Author Topic: RS-Pro IDM-8341 Benchtop multimeter excel addin  (Read 206 times)
Offline divy001Topic starter
« on: December 30, 2024, 10:11:29 pm »
Hi
I was trying to use RS Pro IDM-8341 to log some information on an excel.
And to do i found there is an add-on for excel and drivers that go with it but all i can online are for GDM-8341. I changed drivers to work for IDM but excel add-in is difficult to change.
Just wondering do anyone has drivers for IDM-8341 and maybe excel Add-in. (I have emailed RSPRO and gwtech as well but haven't received an response in last couple of days)
Offline coromonadalix
Re: RS-Pro IDM-8341 Benchtop multimeter excel addin
« Reply #1 on: December 31, 2024, 03:10:09 am »
you should not double post
Online voltsandjolts
« Reply #2 on: December 31, 2024, 10:45:54 am »
Consider using a Python script or TestController (your dmm not yet supported), both of which would require some effort on your part but folks here would likely help with specific questions.
Offline mendip_discovery
« Reply #3 on: December 31, 2024, 11:51:48 am »
Short term solution, log it to a USB stick and then open the data files in Excel. Looks like it supports CSV files which are easy to work with.
In the long term, find a program you would like to use to control the meter and go from there. I am using one connected to a Rasberry Pi and using Jupyter Notebooks to do the clever stuff.
Motorcyclist, Nerd, and I work in a Calibration Lab :-)
So everyone is clear, Calibration = Taking Measurement against a known source, Verification = Checking Calibration against Specification, Adjustment = Adjusting the unit to be within specifications.
