
Datasheet attached.
Post by: TylerPeppy on June 15, 2026, 09:49:41 pm
Datasheet attached.
Might need many of your replacements there, in the event that they are already broken. Can't say I am fond of the idea of "used" chips, but might not have any options anyways.
Post by: KungFuJosh on June 15, 2026, 11:33:51 pm
If you can manage to swap SW2 and SW3, then you'll get a better idea after testing the voltages. If the voltage difference follows the chip from SW3, then you know it's the chip.
If you can't swap the chips you have, then ordering more of them won't help until you can swap them anyway.
Something like this might help:
https://www.youtube.com/watch?v=7kyaz4Zrd78 (https://www.youtube.com/watch?v=7kyaz4Zrd78)
Post by: rf-messkopf on June 16, 2026, 09:48:51 am
Datasheet attached.
If that's the correct datasheet, the HMC347ALP3E from Analog Devices/Hittite and the MSWA2-50+ from Minicircuits are both available and perfect matches (nonreflective SPDT GaAs switch with negative control voltage and comparable isolation and loss) -- except for the package. Since both are 3x3mm QFNs you could make a small adapter board with castellated holes on the sides that fits on the SO8 footprint.
That's the pulse modulator assembly, right? I think the attenuator in the SML has similar switches and a software temperature compensation, therefore it is important to stick with GaAs MESFET devices, although I don't think there is temperature compensation in the pulse modulator.
Post by: TylerPeppy on June 16, 2026, 01:29:01 pm
Datasheet attached.
This could also work, but will probably be magnitudes more expensive on a gamble with the used parts. Once I get a preheater for my soldering bench, I might have a bit more luck removing this switch and then replacing all of them.
Post by: KungFuJosh on June 16, 2026, 03:34:14 pm
Datasheet attached.
The MSWA2-50+ certainly looks interesting at $19 a pop. The other one for $104 is less appealing.
I was already considering an adapter board, but my SML is working fine so there was no urgency for me. ;)
There was another chip people were bodging in to replace these, but I don't remember what it was. It might also be worth considering an adapter for if the part number is found again and still available at a reasonable price.
Yes, the output module/attenuator has a bunch of these same switches.
Thanks,
Josh
ETA:
I'm still reviewing the datasheets, but it looks like HMC347ALP3E is not as a good of a choice compared to the MSWA2-50+.
Comparisons up to 3GHz:
SSW-124 (original):
Max insertion loss: 1.0dB
Typical isolation: 40dB
Minimum isolation: 30dB
Operating temp: -45C to +85C
Switching speed: 3nsec
Max control voltage: -10V
VSWR: 1.25
Current Price: OBSOLETE
MSWA2-50+:
Typical isolation: 47dB
Minimum isolation: 29dB
Operating temp: -40C to +85C
Switching speed: 7nsec
Max control voltage: -8.5V
VSWR: 1.33
Current Price: $19
KSW-2-46+ (has been used previously for this purpose):
Max insertion loss: 1.8dB
Minimum isolation: 28dB
Operating temp: -55C to +100C
Switching speed: 4nsec
Max control voltage: -8V
VSWR: 1.3
HMC347ALP3E:
Max insertion loss: 1.9dB
Typical isolation: 54dB
Minimum isolation: 50dB
Operating temp: -55C to +85C
Switching speed: 10nsec
Max control voltage: -7.5V
VSWR: 1.33
Current Price: $104
R&S has been known to push the voltages on these switches (which likely contributes to their failure rate), so HMC347ALP3E is not a good choice beyond the price.
Anyway, somebody smarter than me should compare further to make sure we didn't miss anything. ;)
Post by: rf-messkopf on June 17, 2026, 10:44:36 am
No idea. The HMC347ALP3E is spec'd to higher frequencies, so you can speculate that its FETs have shorter gates and hence a smaller Schottky breakdown voltage. Depending on which philosophy the company follows with their abs. maximum ratings and which margins they apply, this may be the reason for the -7.5V max control voltage. On the other hand, these devices might be manufactured in a more modern process than the original ones, which makes them much less prone to deterioration processes like gate sinking (i.e., the gate diffusing into the semiconductor material), which is dependent on gate-source voltage and temperature.
But that is all just reading tea leaves. For me, the deciding factor would be the price.  ;)
That said, the old GaAs devices are notorious for failure, even if they are new old stock. I've had a SML where the signal level fluctuated wildly as soon as it warmed up. Presumably the switches in the attenuator. Since I bought it from a dealer, I simply sent it back (and received a better one as compensation). But I’ve replaced a few of the damn things in various devices. Most recently in an R&S EB200 wideband receiver.
Post by: TylerPeppy on June 17, 2026, 02:47:43 pm
There are a few other options that would have probably been better avenues. For the price I simply couldn't give this guy up though. Siglent's SSG5040X would probably have been a much better decision.
eBay seller refuses to help me at all it seems, so I am kind of out in the weeds on this one hence why I started my own debug. He's been MIA for the past while. I guess I should have expected this though.
