Author Topic: R&S FSPN Phase noise analyzer and VCO tester  (Read 489 times)
Offline Leo Bodnar
« on: October 25, 2021, 05:49:45 pm »
We had this phase noise tester unit for a week but it wasn't enough to take it through its paces.
Does anybody have comments about this unit?
https://www.rohde-schwarz.com/us/products/test-and-measurement/phase-noise-analyzers/rs-fspn-phase-noise-analyzer-and-vco-tester_63493-1087847.html
We have also tried FSWP but could not make our mind up either.  With all the options (SA, etc) it was just too expensive.  FSPN, on the other hand is almost "take it or leave it" - this appeals to me.
I always thought that FSWP is positioned as E5052B killer.  Not sure how FSPN stacks up against that.
Cheers
Leo
Offline Wolfgang
    • Electronic Projects for Fun
Re: R&S FSPN Phase noise analyzer and VCO tester
« Reply #1 on: October 25, 2021, 11:08:51 pm »
Did all my PhD work on an FSWP26.
The FSPN looks like a phase noise only version of the FSWP (No SA, noise figure, pulse, IQ, protocols, ...).
How much do they ask for an FSPN ? The FSWP is a lot above the Keysight pricewise, but it can also do a lot more.
IMHO, the main criteria is frequency range. If you need <10MHz (I did), Keysight has no offer, If you need < 200MHz, the Microsemi part could be an option (53100A). Above, its R&S or Keysight.
The RS parts are "integrated" solutions with internal references. These can limit performance, but a dual external reference system is not supported AFAIK. Keysight the same, Microsemi *must* use external references, making very low PN measurements possible (< -130dBc@1Hz).
What do you intend to measure ?
Offline Leo Bodnar
« Reply #2 on: October 26, 2021, 09:18:54 am »
Thanks, Wolfganag.
This all does make sense.
Indeed, for simple sub-200MHz work I now use 53100A - I switch between low PN and high stability external sources depending on the needs.  It's fanless and fits on my desk easily.
For over-200MHz I could use E5500 or HP3048A but you'd need a clean signal source for each frequency of interest.  They are both very noisy so don't get much use these days.
I see FSPN as a simple and fast GHz instrument.  Need to think about a bit more.
Cheers
Leo
Offline Sighound36
« Reply #3 on: October 26, 2021, 11:21:26 am »
Leo
Howabout one of these, we find them more than sufficent for PH meas
https://www.holzworth.com/products/phase-noise-analyzers/ha7062c
Sighound
Offline Leo Bodnar
« Reply #4 on: October 26, 2021, 01:40:27 pm »
I have looked at Holzworth (and a few Swiss companies) offers for quite some time but I don't personally know anybody who has one.
Yeah, I know, it's shallow but still...
Leo
Offline Sighound36
« Reply #5 on: October 26, 2021, 02:58:03 pm »
Hi Leo
We have had Holtzworthy's for a few years, we are involved with ultra low phase noise clock design and manufacturer so it is an essential part of remit.Quality equipment, great back up and ultra stable units.
Never really liked the KS PNA until you get to the real silly money, the R&S is always top draw, if a touch quirky but if you not require all the belles and whistles then the Holtsworthy and Microsemi (Its a US designed instrument from memory)
It handles the clocks we have to -122dbc @ 1hz and over -180bc @ 10Mhz compared its results to a big KS noise analyser which is then six figure range, more than happy with the results.
They are quite a few users in the UK I believe
« Last Edit: October 26, 2021, 07:08:17 pm by Sighound36 »
Offline Gerhard_dk4xp
« Reply #6 on: October 26, 2021, 08:21:01 pm »
https://ieeexplore.ieee.org/document/6588446
They have compared a lot of instruments. It's behind the IEEE pay-wall of shame,
but I have seen it in the wild. The Timepod is missing, of course.
In Microwaves/Microwave Magazine there was also a variant IIRC.
Cheers, Gerhard
Offline Wolfgang
« Reply #7 on: October 26, 2021, 08:29:01 pm »
Thanks, Wolfganag.
Cheers
Leo
Hi Leo,
just curious, what kind of references do you use for < 200MHz and above ?
Best regards
  Wolfgang
Offline Leo Bodnar
« Reply #8 on: October 26, 2021, 08:29:14 pm »
I think I might have read it before.
Is this the one where they had to wrap the whole kit in Aluminium foil to get rid of local FM station EMI?
Leo
Cheers, Gerhard
