Author Topic: Tektronix TDS520B Hack / Upgrade to TDS620B ?  (Read 7510 times)
Offline sorenkirTopic starter
« on: November 30, 2014, 11:27:54 am »
Hello group,
I have seen interesting hack/upgrade data in the following thread :
https://www.eevblog.com/forum/testgear/tek-tds-3054b-vs-tds-744a/
I have a TDS520B, 2 channels 500MHZ 1GS/s. I think I could see if an "upgrade" to TDS620B (same BW and number of channels but better sampling rate) is possible.
Configuration resistors for TDS520B on acquisition board are (see photo):
BID0=R1061 missing, BID1=R1062 soldered, BID2=R1063 missing, BID3=R1064 soldered --> 1010
Configuration resistors on processor board are (see other photo):
ID0=R17 soldered, ID1=R15 missing, ID2=R13 missing, ID3=R12 soldered --> 0110
NVSIZE0=R9 soldered, NVSIZE1=R7 soldered --> 00
(signal names as per TDS520B Component Service Manual pdf p269 & 297)
I had no chance with finding board pictures for TDS620B on Google.
Does anyone by chance have this configuration resistors data or photos of acquisition board (bottom side) & processor board ?
Thanks,
Michel.
« Last Edit: November 30, 2014, 12:35:23 pm by sorenkir »
Online nctnico
Re: Tektronix TDS520B Hack / Upgrade to TDS620B ?
« Reply #1 on: November 30, 2014, 12:12:57 pm »
These scopes are completely different so I strongly doubt such a hack is possible. The TDS600 series are realtime sampling oscilloscopes with very short memories.
« Reply #2 on: November 30, 2014, 12:52:05 pm »
nctnico, I think you are right on the architecture point.
Anyway, TDS520B has 2 samplers operating each @ 500MS/s. Maybe there is a configuration that allows them to operate @ 1GS/s (that's what happens when a TDS744A, 4 samplers @ 500MS/s, "becomes" a TDS784A, 4 samplers @ 1GS/s, as some reported in the other thread) ?
Unfortunately, that config. does not seem to correspond to any model. So maybe a dead end  :-[.
Michel.
Re: Tektronix TDS520B Hack / Upgrade ?
« Reply #3 on: December 03, 2014, 02:21:25 pm »
Hello,
I have seen on the photos of a TDS724A acquisition board that the configuration resistors are exactly the same as for my TDS520B (in this post:  TDS 724A saga, dead H2462H, many questions, please help !!! ) !
So the complete model definition probably includes the processor board configuration...
Does anyone have a close-up of the configuration resistors (R12 to R17 near U2000) of the processor board of a TDS 724A ?
Thanks in advance,
Michel.
Online nctnico
« Reply #4 on: December 03, 2014, 04:03:08 pm »
Attach a dip switch and try the combinations to see if the firmware in your oscilloscope supports other models.
Re: Tektronix TDS520B Hack / Upgrade to TDS724A failed
« Reply #5 on: December 13, 2014, 02:21:02 pm »
I have tried to remove R12 on processor board which seems the only difference between a TDS520B configuration and a TDS724A (apart from colour display hardware which is not present in TDS520B). The acquisition board is the same with the same configuration resistors.
The scope booted with a banner indicating TDS724A. But the display had some parts blinking quickly.
Also, the acquisition and position control were inoperative. The limitation to two live channels remains. Plus a truncated nvram related message in the error log (WARNING: 600 remote nv memory ac...).
So, there must be something else (but I have tried !)...
Michel.
Offline tinhead
« Reply #6 on: December 13, 2014, 11:31:01 pm »
the only diff between TDS520B and TDS724A are on processor board and in nvram (TDS5 enabled/disabled). So when you already playing, try the next model, TDS782A. Change the processor board first back to TDS520B and then acq board from 5 to 1, maybe the firmware will not check the nvram anymore.
Re: Tektronix TDS520B Hack / Upgrade to TDSxxx
« Reply #7 on: December 20, 2014, 04:25:49 pm »
Hello,
I have tried what tinhead suggested : processor board as TDS520B and acquisition board as TDS782A (by adding a strap on R1063 --> acq id=1).
I managed to have a TDS xxx on the banner screen !
This model is capable of 2GS/s with only one channel active (whereas TDS520B goes only to 1GS/s). That's what I was expecting.
But :
The two DACs do not interleave properly at 2GS/s, see photo. Calibration is required...
A side effect of this configuration is that the TDS xxx is not recognized by the WaveStar software  :(.
I don't think that a 2 channels monochrome model with 2GS/s acquisition capabilty exists, so I fear that no solution exists for this issue.
Michel.
« Last Edit: December 20, 2014, 04:27:44 pm by sorenkir »