- Tyler
Post by: KungFuJosh on June 17, 2026, 02:50:21 pm
I designed the conversion PCB for the MSWA2-50+ to SSW-224. PCBWAY can probably make them, JLCPCB can't (too small for castellated holes - they require minimum 10mmx10mm).
Somebody else please verify.
If you order these, I recommend ENIG plating, and make sure to use at least 25u for hole copper thickness (https://www.pcbway.com/helpcenter/ordering_parameter_instruction/What_is_PCB_Hole_Copper_Thickness_.html).
And of course:
USE AT YOUR OWN RISK.
Thanks,
Josh
ETA: lol, it just occurred to me how tiny this is. Should be interesting to work with.  :-DD
Post by: KungFuJosh on June 17, 2026, 02:52:02 pm
I know it's annoying, but given the price you paid for an SML03 that works fine except for the B3 option, I wouldn't worry about it. The PCB I made above should work to replace your bad switches.
Thanks,
Josh
Post by: TylerPeppy on June 17, 2026, 03:07:13 pm
Thanks,
Josh
Nice boards, thanks! I was working on some adapters in Altium yesterday as well, it was just taking a while in between gaps of work. While I shouldn't really be concerned, and can bypass the problem, I still need to get some rigid coax and solder-cup SMA connectors to put the fix together.
I am still working on figuring out the switch removal. I am having the issue where the thermal pad on the board is sinking too much heat into my table when desoldering. The white switches are more problematic than the black ones as the difference is the ground pour under the chips.
- Tyler
Post by: KungFuJosh on June 17, 2026, 03:14:28 pm
You're welcome. Hopefully it helps somebody.
Removing those switches is probably easier on a hot plate, but you gotta be careful not to remove anything else. If I were to try it, I would use a hot plate with the chip quik kit I linked before. But, I'd probably fuck it up, so take that with a grain of salt. ;)
Post by: rf-messkopf on June 17, 2026, 03:39:19 pm
I might be getting this wrong in my haste, but according to the schematic you posted you may need to swap the Control1 and Control2 lines (or RF_Out1 and RF_Out2). If I read the datasheets correctly, we have:
Since you wired RF_Out 1 on the SO8 to RF_Out1 on the QFN, and similarly for RF_Out2 as well as the Control lines, you need reversing them, don't you?
Again, I might mistaken, but please check.  :)
Post by: KungFuJosh on June 17, 2026, 03:44:45 pm
  • Control1 = 0V, Control2 = -5V: RF_Out1 active on SSW-124, RF_Out2 active on MSWA2-50+
  • Control1 = -5V, Control2 = 0V: RF_Out2 active on SSW-124, RF_Out1 active on MSWA2-50+
Good idea to check that. That's much more reading than I did. ;) Seems I need to study those a docs a little more.
Post by: KungFuJosh on June 17, 2026, 04:20:55 pm
I'm not sure. This needs translation. ;)
It sounds like you're probably correct, but it's slightly ambiguous.
Post by: rf-messkopf on June 17, 2026, 06:21:05 pm
Datasheet exegesis can be a source of true joy. This is one of the things you'd normally fix in software in your own designs. Anyway, as I read it, the two devices behave in opposite ways with respect to Control1 and Control2, so the lines should be reversed, but that doesn't necessarily mean anything. Maybe we can get another opinion.  :)
Anyway, it's good to have a way to replace that switch. This won't be the last time one of those turds will fail in an SML, so thank you for designing it.
Perhaps you can panelize that small board somehow as a breakout board. That would make handling and soldering much easier. A FR4 thickness of 0.5mm would probably be ideal.
Post by: TylerPeppy on June 17, 2026, 06:21:48 pm
Just having a quick look at your schematic versus the datasheets:
For MSWA2-50+:
1.) When VC1 = 0V, VC2 = -5/-8V => RFO1 = OFF, RFO2 = ON
2.) When VC1 = -5/-8V, VC2 = 0V => RFO1 = ON, RFO2 = OFF
For SSW-124:
1.) When VC1 = 0V, VC = -5V => J1-J2 path ON, J1-J3 OFF
2.) When VC2 = -5V, VC2 = 0V => J1-J2 path OFF, J1-J3 path ON
On your board:
RFI1 is connected to SOP8 pin 2. RFO1 is connected to SOP8 pin 5, RFO2 is on SOP8 pin 8.
- Looking at MSWA2-50+, the first case turns on RFO2, which means that SOP8 pin 2 is connected to SOP8 pin 8. In the second case, RFO1 is on, which connects SOP8 pin 2 to SOP8 pin 5.
- Looking at the SSW-128 Datasheet, the first case turns on J1-J2 path, connecting SOP8 pin 2 to pin 5. In the second scenario, J1-J3 path is connected, and thus SOP8 pin 2 is connected to SOP8 pin 8.
Assuming your PCB footprint for SOP8 is the same pin numbering as the SSW-124 part, I *think* the control lines probably need to be reversed.
