Author Topic: RPL1116 (MSO1000Z) and PLA2216 (MSO5000) Active Logic Probe teardown  (Read 18169 times)
Online gizmo5418
I have noise if I have a "PCB Breakout" attached without connected logic probes.
pmnxis, connecting the ISP programmer at the same time that LA was connected to the oscilloscope was probably not the right solution.
Preservation of my oscilloscope with "PCB Breakout" plugged in without logic probes:
The following users thanked this post: pmnxis
Offline pmnxis
  • Country: kr
  • Country: kr
thanks for you pictures.
Mine got some "too much" noisy issue on 6th channel when didn't connect cable 0to7 channel.
BTW I solved issue that channel 1ch(start from zero) didn't work.
I was soldering each only one point to 2 bypass capacitor near the MCU.
and re-soldered array capacitor. and then it works.
for now, a left issue is a known issue. some channel is inverted.
hope it would be nice fix later. but I think that's not immediately to me and enough for see extra point for change or triggering something. :D
« Last Edit: May 17, 2019, 07:15:50 pm by pmnxis »
Offline thmjpr
Can confirm the noise, even with the Logic analyzer completely disconnected, some channels seem to have injected noise and go wild. Wonder if a high value (100k) pull-down on the connector board would help to get rid of that. Seems odd that Rigol would leave it high-z.
Also confirm the original pinout of the connector has many signals flipped (D1, D3, D5, D7, D9, D13, D14, D15), see attached for what it should be. On mine, dumb luck meant I flipped one of the pinouts of the LM7324, so I only have these flipped: D3, D7, D14, D15. I'll think if I want to mod the main board or the pods to fix this.. Once I've done some high speed testing, can send out USBC boards if anyone wants the extras (knowing that you have to do some mods).
Noticed that 2V5 seems to get pulled down a fair bit, with just one pod connected I was reading 2.2V. Not sure what the wire gauge in my USB cables is.
Also if it wasn't clear (because I didn't realize this), the Vref is: -1.5 to +1.5 to represent a -15 to +15V trigger level. How I have it now, the STM32 can only read positive trigger voltages (0 to 1.5V).
Offline Rerouter
100% certain on D11 and D14? they break the pattern of all the others
Online TK
By completely disconnected you mean the minimum required for the Scope to detected and activate the logic analyzer, correct?  The microcontroller that was added for the LEDs, is it active when you detect the noise?
Offline thmjpr
See attached for 40MHz SPI signal on analog + logic input, seems to work quite well other than a bit of jitter.
One issue is there is a ~150ns offset between the analog channels at the top, and the same digital channel on the bottom. I'm thinking this is worth reporting as a bug.
One possible workaround for this would be adjusting the analog channel offsets, so all are -150ns. But that is a lot so it may not be possible.. will check.
Temperature is 55C on the chip and 45C on the bottom of the board (in open air at 23C). It will get a bit worse inside the case, but would likely be fine without a heatsink.
Yeah thats right, nothing connected to the Rigols 50-pin port at all. Sometimes the LA will run for a bit, even after unplugging the pod (some bug or timing detection). But you can manually short pin 1 to ground too, to enable the LA and test this way as well. I suppose in Rigols design case it doesn't matter, as you either have all channels connected, driving the inputs hard, or not connected and LA disabled on the screen.
Good point about the micro though, I could see it having some effect.
It is an odd pattern, and it would make more sense if it was N, P, N, P repeating consistently. Actually now that you mention it, the bit order does have a "logical" pattern: if you skip two pins, it does go from D0, D1 .. to D7, and the same for D8 to D15. At first I thought it was completely nonsensical.
I will go over them again tomorrow now that I've modified my pod to swap D4 and verify the pinout (having the resistor pack made it easier, see photo below).
« Last Edit: May 22, 2019, 05:43:35 am by thmjpr »
Offline thmjpr
With the pod now having D1 and D3 flipped, the signals D11 and D14 are still backwards. So they don't match the pattern seen on the other signals. To eliminate all possible sources of error it could be checked manually at the input pins.
Digital to analog delay cant be adjusted with ch-ch skew adjustment. This only delays the analog channel further forward on the x-axis (+/-150ns max). Maybe someone with the official logic pod can verify they see this digital-> analog delay as well. Adding a fixed offset in firmware would be nice, an adjustable offset in the menu even better still.
Channel to channel jitter is OK, I will get a shift back and forth of 1ns on D3, D2, D1 when triggering on D0 for example. Rigol spec is 2ns typical, 5ns maximum. Sample rate is 1GS/s at 200MHz, which all adds up.
Going to print the pod case again, font was too small to show up. Clear color would be cool too, to see the LED inside.
Adapter case coming soon.
Offline Rerouter
Does the Channel - Channel skew line up with your trace lengths, if not we may be able to forward correct for it on a new PCB version.
Offline thmjpr
The trace lengths were matched to under 1cm or so, speed of signal in FR4 is ~15cm/ns, so 70ps. I can't see it making too much difference, its well under their specifications. The skews sort of just jump around, if I averaged a bunch of captures then I might see the relationship you are referring to.
If we wanted to extend the traces to make up for the 150ns LA->analog delay in the scope, we are talking about 22m of trace! So I'm sure the official Rigol pod does not line up with the analog channels either.
