Products => Test Equipment => Topic started by: Hugoneus on February 23, 2018, 05:04:31 pm
Title: Rohde & Schwarz ZNLE 1MHz - 6GHz Vector Network Analyzer Review & Experiments
Post by: Hugoneus on February 23, 2018, 05:04:31 pm
You can watch the video here: [1 Hour & 5 Min]
youtu.be/6cd5JcPKi14 (http://youtu.be/6cd5JcPKi14)
The Signal Path
www.TheSignalPath.com (http://www.TheSignalPath.com)
www.YouTube.com/TheSignalPath (http://www.YouTube.com/TheSignalPath)
www.Patreon.com/TheSignalPath (http://www.Patreon.com/TheSignalPath)
Title: Re: Rohde & Schwarz ZNLE 1MHz - 6GHz Vector Network Analyzer Review & Experiments
Post by: TheSteve on February 23, 2018, 06:04:44 pm
Thanks for the video Shahriar. I was hoping to see you demo the Gore cables and show the amplitude and phase stability of a Metrology grade cable when moved etc. If possible please consider showing us the various grades of cable in a future network analyzer video.
Post by: hscade on February 23, 2018, 06:08:25 pm
well as always enjoyed watching  :-+
Post by: mikeselectricstuff on February 23, 2018, 06:32:09 pm
Those fancy cables look like Audiophool cables...
Post by: TheSteve on February 23, 2018, 06:39:07 pm
Hah - except in the case of RF it would be pretty easy to prove they are better.
Post by: Hugoneus on February 23, 2018, 06:40:26 pm
I assure you they are not. Not every application needs them, but they are needed in some circumstances. :)
Post by: Hugoneus on February 23, 2018, 06:46:19 pm
Sorry I didn’t get to do that. My Gore cables are very rigid and long and it made it difficult to setup on my bench.
Post by: hagster on February 23, 2018, 07:54:04 pm
Great video and very informative. Looks like a nice machine and I totally agree on the benifit of the short depth. I used to use an enoumous HP machine came in two sections and needed its own trolley.
Does the ZNLE have TDR and gating modes btw?
Post by: Hugoneus on February 25, 2018, 10:41:52 pm
Those features exist in the ZNL model (as options) but sadly not in the ZNLE model. :(
Post by: hendorog on February 26, 2018, 09:10:56 am
Just wondering what sort of stuff can you do with TDR at 6GHz?
Is that a high enough frequency to see the effect of an end launch SMA on a PCB for example or does that require a higher frequency?
Post by: hagster on February 26, 2018, 08:31:25 pm
It can still be handy. You can find damaged cables for instance.
With gating you can detect and remove the effect of external reflections when measuring antennas outside of a anachoic chamber.
As far as I know it doesnt really need hardware mods. I guess if you can export a touchstone file you can just run an FFT on the frequency data to calculate it yourself.