Here's my interpretation:
║                ║                ║ SSW-124                  ║ MSWA2-50+              ║
║ VC1         ║ VC2          ║ Connected Path         ║ Connected Path         ║
║ OFF         ║ -5/-8V      ║ SOP8 (P2 - P5)          ║ SOP8 (P2 - P8)          ║
║ -5/-8V     ║ OFF          ║ SOP8 (P2 - P8)          ║ SOP8 (P2 - P5)          ║
- Tyler
Post by: KungFuJosh on June 17, 2026, 09:07:27 pm
Ok, here it is with the control pins reversed. Board thickness reduced to 0.8mm.
I don't love that I needed to use vias with uneven tracks, but it's a switch, so I don't think it should matter so much. Anyway...
Thanks,
Josh
Post by: TylerPeppy on June 17, 2026, 09:14:04 pm
Thanks,
Josh
Looks fantastic! I was wondering for mfg, if a flex PCB would be better thickness wise. It would probably be more susceptible to vibrations, but could be an option.
Post by: KungFuJosh on June 17, 2026, 09:45:57 pm
I wouldn't go nuts with the PCB type. Flex PCB adds extra risks like copper tear out.
0.8mm FR4 should be fine. I would use ENIG and maybe a heavier weight, with a minimum of 25um for hole copper thickness.
Post by: squadchannel on June 18, 2026, 12:58:12 am
At JLC, you don't necessarily need to enable the "Castellated Hole" option.
https://www.eevblog.com/forum/manufacture/manufacturing-less-than-half-castelated-holes-in-jlcpcb/msg6221843/#msg6221843 (https://www.eevblog.com/forum/manufacture/manufacturing-less-than-half-castelated-holes-in-jlcpcb/msg6221843/#msg6221843)
I've made a few PCBs in the past that violated the design rules for castellated holes, but there weren't any major issues, and JLC didn't say anything about it.
Post by: KungFuJosh on June 18, 2026, 01:33:48 am
That's good to know, but I avoid gambling with JLC these days. PCBWay seems to have better pricing in this case anyway.
Post by: KungFuJosh on June 18, 2026, 02:42:26 pm
PCBWay said:
Your design includes half-holes, but the portion of the half-hole inside the board edge is less than 0.25mm. To meet our manufacturing requirements, we recommend increasing the hole diameter or adjusting the hole position to ensure there is at least 0.25mm of the hole remaining inside the board.
I will fix that and upload a new gerber set.
Thanks,
Josh
Post by: KungFuJosh on June 18, 2026, 02:56:47 pm
Here's the updated gerber set.
Thanks,
Josh
ETA: This version passed review at PCBWay.
Post by: tszaboo on July 29, 2026, 05:07:06 pm
I got myself an SML02 with some issues. So far:
1. Radom screw loose in the enclosure on arrival, falls out at the back.
2. Output level not even close, 30dB or more difference from set level and output. At least the output goes to 2.2GHz. So I'm guessing blown output amplifier. Probably also issues with some of the switch MMICs.
3. Lines on the LCD. Probably a zebra strip issue, I have to se if this can be repaired or not.
4. This on is strange, very slow response to button presses. Often times I have to press a button for 2 seconds for it to register. The encoder is fast though, so not sure what's going on.
I knew about 2 and 3 when buying, let's see if I can repair this.
Post by: KungFuJosh on July 29, 2026, 05:35:52 pm
A good cleaning and a firmware update might help with the responsiveness. From the sounds of it though, you probably need to do a thorough cleaning and inspection of the mainboard also...and check the PSU voltages.
What options are installed?
Post by: TylerPeppy on July 29, 2026, 07:56:07 pm
You might want to read about the tests I did on mine and how the output unlevel issue was interestingly just a module. You didn't mention if it has any other installed options though, so my experiences might not be worth much.
On the other hand, can you set up a slow sweep from 9kHz - 2.2GHz and leave trace persistence ON on the SA for the test? I am curious to see if the gain error is flat.
The other thing, is you might want to do a self-test. If it passes, the output amp is probably fine, and something else in the path is broken. Mine did this, and all self-tests passed but the B3 pulse mod option was busted. When bypassed, it had no issue on the output.
Post by: KungFuJosh on July 29, 2026, 09:16:09 pm
Probably worth trying self-calibration also.
Post by: TylerPeppy on July 29, 2026, 09:37:52 pm
Self cal might find some issues, but probably won't solve a 30dB discrepancy.
Also, read the repair manual, and in specific, section 7.6. It has the test point voltages for the 2/3GHz output module.
(https://manuals.repeater-builder.com/te-files/R&S/R&S%20SML_SHB_BD2_03%20Service%20part%202.pdf)
You should be able to access the test point utility through the front panel interface to check the voltages as well. This was useful when checking my output from the B3 module.
Tyler
Post by: tszaboo on July 30, 2026, 07:50:25 am
I did read through this thread. I didn't see any options listed at the back, not sure if RS does that. And I didn't have time to take it apart. That have to wait till this weekend. I hope there is an option, seemingly it uses the same switch MMICs so I would rather have a working output level than pulse generation.