I originally had the case try to duck under the cutout in the rigol scope, but it didn't quite fit. So pulled it forward to be in front instead. The OLED module sits inside that top bezel part.
If you don't need a screen (its not as necessary as I thought because the idle signals will be clearly inverted if the cable is upside down), then removing that top makes it a simpler design.
« Last Edit: May 28, 2019, 06:07:59 am by thmjpr »
Offline Rerouter
Ah sorry, misread, though it was digital - Digital skew, I would assume the rigol would have a setting somewhere to adjust digital skew.
Online TK
Re: RPL1116 (MSO1000Z) and PLA2216 (MSO5000) Active Logic Probe teardown
« Reply #185 on: June 07, 2019, 04:09:16 pm »
Today I noticed the LA can be activated without the digital probe connected (I don't have one).  What is the purpose of the probe detect on pin 1?
I don't have any noise in the digital channels when the LA is active and there is no probe connected to the scope
Offline thm_w
« Reply #186 on: June 07, 2019, 10:06:44 pm »
You get to adjust LA settings and see what is in the menus with nothing connected which is OK. But yeah the software should probably auto-disable the channels from showing up on screen.
The noise will appear as soon as you short pin 1 and 2 together. So the probe detect pin is enabling buffers/inputs, might save some power and reduce noise, assuming its a hardware disable. The calibration menu option is also disabled.
Offline John_Cavanaugh
« Reply #187 on: June 20, 2019, 04:50:50 am »
Any thought on using mini displayport for cables?   They have orientation and same lanes as hdmi.
Cables are pretty cheap.   https://smile.amazon.com/Cable-Matters-Mini-DisplayPort-Black/dp/B0777RKTJB/ref=sr_1_8
But I didnt check on the connector prices.    I suspect the usb-c are much cheaper...
Offline thmjpr
« Reply #188 on: June 24, 2019, 01:20:53 am »
Added code for stm32 here: https://gitlab.com/thmjpr/stm32f03_la_monitor
Will show cable status ("A: -" means A cable not connected, etc.) and the two threshold voltages (0 to +15V).
I have one partial built usbc main board and un-built PCBs if anyone is interested. 3D printing is possible but would cost more for shipping.
BTW there is a SCPI command for LA time offset, :LA:TCALibrate 0.0000002 +/- 200ns but its not working (read back is always 0), suspect in another thread that its not actually been implemented yet.
That would be a good choice. Its also possible to mix it up with mini->normal size cables as those are more common, but $9 is great already and seems robust. Connectors, I see two on digikey for $2-3 each:
https://www.digikey.ca/product-detail/en/te-connectivity-amp-connectors/2129320-3/A120537CT-ND/5021748
https://www.digikey.ca/product-detail/en/pulse-electronics-network/E9320-001-01/553-3756-1-ND/4169580
« Last Edit: June 24, 2019, 01:51:42 am by thmjpr »
Online jMachina
« Reply #189 on: August 08, 2019, 10:45:53 pm »
Wow, I am so glad that I just made this account! Would you be willing to share design files and firmware so I can make a run of PCBs?
Thank you kindly,
jMachina
Offline thmjpr
« Reply #190 on: August 09, 2019, 05:13:30 am »
Thank you kindly,
jMachina
Thats great. I've added files for revision 1 board here: https://gitlab.com/thmjpr/stm32f03_la_monitor/tree/master/PCB_Rev1
As mentioned in PM, I would recommend going with that and modding the pod PCBs, or getting me to do it. That way you'd have 14 usable channels out of 16, then two inverted. Shipping the extra boards is not expensive. But if you want to wait for Rev2 files that is OK.
« Last Edit: August 09, 2019, 05:15:11 am by thmjpr »
Offline thmjpr
« Reply #191 on: September 03, 2019, 06:35:12 am »
Revision 2 PCB is here: https://gitlab.com/thmjpr/stm32f03_la_monitor/tree/master/PCB_Rev2
- See readme.md
- A 50 pin connector available from LCSC but has no polarized part in the middle, so could accidentally be plugged in upside down. One polarized version is: SFH11-PBPC-D25-ST-BK (digikey)
- CC1/2 resistor values might need to be played with or voltage measured, can't recall if I used what was on the schematic.
Attached some parts I bought from LCSC but its not the complete BOM, just use for sourcing ideas.
The following users thanked this post: MegaVolt
Offline AngusBeef
« Reply #192 on: September 06, 2019, 06:01:06 pm »
I'm a little uncertain reading through this thread - does the logic analyzer you guys designed improve anything off the Rigol design, or is it simply a matter of reducing the $400 price tag off the Rigol product to BOM plus hobby time?
Online spongle
« Reply #193 on: September 06, 2019, 07:22:13 pm »
- See readme.md
This is fantastic, if you have any spare boards / parts you'd like to sell I'm interested.
Offline thmjpr
« Reply #194 on: September 06, 2019, 09:40:49 pm »
Its mostly reducing the price tag. There are some small improvements, like if you want a longer cable you could buy a different length USB-C cable.
I have 3x rev 1 bare boards, I don't plan on buying rev2. $4 for just PCBs in a bubble envelope, modding required. Will send a PM for the pre-made board price.
