You can watch the video here: [46 Minutes]
youtu.be/qaN1f8G--zcThe video description:
In this episode Shahriar looks at the ecosystem of R&S power sensors & power meter. In particular, the NRP Triple-Diode Path Power Sensor & the unique NRQ6 Frequency Selective Power Sensor:
https://www.rohde-schwarz.com/us/products/test-and-measurement/rf-and-microwave-power-sensors/rs-nrpxxs-sn-sn-v-three-path-diode-power-sensors_63493-99587.htmlhttps://www.rohde-schwarz.com/us/products/test-and-measurement/rf-and-microwave-power-sensors/rs-nrq6-frequency-selective-power-sensor_63493-533642.htmlThe R&S NRX Power Meter can be used to interface with a wide range of power sensors as well:
https://www.rohde-schwarz.com/us/products/test-and-measurement/power-meter-base-units/rs-nrx-power-meter_63493-533644.htmlThis review is organized as follows:
00:00 – Introductions.
00:40 – NRP40SN 3-Path Diode Power Sensor hardware overview.
01:21 – Triple-Diode sensor architecture, benefits, principle of operation.
05:59 – Experiment setup, AM modulation glitch, web interface design, power measurements, high-sampling rate, trigger setup, trace view, R&S Power Viewer windows software.
16:17 – NRQ6 Frequency Selective Power Sensor hardware overview.
17:10 – NRQ architecture, principle of operation, advantages & disadvantages, DSP functions.
21:51 – Experiment setup, multi-frequency signal generation & interference, blocker signals.
23:33 – Web GUI interface, Signal Check function, auto-set, IF BW setup, I/Q, trace view, attenuation & averaging, blocker signal impact, catching frequency hopping events, ACLR measurements, additional features.
37:19 – NRX Power Meter overview & teardown.
40:49 – Experiment setup, input VSWR & power amplifier output power measurement.
40:01 – NRX GUI, multi-sensor measurement, sensor setups & measurement features.
45:48 – Concluding remarks.