I also made a quick scan, measuring the output level at different frequencies and it seemed mostly consistent. I've also saw sometimes 2nd order harmonics (as  I recall) 20-30 down, which would mean I think that filter is getting bypassed, maybe a stuck MMIC.
Shahriar from TSP had a few repairs where it was the output cabling, I don't think I'm that lucky, but we will see. The test you suggests make sense.
Also, when looking at this thread before buying the SML02, I noticed that the manual's block diagram and the teardown photo KungFuJosh posted, they don't seem to align 100%. I'm not sure how exactly, but the switches seem to do something different than what's in the manual.
Post by: rf-messkopf on July 30, 2026, 09:08:35 am
This is a known problem with older SML. From what I hear it is the contact pill in the elastomeric keypad that degrades. I know that some people have experimented with conductive silver, but that is apparently difficult to fix. Luckily, mine doesn't do that.
Post by: TylerPeppy on July 30, 2026, 12:44:47 pm
This is interesting, when you mention the harmonics. They should not appear that high relative to the carrier. This is almost the exact same issue from my B3 pulse modulation option, where the switch MMIC died and one of the output amplifiers was also broken according to test points.
Not entirely sure what components were all broken on the B3, as I bypassed it and called it a day. I am hoping to swap the switches out at some point, though.
Post by: nctnico on July 30, 2026, 01:41:40 pm
You can buy 'stickers' from Buttonworx which have a conductive pattern printed on them. They go between the original rubber key mat and the contact area. They work like a charm.
Post by: tszaboo on July 30, 2026, 02:57:25 pm
Interesting. I've google searched for this quickly and it also gave me an alibaba link as well.
Searching on AliExpress, " Diameter 3/4/5/6 MM 4 Sizes Black Conductive Rubber Pads Keypad Repair Kit" is an item for ~3 EUR.
I also though so. I have low frequency output and modulation input, which might be an option (not shown on the picture). Anyway, I'll crack it open and see what's inside. And I really apricate the help.
Here is some brain dump from me:
From what I can see in the manual, the difference between the SML02 and SML03 is the number of filters after the step recovery diode.
Table 7-1 Frequency schedule of Output Unit 2 GHz / 3 GHz
n Input frequency Output frequency
2 605.25 to 909 MHz 1210.5 to 1818 MHz
3 606 to 885 MHz 1818 to 2655 MHz
4 663.75 to 825 MHz 2655 to 3300 MHz
The selection of the desired spectral line is made by means of a tunable, three-stage bandpass filter
which can be set to the desired frequency via a D/A converter using calibration data stored in the
instrument. This filter suppresses unwanted spurious, i.e. adjacent spectral lines from the step-recovery
diode, down to -60 dBc. The filter frequency ranges are specified as follows:
Table 7-2 Filter frequency ranges
Filter Frequency range
1 1210.5 to 2200 MHz
2 2200 to 2800 MHz
3 2800 to 3300 MHz
This seems to be the biggest difference between the SML02 and SML03, maybe the 02 doesn't have the 2nd and 3rd filter.
Anyway, first fixing.
I found on the KO4BB website an SME03 service kit, someone suggested on the groups.io to use that. It's written for windows 3.1 , there is no way to run that today unfortunately.
From what I see, there is some limited documentation on the diagnostics commands in the operation manual (SCPI commands), telling me this:
:DIAGnostic[:MEASure]:POINt?
The command triggers a measurement at a measuring point and returns the voltage measured.
The measuring point is specified by a numeric suffix (cf. service manual).
Example: :DIAG:MEAS:POIN? 2 Response: 11.56
Service manual tells me to run the software.  >:(
Post by: TylerPeppy on July 30, 2026, 03:24:24 pm
2 2200 to 2800 MHz
3 2800 to 3300 MHz
The test points are a bit hit or miss with the software tool, I have had decent luck just using the built-in test point utility on the SML to check them. Problem is, they aren't all available unfortunately.
Post by: tszaboo on July 30, 2026, 04:50:48 pm
OK, I made some time to open it up. The output coax assembly looked strange. There is an intentional split in the ground connection. I measured it with a VNA, things are even more strange now.
I'm not sure why RS wouldn't just connect the ground together in the first place.
But then, the S21 and S12 is down like 40dB or more. I even flipped it, because maybe they are doing something directional.
Did anyone measure this output assembly before?
Anyone wants to take bets before I connect the spectrum analyzer on the SMA directly, that this is the main issue for the signal loss??
Post by: KungFuJosh on July 30, 2026, 04:59:07 pm
The cable shouldn't look like that. It appears somebody tried to repair it. It should be a solid/single semi-rigid cable with the cores on it directly.
The B19 output cable illustrates this more easily. The front panel cable is the same idea, but shorter.
Thanks,
Josh
Post by: nctnico on July 30, 2026, 05:00:17 pm
The cable shouldn't look like that. It appears somebody tried to repair it. It should be a single semi-rigid cable with the cores on it directly.
I agree with that 100%. The output cable should not look like that. It needs to be replaced.
Post by: tszaboo on July 30, 2026, 05:04:43 pm
Thanks,
Josh
Thanks Josh, I also think so. But it looks very intentional on first sight.
But now I've put it under the microscope, and the split looks like it broke somehow? I've never seen a broken hardline coax where it was broken on the outside.
Post by: KungFuJosh on July 30, 2026, 05:09:43 pm
With the wrong tools, and a solid lack of skills, anything is possible. ;)
Post by: tszaboo on July 30, 2026, 05:29:26 pm
Actually, this could be shipping damage. I ordered it to a DHL service point. The guy handed over the package by slapping it on the counter on the shorter edge of the package. It took the better half of me not to shout with him. Fragile written on the package and all...
Other time I got a HP Power supply that was just tossed into my garbage bin (for paper) and a note delivered to me. I think these delivery companies could somehow break solid steel balls.
I'm not saying it was this. Maybe the seller also received it with this already.
Post by: nctnico on July 30, 2026, 05:50:11 pm
Yep. Every now and then I lend a hand with test equipment repairs and you don't want to know what I've encountered so far.
That is your problem. Equipment should be packed so it survives falling off a flight of stairs. Couriers really don't care about fragile signs etc. Just make sure equipment is packed properly. If you don't then you should accept shipping damage. I've seen a fair amount of that...
Bubble wrap or instant foam are the best ways but with instant foam it is super important to place equipment in the middle so a foam layer can form around the equipment. Either way: there should be at least 8cm of bubble wrap, air cushioning or foam between the equipment and the card board.
Post by: KungFuJosh on July 30, 2026, 06:33:31 pm
It doesn't look like it happened in shipping. The photo looks like part of the cable is semi-transparent instead of grey. Somebody botched it.
Post by: tszaboo on July 30, 2026, 07:51:35 pm
You are right, this is someone's doing. Here it is compared to a high quality N to SMA connector. I hope to use this (and a semi-flex SMA-SMA cable) to fix the front connector. The center contact is a lot deeper on the SML's connector, I don't think it even makes contact at all.
On the good connector the center pin is 4.3mm deep, on the bad one it's 9.2mm.  :scared:
Post by: KungFuJosh on July 30, 2026, 08:18:54 pm
If you can figure out how to reuse those cores, you'll be happy. If you can get a semi-rigid cable, and add a crimp connector, that would probably work.
Post by: tszaboo on July 31, 2026, 04:00:46 pm
Taking it apart further... Cleaning the keypad seemed to help a little, feels better, but it still doesn't register a lot of button presses so I will try the repair kit.
I measured the SMA connector directly, the level is still bad. I did the test
It is, that variation is more likely my bad quality coax.
 [attach=1]
I don't have OCXO or pulse modulation options.
I looked into the diagnostic menu. What jumped at me is the operation time is 900 hours, which is not a lot. And the "overload protection count" was 122 which sounds like a lot, and I'm not sure how that even happens so often to such an instrument. I'm not sure either if this is kept in the battery backed RAM and if this resets.
Harmonics seem to appear only below 750MHz.
I measured the output of the 2/3GHz output, which was 8.6dBm when the output was set to 0dBm. And it went all the way to 22dBm, when the output was set to maximum. So this module is working, the attenuator has the issue.
Some other things that I've noticed. I went through the built in testpoints (in the menu), and TP 404 and 407 was 0V. This is called MB 8VHF1, which makes me think this is supposed to be 8V, and not 0V. Can someone check it please? This is not covered in the manual.
Post by: KungFuJosh on July 31, 2026, 04:34:08 pm
That's nothing. 100,000 would even be considered low. That said, the number could be inaccurate.
The overload thing probably doesn't matter. I think that's automatically counted when you set the output past a specific dB level.
That's (unfortunately) normal. The attenuator/output module is the most common failure point. You can use the switch conversion board I shared earlier in the thread if you need to replace them with something new.
Thanks,
Josh
Post by: tszaboo on July 31, 2026, 07:41:15 pm
Thanks,
Josh
Thanks, I was also expecting this to be the issue. I've taken it apart, and found 3 switches that had the issue, and a 4th may be on it's way out. There was a lot of voltage drop on the resistor series with the IC control pin.
Looks like my board is not made with the P35-4227-C06-300, like everyone else's but it's with SSW-124. The switches have a W1 marking like the datasheet.
https://www.alldatasheet.com/datasheet-pdf/view/157236/STANFORD/SSW-124.html (https://www.alldatasheet.com/datasheet-pdf/view/157236/STANFORD/SSW-124.html)
Standford Microdevices became Sirenza Microdevices
In 2007, Sirenza Microdevices was acquired by RF Micro Devices
Which is now Qorvo, who makes everything that you don't order a million or pay like the military obsolete.
Post by: rf-messkopf on July 31, 2026, 08:47:25 pm
According to the service manual:
Diagnostic pointDescriptionminmax
404 D_8VHF1Supply voltage for RF stages7.558.35
407 D_8VHF2 Supply voltage for RF stages 7.558.35
Both test points belong to the output module. The manual says "Check 8-V voltage regulator N21, V146" and "Check 8-V voltage regulator N21, V234" when these are out of tolerance.
Post by: bte on July 31, 2026, 09:26:32 pm
Out of curiosity, I tried that software on 32-bit Windows 7 and it seemed to start up fine. Maybe the software could be made to work along with a recent NI-VISA installation and a PCI-E (i.e. something recent enough that has a 32-bit Windows 7 driver) GPIB adapter.
Post by: tszaboo on July 31, 2026, 09:46:06 pm
Thanks. I just found out that the service manual comes in two volumes and I only found volume 2 so far. But Volume 1 was on Elektrotanya.
I suppose the circuit diagram isn't available, or am I not looking hard enough?
Also worth reading, CCFL to LED conversion:
https://www.elektormagazine.com/labs/repair-of-a-rohdeschwarz-sml03-rf-signal-generator
 (https://www.elektormagazine.com/labs/repair-of-a-rohdeschwarz-sml03-rf-signal-generator)
Post by: KungFuJosh on July 31, 2026, 09:59:05 pm
I have maintenance, firmware, and service manuals attached to the first couple posts in this thread.
I think I shared them somewhere else before, but I just added service to the 2nd.
Post by: tszaboo on August 01, 2026, 01:48:46 pm
I've been looking at this attenuator for a few hours now, trying to make some sense of it.
The manual gives some idea what's going on, but I think it's somehow misleading on so many levels.
So we have a declaration for the attenuation levels:
The different attenuator pads of 5, 10, 15, 30, 40dB permit to set the attenuation in
the range from 0 to 125dB with 5-dB resolution. The attenuator pads are combined
in 5 groups and switched with GaAs switches.
The 5 groups makes no sense with the layout that we have.
Then we have a truth table for it:
[attachimg=1]
If I read this, SWI1 2 and 3 are 5dB attenuators, SWI4-5 are 15dB and SWI6 and 7 are 40dB, total 125dB.
Below is a picture (from Josh) that I edited, numbering the switches my own way, and drawing out all the 0dB loss paths in blue.
What we actually have is this: SW 1 2 and 3 connects the input directly to the output with some limiters in between.
And then I started tracing my attenuator. I set it to the highest output level, and got almost 0dBm out of my generator. Judging by the IC's datasheet, negative control voltage turns the switch to that path.
And I was tracing the RF, by looking at which control voltage is present where.
The confusing part was, that the pins are swapped, the RF pin that's conducting is to the opposite of the negative control voltage. Anyway by the looks of it for me switch 1, 12 and 4 is damaged, they have almost 0V on the control pins, where the other side of the resistor has -7V. Ah the resistors. There is 100Ohm on the other side of the board in series with the resistor on this side, which is 6800Ohm. I placed a 1Kohm resistor parallel with the 6.8K to se if it makes a difference. Maybe just a bit of extra current brings back the switch. And it made a difference,  I got extra 6dB to the output signal. Which is still low, so this is not a solution.
11 and 12 switches in two different attenuation settings, where there are switches on both sides of the attenuators.
10 and 4 acts another way, where they also select two different attenuations, but their outputs are a single trace. What must be happening here is that they use the absorvative characteristics of the attenuator to make the non-selected RF path into a resistor.
Switch 5 and 3 can select whether switch 4 is in the path. Probably it's a way to increase isolation, otherwise it doesn't make sense to use 3 switches for 3 different gains.
Similarly, 6 and 7 selects whether 10 is in the path.
SW4 doesn't change until we reach -80dBm on the output. SW 5 doesn't change until -40dBm. So I thinkSW4 selects either a 40dB or a 80 dB attenuation.
There is also something going on with SW3. The driving of it is different, and depending on the output level, it has either -5V or -8V on the pins.
For me it's clear that my main issue is switch 1, which is always in the path. I don't really care much about the low ranges for now, plus it doesn't work anyway, I would much rather have a generator that can output 19dBm. So I'm going to swap SW1 and 5, or short out 5.
Post by: tszaboo on August 02, 2026, 05:50:17 pm
So I've replaced that input switch.
And I'm seeing something quite exceptional.
The driving pin of these MMIC switches work as a non volatile memristor. Memristor is a device that stores a resistance value, and non-volatile, because even after removing the power it stays that way. At least the broken ones, the good ones are fine.
Heating it up, it returns to about 2Mohm resistance between the gate and ground. This is the same for the good ones. And depending on their state when turned off, they might be in this 2MOhm state, or something as low a 2-3 KOhm. That's why they don't work, they pull the pin low when this happens, it makes a resistor divider with the 6.8KOhm resistor in front of the IC.
Post by: tszaboo on August 11, 2026, 09:39:00 am
The IC I swapped to the input of the attenuator was also toast, so I went in an other direction with the repair, hacking in another switch IC. So this apparently works.
That trace is in max hold, that' why there is something every 100MHz. I got 17dBm max out of the 19 nominal. The difficulty of hacking in this IC is quite high, but I wanted to test it before committing more effort of making an adapter PCB. Sorry for the upside down generator in the picture, but it's this way. The generator was set to 5dBm.
The IC is MASW-007935.
Post by: tszaboo on August 18, 2026, 09:11:47 am
While waiting for my adapter PCB, I turned my attention to the main RF generator board. Here I have a power supply failure, Some 8V is missing from somewhere. Below are my teardown pictures, I'm going to annotate it with some reverse engineering.
Post by: tszaboo on August 18, 2026, 09:51:56 am
Below is my effort trying to understand this board.
My first big question mark was, where is the VCO? And then it hit me, the entire board is pretty much just a large multiplier, there is no VCO here..
I'm going to go back to the manual, trying to find some clues, to understand what this 8V actually does.
mod: And closing it back, because the testpoint is not on this board. :-DD
Post by: tszaboo on August 18, 2026, 10:03:13 pm
OK, another set of teardown photos. You can see the block diagram on the cover of the Mainboard.
My 8V power supply magically fixed itself after opening and turning it on.  :-//
I was measuring 8V on that point. The fact they call it "Supply voltage for RF stages" makes me think this is the right point.
Looks like someone had a repair at this, the white part ( RF transistor? MMIC?) seems to have some extra solder and the PCB is doing something there.
I've also included some thermal images. Some of these parts run hot, 70-80 degrees, below the cover, so it's not an airflow issue. And I think these parts meant to run hot, they are reverse geometry resistors (0612) some of it in parallel.
Post by: CrazyTiger on August 18, 2026, 11:51:19 pm
In the past as an experiment, i tried making an  tiny carrier board to replace the existing switches marked W1 on the attenuator to something modern, it worked sort off, since I had the adjustment program, NRVD and NRV-Z51, even adjusted the unit. Problem was I could not get the frequency level response linear above 2GHz, main reason likely the carrier board was FR4, 1.6mm, with limited space, re-routing rf traces becomes a hasle and noisy, could have performed better with a better pcb material and thinner board. But it was a weekend experiment.
Post by: KungFuJosh on August 18, 2026, 11:55:58 pm
Which one? SME03 or something else? Do you still have it?
Thanks,
Josh
Post by: tszaboo on August 19, 2026, 07:35:36 am
Interesting. I have an SML02, not 03. So the frequency is limited.*
I couldn't really attempt to make the trace 50 Ohm on this adapter board. There is a complicated transition from an SO8 pad to a castellated edge, then a PCB, then the pins of the SOT23-6 switch. The trace is only 1.5mm long, and it's less than the half of the total distance RF needs to travel.
*Though from what I can see maybe there isn't any hardware difference between these two types.
Post by: rf-messkopf on August 19, 2026, 12:24:52 pm
Another reason could be that the adapter board compromises the impedance matching between switch and transmission line, leading to reflections which cause ripple. Also, the electrical length of the lines may have been slightly changed. If the circuit relies on phase matching, this might also lead to ripple.
Edit: The layout might also compensate for the SO-8 pin of the original switch by matching elements in the layout (e.g., trace thickness). This may be upset by the adapter board, even if you try to stick to 50 ohms impedance as close as you can.
Post by: KungFuJosh on August 19, 2026, 01:29:18 pm
There might be something as stupid as jumpers that set the top frequency in the 2G/3G module. I never tried them though, since all the units I had were 3GHz. They use the same module for both units, so I dunno if they bothered to change anything else or not.
Admittedly, it's a dumb guess, but what do those jumpers do? 🤔
Post by: tszaboo on August 19, 2026, 09:11:36 pm
It's a great guess, but it's only part of it.
I checked my jumpers and it's in a different position. When I moved it to the same position as on this picture, I get an error while starting it up. EEPROM data missing, calibration lost. And the generator only goes to 1.1 GHz.
So maybe rewriting the EEPROM with content from an SML03 and then manually calibrating it, might just give it that extra speed. Which I wouldn't mind, testing 2.45GHz stuff would be interesting. I have to see into the service menu as well, maybe there is something to "reset" the EEPROM content, but I will attempt any of this after I made a backup from it.
Post by: KungFuJosh on August 19, 2026, 10:42:44 pm
Does running the self calibration help?
Post by: TylerPeppy on August 19, 2026, 11:25:32 pm
You might be onto something. Here's the inside of my SML03. Notice the jumper closest the ribbon cable is in the upper position, rather than the lower one on the 2G/3G module...
I wonder if this is how one gets the 3GHz option, and then the unit is subsequently coded to work in the extended range.
Tyler
Post by: KungFuJosh on August 19, 2026, 11:38:57 pm
I dunno if there's any coding involved. This series seems to me to be "slap it together and it works."
My guess is that you flip the jumpers, and either run the self cal, or the external cal script to accommodate the new range. I'm hoping that the self cal will be sufficient.
Post by: tszaboo on August 20, 2026, 12:25:55 pm
I don't have the module in front of me. As you can see the jumper is connected to pin 14 of that connector.
According to the service manual, Pin 14 is EEPROM I2C DATA. I don't see on my previous image where the other jumper would go, but I'm going to guess it's the other I2C pin.
This, on the bottom right, looks like a pullup resistor to me, that gets selected by the jumper.
Anyway, it should be trivial to read out this EEPROM, I'll make some time this weekend to do that.
Post by: tszaboo on August 20, 2026, 09:27:20 pm
See below the EEPROM's content of my 2/3GHz output unit.
There is one text on it, OPU3, which is the name of this unit.
The rest of the EEPROM is FF.
I get the error messages 313 and 315 when I change the jumpers, 313 is lost calibration, 315 is lost configuration. While it uses the
0000: 05 00 2C 00 CE 47 10 00 00 20 00 00 C7 61 A6 00  |..,..G... ...a..|
0010: 02 00 95 01 CA 7E F9 05 BC 2A 00 00 CA 00 4F 50  |....~...*....OP|
0020: 55 33 00 00 00 00 00 00 00 00 00 00 64 00 1C 00  |U3..........d...|
0030: 80 FF 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |................|
0040: 00 00 00 00 00 00 00 00 FF FF 00 00 FF FF FF FF  |................|
The jumper X2 seems to set the middle pin either to the SDA, or GND. Considering that SDA would be pulled up most of the time, I guess this is just to select 3.3V or GND on something.
Post by: tszaboo on August 20, 2026, 10:10:29 pm
And here is the attenuator's EEPROM content while at it.
It's a lot more data. It has ".Attenuator2.2.d" in it as ASCII.
Post by: KungFuJosh on August 20, 2026, 11:36:26 pm
Have you tried running the self calibration after changing the jumpers?
Post by: tszaboo on August 21, 2026, 07:41:22 am
I'll fix the attenuator first, before doing any sort of calibration. I think half the steps aren't working properly. Then I'll do one without changing the jumpers to make sure my procedure is right.
Post by: CrazyTiger on August 24, 2026, 07:06:59 am
Agreed, It was extremely small space with RF traces going in a X layout, and nearly imposible to create a proper 50 ohm trace. I was happy that it worked to certain extent. The SML is with 70 y.o man now, he is happy testing his homebrew radios using it.
Post by: CrazyTiger on August 24, 2026, 07:09:35 am
Thanks,
Josh
Everyone can download from my google drive here
 https://drive.google.com/file/d/1KbRV6YfIuk0Jys9V2ygdzytKlReskcqF/view?usp=sharing (https://drive.google.com/file/d/1KbRV6YfIuk0Jys9V2ygdzytKlReskcqF/view?usp=sharing)
Post by: KungFuJosh on August 24, 2026, 06:00:38 pm
Thanks for sharing that!
Post by: tszaboo on August 25, 2026, 05:15:33 pm
Well, I've just tested this, and at 100MHz, it gave me the correct levels from 15dBm to -120dBm. I call that a success.
I think I replaced unnecessarily maybe 2 switches because I made a short under the repair PCB.
If anyone wants one of these boards, PM me.
Now, back to that keyboard repair (which I forgot to order conductive pads) and see what I can do with that LCD lines.
And testing, if the frequency response was affected by the switches. Maybe a calibration.
BTW, I don't like these GAAS switches. When not powered, they are like 2 Ohm to ground. Makes searches for short circuit practically impossible.
Post by: KungFuJosh on August 25, 2026, 07:50:42 pm
Do you mind sharing the gerbers? I shared gerbers previously for a different option as well.
Post by: tszaboo on August 28, 2026, 09:29:36 am
Sure, I wanted to test is a bit to make sure it works. I'll gather the files and make a github repo for it when I have time.
Looks good up to 2GHz. That variation on the amplitude is not unlike the original parts. The picture is a mx hold trace with 10dBm nominal signal.
I see a bit of 2nd harmonic, but by the looks of it the specifications are -30dBc? Might be even in spec.
Now, onto calibrating it. I guess I jut terminate the output and send it. It's doing that now.
So that run just fine. No real change on the output level, because the attenuator is an external calibration.
 By the looks of it, it's 30 something attenuation steps at around 40 something frequency steps.
So counting only 30 seconds each step, it's still 10 hours to do  :palm:
I was able to run the service program, but I don't have the right equipment to do that cal. So I guess next would be
1) Figuring out if I can control my SA and the SML02 over SCPI
2) Figuring out to change calibration values over SCPI
3) Getting the right RBW/VBW values
4) Wishing that I had a power meter
5) calibrate the RF cable
6) Writing python script to calibrate it, or vibe code it
Sounds easy  ;D
Post by: KungFuJosh on August 28, 2026, 02:45:36 pm
Sounds easy  ;D
I made a definition for the SML series to work with TestController. I also made one for the V3500A. TestController has a built in Parameter Sweeper, so I've done tests sweeping across the full range of the SML03 (and the SMIQ06B and others).
The SCPI commands are pretty simple for running the tests and the manual has commands for calibration. I don't know if those commands are any different than the front panel self-cal though.
Post by: tszaboo on September 14, 2026, 12:10:31 pm
I didn't really had time to work on this, other than some software claude coded for calibration.
When doing a verification, it turned out that in some ranges the signal was 5dB down, so I have to go back to solder before I can attempt to calibrate it. At least everything now is controlled by SCPI.
